Stall Warning - AofA
Old March 1st 09, 05:12 PM posted to rec.aviation.misc,rec.aviation.homebuilt
Brian Whatcott
Default Stall Warning - AofA
One of the design features of the Cessna 150 that I admired most is the
stall warning. It is a small aperture in the lower curve of the leading
edge guarded by a wire screen (those pesky flies!) The cavity connects
to a tube leading to the wing root in the cabin. There, covering the
other end of the tube is a mouth organ reed, arrange to be silent when
blown, and to whine when sucked. That's three components and just one
moving part if you could call a vibrating reed, a moving part.....
The most bang from the least buck - it seems to me.
It was pre flight checkable - with a wipeoff of fly squash and a mouth
applied suck. Wonderful!
It was not everyone's cup of tea, I don't suppose: in particular, that
mouth to wing actvity was eliminated by a small vane on a microswitch,
which howled when the vane pushed up at high AofA. I think that was a
C172 mod wasn't it? It needed power to work though.
Anyway, for something a little fancier yet, a kind of lift reserve or
AofA indicator that takes two pitot tubes to a differential pressure
gage, shown he about $`125
http://www.pipcom.com/~cowcam/AOAr.htm
I am prejudiced in favor of red sector in right, not in left but that's
just my feeling.
[No financial interest]
Brian Whatcott
Altus OK
Old March 1st 09, 08:08 PM posted to rec.aviation.misc,rec.aviation.homebuilt
Dan[_12_]
just my feeling.
Brian Whatcott
Altus OK
It's a rather nice system.
What is the purpose of the zip tie around the tube? It's not tight
enough to secure anything.
Dan, U.S. Air Force, retired
Old March 1st 09, 08:39 PM posted to rec.aviation.misc,rec.aviation.homebuilt
Dana M. Hague[_2_]
On Sun, 01 Mar 2009 11:12:59 -0600, Brian Whatcott
other end of the tube is a mouth organ reed...
Hah!
Many years ago I took my then recent bride for her first small
airplane ride in a 150 borrowed from a friend (since my T-Craft had
been down for work for some time). Being young and foolish and a
showoff, I decided to do a spin, which is, of course, preceded by a
stall... to this day she tells of the flight, "Oh my goodness, we were
flying along and all the sudden a SIREN went off and I thought we were
going to die..."
-Dana
I can see clearly now, the brain is gone...
Old March 1st 09, 09:19 PM posted to rec.aviation.misc,rec.aviation.homebuilt
Paul Tomblin
Our club bought a plane that had a Lift Reserve Indicator. Everybody
hated it, because it was in the way, and so we had it ripped out. I never
got a chance to see it in action.
Paul Tomblin http://blog.xcski.com/
"What we obtain too cheap we esteem too lightly; it is dearness only that
gives everything its value." - Thomas Paine.
Old March 1st 09, 10:10 PM posted to rec.aviation.misc,rec.aviation.homebuilt
Brian Whatcott
Brian Whatcott
Altus OK
I have no great insight into operating this system, but my guess is the
usual one about things on struts - they tend to oscillate in the wind -
and this might damp it out???
Brian W
Old March 2nd 09, 12:28 AM posted to rec.aviation.misc,rec.aviation.homebuilt
Dan[_12_]
Brian Whatcott
Altus OK
Brian W
I would think it would be better served to strap it securely to the
strut.
My pet peeve with some who use tie wraps is they don't cut the tail
flush with the lock. It's a safety issue since the tail can scratch or
cut ones skin. Depending on where that strut is the tail could catch an
unwary person in the eye.
Old March 2nd 09, 02:29 AM posted to rec.aviation.misc,rec.aviation.homebuilt
Morgans[_2_]
It looks to me like the tie is loose enough, but at the midpoint of the
lines, so that when exposed to airspeed, the tie holds the lines more or
less straight.
Old March 2nd 09, 12:57 PM posted to rec.aviation.misc,rec.aviation.homebuilt
Stealth Pilot[_2_]
just my feeling.
Brian Whatcott
Altus OK
my stall warning has cost me $1.25 and has performed faultlessly for
20 years, then again for 8 years. :-) (I accidently glued it up with
epoxy)
yea it is on a wooden wing.
a small microswitch is imbeded in the wing skin.
contacting that is a small aloominum vane held to the wing loosely by
two brass countersink screws. the middle of the vane is cut away so
that it looks like two postage stamp sized areas separated by two
pieces of aluminium about 10 mm wide. (think of a rectangle with a
square hole in the middle) the screws provide a hinge in the middle of
one end rectangle.
the two parallels are curved around the wing leading edge profile and
the end area bends up perpendicular to the leading edge at that point.
the exact position of the bend is found experimentally so that the
vane lifts and the microswitch is triggered on about 5 knots before
the stall.
the microswitch has two wires back to a light on the panel.
the circuit is of course powered from the aircraft battery and sits
normally open circuit until the microswitch closes when the red light
illuminates.
this requires no power at all unless the stall warning is activated.
stall warning light and aircraft wiring of course cost more than the
$1.25 I spent at tandy replacing the microswitch I glued solid but
that is all it has cost me.
it is chugger simple and it works to 160 knots.
$125 buys more envy though :-)
Stealth Pilot
Old March 5th 09, 03:53 AM posted to rec.aviation.misc,rec.aviation.homebuilt
The 172's also used the sucker horn. The microswitch was a earlier
iteration on smaller Cessnas and was used much later on faster
singles.
The reed for the horn is one of the cheapest parts you can buy from
Cessna. Last batch I bought were something like 47 cents apiece. But
then, some of them didn't work and took a little dorking with the reed
to get them to squeak properly.
If there are ANY leaks in that system it won't work. Common leakage
is at the wing's leading edge skin-to-hose fitting interface, where
there's a small plate (with the slot in it) sandwiched between the two
that's adjustable for stagnation point so the 5-10 kt thing can be
adjusted. The hose fitting is plastic and cracks, too, and Cessna more
than makes up for the low reed price by charging bigtime for the
fitting.
Dan
grumman aa-5 stall warning delay H@mst3r Owning 12 January 12th 09 12:30 AM
Secondary Stall w3n-a Products 10 December 10th 08 07:10 PM
Stall warning switch for Cessna 206? [email protected] Owning 1 February 20th 07 09:16 PM
Stall Recovery Danny Deger Piloting 12 January 30th 07 01:01 AM
Plane with no stall warning device? Roy Smith General Aviation 23 February 17th 04 03:23 AM
