There have been several Quiet Vent failures, mostly associated with use at
sub-zero temperatures, where the QV seal has come loose from its clear adhesive mounting strip. If you have experienced this, or any other failure of your QV, please return defective plastic seal part for free replacement with a new QV. I'll include a US postage stamp to cover your shipping cost too. A change in the manufacturing procedure should eliminate the cold/separation problem by markedly improving the bond between the QV's clear plastic seal and the clear adhesive strip used for mounting to the existing vent window. This "bonding improvement" technology has also been applied to the MKII "high tech" yaw string. This makes four improvements to the MKII since it came out, so it's time to call it the MKIII. The MKIII is now available with a synthetic yarn to improve UV exposure longevity. This will help the MKIII last longer on gliders that are tied out. The downside is I'll probably sell fewer replacement MKIII's. No increase in pricing . . . still the cheapest best toys you can buy for your favorite glider: Quiet Vent: reduces noise from the Mecaplex flip-out window vent by 10 dba (as measured in my ASH26E at 60 knots). $6 USD MKIII "high tech" yaw string: Clear turbulator base raises yarn .035" above canopy for no static cling or scratched canopy plastic. Easy to remove for replacement with no tape residue. Looks nicer than tape and yarn. Includes optional index dot. Available with synthetic or original natural wool yarn in red, royal blue, sky-blue or yellow. $10 USD US shipping free. International just $1 per order. email bumperm@ followed by att "dot" net |
| Thread Tools | |
| Display Modes | |
| Quiet Vent | Ron (RW) | Soaring | 26 | June 30th 18 05:31 PM |
| Bush Proposes To Cut Funding For Airport Improvements. | Larry Dighera | Piloting | 0 | March 11th 08 05:00 PM |
| Quiet Vent | Ramy | Soaring | 6 | October 27th 06 06:27 AM |
| Improvements in air flow for non-conventional aircraft. | NiceGuyInPDX | Rotorcraft | 0 | March 16th 04 07:23 PM |
| Helo countermeasure improvements | Eric Moore | Military Aviation | 2 | November 29th 03 01:25 PM |
