Bendix Ignition Switch Rebuild
Old November 27th 08, 08:49 PM posted to rec.aviation.owning
Mike Spera
Default Bendix Ignition Switch Rebuild
I have had my TCM-Bendix 357210-1 ignition switch (1974 Piper Cherokee
140) apart twice in the last 14 years to clean up the contacts. I
remember once seeing a rebuild kit consisting of the back plate and the
3 triangular pressed metal contacts. Might have been from an old
Wag-Aero catalog. I cannot seem to find such a beast. Given the price
for a new switch hovers around $275 (for a $10 part), I was looking to
see if there were any less expensive alternatives to buying a new one. I
checked several parts houses and everyone has the switch but no rebuild
kit. Was I dreaming?
Thanks for any info.
Old November 28th 08, 01:50 AM posted to rec.aviation.owning
Cessna sells that kit. Not expensive. But watch: Some kits are
for the Bendix switch and some are for the ACS (Aircraft Spruce house
brand) that Cessna often used and still does. The backplate screw lug
spacing is different so the kits are different. And some Bendix
switches have an AD against them; if yours is one that misbehaves
according to the AD, it's junk anyway. With the engine idling, shut
the mags off and try to turn the switch past the OFF position while
the prop is still turning; if the engine starts firing again you have
a bad switch. The bad ones had the OFF stop in the wrong place or
something. We had one years ago.
Dan
Ignition switch settings Tony Cox Piloting 30 March 6th 07 02:31 AM
74 Archer ignition switch question Mike Noel Owning 9 September 10th 06 11:46 PM
Ignition switch, what happen when Left or Right is selected Martin B Piloting 41 May 21st 05 05:55 AM
Just Ordered: An Ignition Switch and Oil Filter from ACS Larry Smith Home Built 30 October 22nd 03 08:41 AM
