Throttle or Prop control first after takeoff
Old March 12th 09, 11:44 PM posted to rec.aviation.owning
BT
Default Throttle or Prop control first after takeoff
How about Cessna T182T NAV III
BT
On Mar 6, 7:31 pm, "BT" wrote:
Some one already mentioned the take off procedure for the C-182T (Turbo).
Reduce the MP and the Fuel Flow to the Top of the Green.
That is true but the C-182T is *not* turbo.
-Robert
Old March 14th 09, 04:23 PM posted to rec.aviation.owning
Dan Luke[_2_]
Can be. Mine is.
Dan
T182T at 4R4
Old March 15th 09, 03:04 PM posted to rec.aviation.owning
Peter Clark
On Sat, 14 Mar 2009 11:23:28 -0500, "Dan Luke"
Can be. Mine is.
I do believe that unless filing a flight plan, technically, that's a
T182T, not a C182T.
A bit pedantic, yes, but still.
Old March 15th 09, 05:15 PM posted to rec.aviation.owning
BT
"Peter Clark" wrote in message
(Turbo).
Can be. Mine is.
T182T, not a C182T.
And if filing a flight plan.. it is neither.. but most likely a C-182/G
(with NAV III package)
and ATC does not care if it is turbo or not.
BT
Old March 16th 09, 02:19 AM posted to rec.aviation.owning
-b-
In article
says...
We older guys can remember a time when cars would "ping" or
"knock" when the engine was driven at a low RPM and too much throttle.
That was detonation and it would break rings and knock holes in
pistons and trash the bearings and sometimes heads and cylinder walls
would crack.
Careening wildly off course here, but in truth the evidence is not that
clear-cut about the damage done to automobile engines from "knocking".
Recalling my UofM courses on the subject, the text even reproduced a study
of tear-down examination of engines after many hours of heavy knocking in
a laboratory controlled environment, and the results were inconclusive as
concerns damage to engine components.
The main concern with knocking, in car engines, is that once IMEP exceeds
KLIMEP the power starts to fall off rapidly; therefore this represents an
absolute performance limitation for any engine.
I am willing to accept that things are different in the world of aircraft
engines, where slow rotational speeds and turbocharging may lead to
extreme detonation conditions, if mismanaged.
Sources:
http://www.me.umn.edu/education/courses/me5461/
Internal Combustion Engines, by Richard Stone, 3rd Edition, SAE 1999
Old March 16th 09, 05:26 PM posted to rec.aviation.owning
Robert M. Gary
On Mar 14, 9:23*am, "Dan Luke" wrote:
"Robert M. Gary" wrote in ...
Can be. Mine is.
Dan
T182T at 4R4
No, yours is a C-T182T.
-Robert
Old March 16th 09, 05:30 PM posted to rec.aviation.owning
Robert M. Gary
http://www.aopa.org/whatsnew/acdesig.html
Filing a filght plane a C182 is non-turbo. A C82R is turbo. Generally
ATC does care about turbo. Just like there are two common Mooneys,
M20P and M20T. All M20's that are non-turbo are M20P (there is no
M20E, M20F, M20J, etc in a flight plan).
-Robert
Old November 16th 12, 06:25 AM posted to rec.aviation.owning
dcd
On Saturday, March 7, 2009 9:41:21 AM UTC-8, Danny Deger wrote:
The POH on my 1941 Taylorcraft doesn't say a thing about when to adjust
the prop :-)
Danny Deger
I didn't think the 1941 Taylorcraft came with a POH? Do you still have it?
Right prop, wrong prop? Wood prop, metal prop? Gus Rasch Aerobatics 1 February 14th 08 10:18 PM
Head wind takeoff into rising hills, or crosswind takeoff to open space ?? P S Piloting 7 September 20th 07 07:29 PM
Question on Baron 58 prop control Mxsmanic Piloting 62 December 3rd 06 05:26 AM
You Want Control? You Can't Handle Control! -- Was 140 dead ArtKramr Military Aviation 0 March 2nd 04 08:48 PM
Hydraulic CS prop converting to Adjustable prop? Scott VanderVeen Home Built 0 December 5th 03 05:54 PM
