Mode S transponder display to ATC?
Old September 5th 08, 01:33 PM posted to rec.aviation.ifr
Mike[_22_]
Default Mode S transponder display to ATC?
"Thomas Borchert" wrote in message
Paul,
Is it normal practice for a Mode S transponder to display the aircraft
tail number to ATC?
Mode S transponder have the option of setting a flight ID or the tail
number in a data field designated for that info. This is broadcast with
the Mode S data packet and is independent of the unique transponder hex
code. In airline operations, the flight crew normally sets the flight ID
for each flight, e.g. UA011 for United flight 011. In GA operations, the
aircraft tailnumber is set by the installer.
Controllers with mode S radar equipment have the option of displaying
this data field next to the "blip". I do not know how common such
equipment is in the US, but it is getting more and more widespread in
Europe.
It doesn't exist anywhere in the US. I seriously doubt it will ever be
implemented as ADS-B which has a much more robust datalink capability will
be the shape of things to come.
Old September 5th 08, 01:37 PM posted to rec.aviation.ifr
Jay Maynard
In the US, the tail number is assigned an 8-digit octal number to be used as
the flight ID algorithmically by the FAA. I don't know what other countries
do. Since it's algorithmic, it's possible to go backward from ID 51577524 to
N55ZC.
Europe.
Apparently, it's not used in the US at all.
AFAIK, the big database correlating call signs and hex codes inside the
radar equipment is a myth.
If other countries do it the way the FAA does, there's no need for a
database.
Jay Maynard, K5ZC http://www.conmicro.com
http://jmaynard.livejournal.com http://www.tronguy.net
Fairmont, MN (FRM) (Yes, that's me!)
AMD Zodiac CH601XLi N55ZC
Old September 5th 08, 03:18 PM posted to rec.aviation.ifr
Thomas Borchert
Jay,
Hmm. Do you have a source for that? Since every airline flight using a flight
number rather than a tail number for the flight ID field in the mode S data
packet would break that algorithm, it doesn't make much sense to use it in the
first place.
Thomas Borchert (EDDH)
Old September 5th 08, 03:30 PM posted to rec.aviation.ifr
Jay Maynard
Not directly, but I got curious to see how it was assigned, and started
poking at the FAA registration database (which includes the assigned code).
The algorithm winds up assigning 50000001 to N1, 50000002 to N1A, 50000003
to N1AA, 50000004 to N1AB,... 50000032 to N1AZ, 50000033 to N1B, 50000034 to
N1BA,... 50001131 to N1ZZ, 50001132 to N10, 50001133 to N10A, and so on. I
never got to the point of writing C code that would generate the code, but
it would be fairly straightforward. The algorithm depends on the rules for
assigning N numbers, and works left to right, with the letters in order from
A to Z (skipping I and O), then 0-9, taking all of the letter combinations
in order before expanding the number field.
Since every airline flight using a flight number rather than a tail number
for the flight ID field in the mode S data packet would break that
algorithm, it doesn't make much sense to use it in the first place.
It saves having an application process for a code separate from the
registration process. They have to come up with the number from somewhere,
and since they have a block big enough to accommodate every possible N
number, it works out easiest that way.
Old September 5th 08, 09:11 PM posted to rec.aviation.ifr
Mike[_22_]
"Jay Maynard" wrote in message
used as
code).
to
from
There's no need as it's already been done and put online.
http://www.airframes.org/
number
This is exactly correct. The registration number and the MODES ICAO ID are
one and the same.
The ICAO ID can also be used to selectively address the transponder (the S
in ModeS stands for "select"). So one particular transponder may be
interrogated exclusively by using the unique ICAO ID. Part of the reason
for this is the FAA was concerned about transponder saturation in areas that
have a high density of sensors. The theory was that a ModeS transponder
could be selectively interrogated by one sensor, and that sensor would share
that position data with other sensors within range. This technology was
never implemented in the US for a few reasons, but that capability still
exists within the transponder standard.
Old September 5th 08, 09:51 PM posted to rec.aviation.ifr
Jay Maynard
code). The algorithm winds up assigning 50000001 to N1, 50000002 to N1A,
50000003 to N1AA, 50000004 to N1AB,... 50000032 to N1AZ, 50000033 to N1B,
50000034 to N1BA,... 50001131 to N1ZZ, 50001132 to N10, 50001133 to N10A,
and so on. I never got to the point of writing C code that would generate
the code, but it would be fairly straightforward. The algorithm depends
on the rules for assigning N numbers, and works left to right, with the
letters in order from A to Z (skipping I and O), then 0-9, taking all of
the letter combinations in order before expanding the number field.
Well, it appears he's written the code, but it doesn't appear to be
available...I'd like to see the actual code, just to check if my thoughts on
the programming required to go in the reverse direction are correct. I'd
also like to see if other countries assign their codes algorithmically.
Old September 5th 08, 10:21 PM posted to rec.aviation.ifr
Mike[_22_]
N1B,
N10A,
generate
on
The algorithm is part of the ICAO standard, so if other countries aren't
doing this, they are doing so outside the standard.
If you could find the written version of the standard in the ICAO
conventions, it would probably verify your suspicions, but ICAO standards
are a bit hard to find without paying for a copy as ICAO would like you to
do.
Old September 5th 08, 10:31 PM posted to rec.aviation.ifr
Jay Maynard
Uhm...since the US algorithm is quite dependent on the US rules for
assigning registration numbers, it would not work at all for, say, the UK.
(Although, in fairness, the UK's algorithm, as well as that for countries
that use all-alphabetic registration systems, would be quite a lot simpler
than the US one.) That either says it's not in the ICAO standard, or else
there's more than one.
Old September 5th 08, 11:17 PM posted to rec.aviation.ifr
Mike[_22_]
I haven't read the standard, but the hard wired serial number in the ModeS
transponder is refered to as the ICAO ID. I'm also quite sure the standard
exists in the ICAO convention.
Old September 6th 08, 09:20 AM posted to rec.aviation.ifr
Mxsmanic
Peter writes:
The UK CAA have a public database linking Mode S codes with tail
numbers (google on G-INFO) so it would be easy enough to trace a
specific aircraft from the 24-bit ID.
Odd that such a database would be public in a country that forbids listening
to ATC.
Garrecht Mode S transponder - USA? Eric Greenwell Soaring 3 August 20th 07 09:05 PM
New transponder mode S vs. mode C Tom N. Soaring 39 November 7th 06 07:40 AM
KT76C Mode C transponder - what is it worth? Mike Rapoport General Aviation 1 November 21st 04 05:56 AM
KT76C Mode C transponder - what is it worth? G.R. Patterson III Owning 0 November 21st 04 05:56 AM
WTB: Mode C Transponder Chris Batcheller Aviation Marketplace 0 February 21st 04 01:31 PM
