KLN-90B
Old October 6th 08, 01:05 AM posted to rec.aviation.ifr,rec.aviation.piloting,rec.aviation.owning
Default KLN-90B
I am considering KLN-90B as replacement for my M-3 Approach. Question
for experienced KLN-90B users: Legality aside, can you operate
KLN-90B in approach mode (doing GPS approaches) with an outdated
database?
Thanks in advance,
Robin Hou
Old October 6th 08, 02:25 AM posted to rec.aviation.ifr,rec.aviation.piloting,rec.aviation.owning
Default KLN-90B
" wrote in message
database?
Thanks in advance,
Robin Hou
Yes.
Old October 17th 08, 02:20 AM posted to rec.aviation.ifr,rec.aviation.piloting,rec.aviation.owning
comanche driver
Default KLN-90B
"Mike" nospam@ microsoft.com wrote in message
" wrote in message
database?
Thanks in advance,
Robin Hou
Yes.
anybody who does an approach in actual using a gps with an outdated data
base on a gps approach is just plain stupid.
Old October 17th 08, 04:30 AM posted to rec.aviation.ifr,rec.aviation.piloting,rec.aviation.owning
Default KLN-90B
"comanche driver" spamawayassh.ole wrote in message
" wrote in message
database?
Thanks in advance,
Robin Hou
Yes.
Be that as it may you can still train on the GPS with an outdated database
in VMC all you want, which is why I assumed he was asking the question.
Old October 18th 08, 01:34 AM posted to rec.aviation.ifr,rec.aviation.piloting,rec.aviation.owning
Peter Clark
Default KLN-90B
On Fri, 17 Oct 2008 02:30:21 GMT, "Mike" nospam @ microsoft.com
" wrote in message
database?
Thanks in advance,
Robin Hou
Yes.
Until the procedure is changed and the waypoints on the box and on the
chart don't match any more.
Old October 19th 08, 02:24 PM posted to rec.aviation.ifr,rec.aviation.piloting,rec.aviation.owning
Default KLN-90B
"Peter" wrote in message
news
" wrote in message
database?
Thanks in advance,
Robin Hou
Yes.
This doesn't answer your Q but may I ask why the KLN90B? It is an out
of date product, WAY out of date in fact, and no longer made or even
properly supported with database updates (the flash card is too
small).
If you are looking for that size unit, a KLN94 is a lot better.
The KLN90B is fully supported by database updates. I think you're confusing
it with the KLN89B which has a smaller card, but even in the case of the
KLN89B the only thing you lose is Canada and South America which is not a
problem for most.
Old October 20th 08, 04:42 PM posted to rec.aviation.ifr,rec.aviation.piloting,rec.aviation.owning
Ross
Default KLN-90B
news
" wrote in message
database?
Thanks in advance,
Robin Hou
Yes.
data
small).
confusing it with the KLN89B which has a smaller card, but even in the
case of the KLN89B the only thing you lose is Canada and South America
which is not a problem for most.
The 89/B is fully supported. I load database updates from downloads and
my laptop. The 89/B is a fine unit but, agree, dated. I have been told
that it will connect for GPSS steering but the 94/B will not.
Regards, Ross
C-172F 180HP
KSWI
Old October 20th 08, 04:59 PM posted to rec.aviation.ifr,rec.aviation.piloting,rec.aviation.owning
Default KLN-90B
"Ross" wrote in message
news
" wrote in message
Question
database?
Thanks in advance,
Robin Hou
Yes.
data
small).
It depends on your definition of fully supported. In the case of the
KLN89B, you must choose between 3 different options for the Americas. If
you choose the US option, you will get all of the approaches for Canada and
South America, but you won't get the complete database for those areas. The
KLN90B will take all of the Americas on one update. This is not really an
issue for most people.
Old October 21st 08, 06:19 PM posted to rec.aviation.ifr,rec.aviation.piloting,rec.aviation.owning
Bill
Default KLN-90B
I would still vote for the 89B. The '94 is plug compatible and makes
a nice
upgrade. It's a lot like a 430 on the GPS side.
The 90B has no upgrade path whatever. Not plug compatible with
anything.
Bill Hale
On Oct 5, 6:25*pm, "Mike" nospam@ microsoft.com wrote:
" wrote in message
I am considering KLN-90B as replacement for my M-3 Approach. *Question
for experienced KLN-90B users: *Legality aside, can you operate
database?
Thanks in advance,
Robin Hou
Yes.
Old October 22nd 08, 05:49 AM posted to rec.aviation.ifr,rec.aviation.piloting,rec.aviation.owning
Default KLN-90B
Wow, I did not expect any more reply 10 days after Mike's initial
reply of "Yes". I guess being called "stupid" does have its
advantage ;-)
The reason I consider KLN-90B because it has ARINC 429 output, and I
am hoping it can talk to Aspen EFD1000 Pro. I have emailed Aspen but
received no reply yet. But why would I install a Legacy GPS to talk
to a glass panel PFD? LOL!
I asked about outdated database because I am based in So. Cal. and
most my flights are practice approaches in VFR condition. I plan to
keep database current during winter months and just let it expires
after storm season. I have a Motion LS800 running Jeppesen FliteDeck
and it is always current 365 days a year. That is good enough for me
to fly VOR approaches using KLN-90B to monitor my approaches even if
the database is not current. Plus, my home base has only VOR
approaches with GPS overlay.
Anyhow, my panel update is still in day-dreaming stage. Thanks for
all who replied.
Robin Hou
