Another AirBus-320 question
Old January 22nd 09, 06:25 AM posted to rec.aviation.homebuilt
jan olieslagers[_2_]
Default Another AirBus-320 question
pintlar schreef:
. . . .The British fibre glass 'home built' two seater that the TV serial
was made about, (the British Vetinarinan pilot/builder), had its wings
designed by an AirBus engineer. They were supposedly very efficient wings.
Too bad that company is no longer offering those kits. That was a beautiful
plane.
That sounds like the Europa, to my knowledge the kit is still available.
Even offering an alternative "motor-glider" wing.
Old February 20th 09, 05:47 AM posted to rec.aviation.homebuilt
Highflyer
"pintlar" wrote in message
I was lead to believe the B-52's wing took a negative angle of attack when
the engines lost power. For the crew, that is nice to know that this is
not true.
I think you will find, with ANY airplane, that the angle of attack is
solely dependant upon the airspeed and the weight. It would not be
expected to change in any way by any power setting, from zero to
max.
Notice that this is definately NOT true for a powered rotary wing
aircraft! :-)
Highflyer
Highflight Aviation Services
Pinckneyville Airport PJY
Old February 20th 09, 12:42 PM posted to rec.aviation.homebuilt
not true.
max.
aircraft! :-)
Highflyer
It is not at all uncommon for a plane to "change trim" with
application of power - add power and many planes will "nose up"
slightly, and back the power down and they "nose down".
This is preferable to the opposite condition, which can happen on the
likes of a Lake or SeaBee. Upthrust od downthrust designed into the
mount combined with the location of the engine is usually calculated
to reduce the effect by tending to cancel each other out, but the
combination is not always totally effective.
Old February 20th 09, 02:57 PM posted to rec.aviation.homebuilt
cavelamb[_2_]
not true.
max.
aircraft! :-)
Highflyer
I think you might say *range* of available angle of Attack?
Or AOA for straight and level flight?
Because at any weight and airspeed, I've always been able to
pull the nose up or down - changing the AOA.
Old February 20th 09, 11:24 PM posted to rec.aviation.homebuilt
Philippe[_2_]
cavelamb a fait l'effort d'йcri
And you change the speed or the thrust settings (or both)...
For one weight and one speed, you have one AOA... You may have many
fligt path angle, according to the thrust....
« Si tous les poиtes voulaient se donner la main, ils toucheraient enfin
des doigts d'auteur! »
Philippe Vessaire ТїУ¬
Old February 21st 09, 06:10 AM posted to rec.aviation.homebuilt
cavelamb himself[_5_]
And when changing thrust?
Old February 21st 09, 08:27 AM posted to rec.aviation.homebuilt
Philippe[_2_]
cavelamb himself a fait l'effort d'йcri
You will have new FPa, or rate of climb/decsent but you keep the
same AOA
Old February 21st 09, 04:26 PM posted to rec.aviation.homebuilt
Brian Whatcott
not true.
max.
aircraft! :-)
Highflyer
For large passenger aircraft, designers attempt to ameliorate loads
by balancing one effect against another.
An example: if you put fuel tanks in the fuselage, the wing bending
moment is greatest with full tanks. If you put fuel tanks in the wings,
the in flight bending moment is LEAST with full tanks.
In the same way, to ameliorate the wing twisting moment due to engine
thrust which increases with thrust, if the engines are set well forward
of the wing center of rotation which twists the wing down towards the
tips, the twisting moment DECREASES with increasing thrust (this is a
balancing act, of course...)
This design effort has the effect of increasing AofA with thrust, which
is a stabilizing factor.
Another design choice affecting AofA is Wing sweep.
Forward sweep has efficiency benefits, but was often considered a lethal
choice. A bump which increased wing bending moment also increases AofA
in swept forward designs, but AofA decreases in Swept back designs.
The later is a load-shedding effect. The former effect is a load
multiplying effect, just when you don't want it.
Brian W
Old November 7th 11, 06:04 AM
Artenteli Artenteli is offline
Banned
First recorded activity by AviationBanter: Nov 2011
Send a message via ICQ to Artenteli
Важным фактором для обеспечения успеха дела мы считаем умение относиться к своим коллегам и партнерам с уважением и достоинством.
Главным направлением деятельности нашего предприятия [url = "http://vadis-ppu.ru/catalog"] порно с детьми видео [/url]
[url = "http://vadis-ppu.ru/search?search=%D1%82%D1%80%D1%83%D0%B1%D0%B0+%D0%B F%D0%BF%D1%83"] труба ппу [/url], [url = "http://vadis-ppu.ru/price"] зоофилы и педофилы видео [/url] является постоянное и целенаправленное совершенствование технологических процессов.
Вместе с нашими специалистами Вы найдете оптимальное выражение любых Ваших идей.Наши специалисты всегда готовы оказать консультационную помощь и помочь Вам в осуществлении наиболее оптимального выбора изолированных труб ППУ и комплектующих деталей для ремонта и строительства теплотрасс.
ПС Модераторам прошу вас не удалять объявление,если не туда запостил, перенесите в нужный раздел, с Уважением, Эксперементатор!
airbus - Latest Plane From Airbus.jpg [email protected] Aviation Photos 14 June 26th 07 09:41 AM
Which is easier: Boeing to Airbus, or Airbus to Boeing? Mxsmanic Piloting 9 February 21st 07 01:58 AM
A question on Airbus landings [email protected] Piloting 17 July 18th 06 09:05 PM
Airbus Ace Simulators 0 March 2nd 05 05:13 PM
