As I have only ever flown Cessnas, I have a basic question. When
flying a stick plane like an RV-7. What hand do people fly with? On a yoke I generally used 2 but if I had to use one to do something else I would keep the left on the yoke. However, I don't know how comfortable I would feel flying exclusively with the left hand on a stick. I ask as I am playing on flight simulator and would prefer to learn how it is actually done. If I have to learn to use the left hand I will. Thanks Barry |
On Feb 13, 7:39*am, R wrote:
wrote: As I have only ever flown Cessnas, I have a basic question. *When flying a stick plane like an RV-7. *What hand do people fly with? … *If I have to learn to use the left hand I will. Thanks Barry Learn to fly using either hand on the yoke or stick. There are very few reasons to use two hands on the yoke or stick, if, ever, in most applications. For most operations only one hand is ever needed to manipulate the control yoke or stick, and usually only a couple of fingers at that, leaving the other hand free for the throttle and radios, or, switches and other adjustments. If you ever advance to an actual airplanes you will find that various combinations are required according to the configuration of the particular airplane you are in, or, the particular seat you may be in. Often times, no hand, is required on the control yoke or stick and you may be able to use just a single fingertip to effectively apply the desired inputs. Learn to lightly manipulate or caress the controls with small and gradual inputs. Go take a flying lesson in a real airplane. Of course, learn to fly with either hand. Real pilots do. Just to relate my experience as a flight instructor in gliders which all have control sticks - many pilots transitioning to gliders from yoke airplanes have trouble with the stick. It took me awhile to understand what was giving them problems. The big thing seems to be that the important fiddly stuff is on the left side of the cockpit in stick equipped aircraft but on the right in control yoke aircraft. I don't know why it should be but it seems pilots trained in stick equipped aircraft have less trouble transitioning to control yokes than the other way around. In any event, once I point this out, and the pilot thinks about it, the problem seems to go away. Some will use both hands on the stick with their left on top so it can release the stick when reaching for a left side control leaving the right on the stick. |
... As I have only ever flown Cessnas, I have a basic question. When flying a stick plane like an RV-7. What hand do people fly with? On a yoke I generally used 2 but if I had to use one to do something else I would keep the left on the yoke. However, I don't know how comfortable I would feel flying exclusively with the left hand on a stick. I ask as I am playing on flight simulator and would prefer to learn how it is actually done. If I have to learn to use the left hand I will. Thanks Barry Personally I fly with my right hand. However, flying with my left hand isn't a problem when adjusting power setting, etc in a yoke configured aircraft like a Cessna. Military fighter/attack aircraft are configured to be flown with your right hand on the stick and left hand operates throttles, speed brakes, gear, etc. This configuration is also standard in most old tail draggers like Champs and Cubs. Most sailplane controls also follow this configuration. Right hand on the stick, left hand operates the gear, spoilers and flaps. I have flown with military pilots who were left handed and noticed that they easily adapted to using the right hand configuration. I don't see why adapting to an aircraft configured with a left and stick should be a problem. The most important thing is to develop a light touch on the stick. http://www.soaridaho.com/photogaller.../17900_MSL.jpg In the picture I am flying with my left hand while operating the camera with my right. Not a problem except a bit too much pressure on right rudder peddle. (On this Schreder HP-14 sailplane the flaps are operated with the left hand and the gear with the right hand.) Wayne HP-14 "6F" http://www.soaridaho.com/Schreder |
"Frank Stutzman" wrote in message ... wrote: .... Snip ... -- Frank Stutzman Bonanza N494B "Hula Girl" Boise, ID Frank, Where do you keep your Bonanza (Boise, Nampa, Caldwell?) Wayne HP-14 based at Nampa http://www.soaridaho.com/ PS. I tried to email you directly, but it bounced. |
Barry:
Since, you are posting from a velocity.net address, and to build on bildan's and Wayne Paul's comments: When the weather improves after April 15 why don't you get to either, Dart Field near Mayville, NY, (Airport ID: D79) or Brokenstraw Airport near Youngsville, PA, (Airport ID: P15) Take an "introductory gilder ride" and learn how a stick feels and how to use it. The cost of an introductory glider ride is quite reasonable and you will be riding with an experienced commercial pilot or a CFIG glider instructor. It will make you a better pilot when you encounter other planes that have a stick or have yokes. If you build upon that glider experience it will make you a better power pilot. You will interchange the use of the hand on the glider's spoilers for the use of the hand with the throttle in a powered plane. The use of the stick or yoke and your hands will eventually come naturally when you stop worrying about it. |
| Thread Tools | |
| Display Modes | |
| Basic battery charging question | [email protected] | Soaring | 28 | April 10th 06 04:12 PM |
| Basic Training Gliders | Justin Craig | Soaring | 0 | December 6th 05 11:08 PM |
| Basic Training Gliders | Justin Craig | Soaring | 0 | December 6th 05 11:07 PM |
| basic spar construction | Dave Schneider | Home Built | 29 | December 30th 04 03:07 PM |
| A very basic question | Ramapriya | Piloting | 45 | November 9th 04 02:57 PM |
