I just towed my new (to me) Cobra for the first time and when I
brake even moderately, the tires lock up on the trailer, then let go, then lock up in a repetitive cycle of about 3Hz. What do I do? Brian |
On Mar 7, 7:30*pm, Brian Bange wrote:
I just towed my new (to me) Cobra for the first time and when I brake even moderately, the tires lock up on the trailer, then let go, then lock up in a repetitive cycle of about 3Hz. What do I do? Brian Start by adjusting the brakes properly. Follow these well written directions from Spindelberger... http://www.cobratrailer.com/Bremsein...englisch_1.pdf You don't say how old the trailer is and how many miles it has traveled. It could be it needs more work in addition to this, but this is the place to start. When you break something Williams Soaring has lots of Cobra parts in stock (there is a free plug in return for an excellent recent trailer maintenance seminar). Darryl |
If the trailer is more than 8 or 10 years old, there's a good
possibility that the shock absorber in the tongue of the trailer is shot. Tim Mara has posted some great info on his website on how to remove and replace this part. http://www.wingsandwheels.com/Tongue%20detail.htm I believe that Williams should be getting some of those parts in soon. But if you have not already removed and examined the shock you must have all the info for your trailer in detail to figure out which shock you need. Send all the numbers from the left side of the trailer tongue to Agnes at Cobra. She'll set you straight. The link Darryl posted is excellent instruction for adjusting the brakes. Many people adjust the wrong place in the system. You should never adjust the threaded rod from the tongue to the cable, unless you're undoing a previous maladjustment. Jim |
Darryl Ramm wrote:
On Mar 7, 7:30 pm, Brian Bange wrote: I just towed my new (to me) Cobra for the first time and when I brake even moderately, the tires lock up on the trailer, then let go, then lock up in a repetitive cycle of about 3Hz. What do I do? Brian Start by adjusting the brakes properly. Follow these well written directions from Spindelberger... http://www.cobratrailer.com/Bremsein...englisch_1.pdf You don't say how old the trailer is and how many miles it has traveled. It could be it needs more work in addition to this, but this is the place to start. When you break something Williams Soaring has lots of Cobra parts in stock (there is a free plug in return for an excellent recent trailer maintenance seminar). And possibly, the gas spring in the tongue is shot. It's easy to check. -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * "Transponders in Sailplanes" http://tinyurl.com/y739x4 * Sections on Mode S, TPAS, ADS-B, Flarm, more * "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
Thanks fella's, this information gives me a pretty good start.
At 06:47 08 March 2009, Eric Greenwell wrote: Darryl Ramm wrote: On Mar 7, 7:30 pm, Brian Bange wrote: I just towed my new (to me) Cobra for the first time and when I brake even moderately, the tires lock up on the trailer, then let go, then lock up in a repetitive cycle of about 3Hz. What do I do? Brian Start by adjusting the brakes properly. Follow these well written directions from Spindelberger... http://www.cobratrailer.com/Bremsein...t_Bildern_engl isch_1.pdf You don't say how old the trailer is and how many miles it has traveled. It could be it needs more work in addition to this, but this is the place to start. When you break something Williams Soaring has lots of Cobra parts in stock (there is a free plug in return for an excellent recent trailer maintenance seminar). And possibly, the gas spring in the tongue is shot. It's easy to check. -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * "Transponders in Sailplanes" http://tinyurl.com/y739x4 * Sections on Mode S, TPAS, ADS-B, Flarm, more * "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
On 8 Mrz., 04:30, Brian Bange wrote:
I just towed my new (to me) Cobra for the first time and when I brake even moderately, the tires lock up on the trailer, then let go, then lock up in a repetitive cycle of about 3Hz. What do I do? Brian HGi Brian In your case, most likely the wheels are too big in diameter. Overrunning brakes are a self regulating system, and they are servo- sustained. Self regulating means, that a trailer with a certain weight needs a certain diameter of the brake drum and a certain diameter of the wheels. The dynamic wheel diameter for a trailer with wheels with 4 bolts can be between 572 and 602 mm, so the difference between minimum and maximum diameter is just slightly more than one inch. The dynamic wheel diameter is the diameter with 100 km/h ( about 60 miles an hour.) Here the wheel is about 12 mm( 1/2 inch) more in diameter as the trailer resting. As mentioned before, the brake is servo sustained. This is done with a certain position of the brake shoes inside the brake drum. So, a certain amount of the force of the turning wheel is used to sustain the brake force. If your wheels are too big in diameter, this servo system just receives too much force from the wheel and overreacts, blocking the wheel. This means no force anymore to the servo brake, = brake opens. Wheel turns again = too much force to the servo brake = blocking again......... If you tell me the wheel size you currently use and if you have a brake drum with 4 or 5 lugs, I can give you some advise The whole system is designed to work perfect at 90 % of the maximum weight of the trailer. It will run up too light and brake too weak at 50 % and it will run up hard ( and brake weak again ) with 100% of the trailers maximum weight. Alfred |
On Mar 9, 10:45*am, Brian Bange wrote:
...It has P165/80R13 tires on 4 lug wheels... The nominal OD of that tire size (independent of "dynamic" effects) is: 165*0.8*2+13*25.4 = 594mm. Brian, you probably already know this, but for everyone else the parts of a tire size like "165/80R13" a 165 - Width in millimeters 80 - Aspect ratio; ratio of height to width R - Type and/or speed rating. R=radial 13 - Wheel size, same as the tire ID in inches (yes, inches) Nominal OD = (width*aspect)+(wheel size*25.4) Thanks, Bob K. |
On Mar 9, 1:46*pm, Bob Kuykendall wrote:
Nominal OD = (width*aspect)+(wheel size*25.4) Oops, I got that wrong. The correct expression is: Nominal OD = (width*aspect*2)+(wheel size*25.4) ^^ Sorry for the confusion. Thanks, Bob K. |
On 9 Mrz., 18:45, Brian Bange wrote:
Alfred, I towed the trailer home with just the wings in it. I left the fuselage in the hangar. That would account for about a 300 pound lighter load. Would this cause my problem? The trailer was probably built in 1983 and has housed an ASW20B since it was new, as nearly as I can tell. It has P165/80R13 tires on 4 lug wheels. Thank you for your very detailed post. Brian Bange At 17:11 09 March 2009, wrote: On 8 Mrz., 04:30, Brian Bange *wrote: I just towed my new (to me) Cobra for the first time and when I brake even moderately, the tires lock up on the trailer, then let go, then lock up in a repetitive cycle of about 3Hz. What do I do? Brian HGi Brian In your case, most likely the wheels are too big in diameter. Overrunning brakes are a self regulating system, and they are servo- sustained. Self regulating means, that a trailer with a certain weight needs a certain diameter of the brake drum and a certain diameter of the wheels. The dynamic wheel diameter for a trailer with wheels with 4 bolts can be between 572 and 602 mm, so the difference between minimum and maximum diameter is just slightly more than one inch. The dynamic wheel diameter is the diameter *with 100 km/h ( about 60 miles an hour.) Here the wheel is about 12 mm( 1/2 inch) more in diameter as the trailer resting. As mentioned before, the brake is servo sustained. This is done with a certain position of the brake shoes *inside the brake drum. So, a certain amount of the force of the turning wheel is used to sustain the brake force. If your wheels are too big in diameter, this servo system just receives too much force from the wheel and overreacts, blocking the wheel. This means no force anymore to the servo brake, = brake opens. Wheel turns again = too much force to the servo brake = blocking again......... If you tell me the wheel size you currently use and if you have a brake drum with 4 or 5 lugs, I can give you some advise The whole system is designed to work perfect at 90 % of the maximum weight of the trailer. It will run up too light and brake too weak at 50 % and it will run up hard ( and brake weak again ) with 100% of the trailers maximum weight. * * * * Alfred- Zitierten Text ausblenden - - Zitierten Text anzeigen - Hi Brian! It seems,that I was wrong with my assumption - your wheels are the right size. So, it may be an extremly worn brake lining, may be together with a wrong adjustment of the brake rod. Please check first the lenght of the brake rod and look at the linings. Use a light to see if the lower edge of the chamfer of the lining is still visible.If not, new linigs are needed. Please do not hesitate to contact me if you have no efforts. Best regards, Alfred |
| Thread Tools | |
| Display Modes | |
| COBRA TRAILER | Gordon Schubert[_2_] | Soaring | 0 | February 10th 09 05:15 AM |
| WTB: Cobra Trailer for LS-4 | [email protected] | Soaring | 0 | July 31st 08 06:04 PM |
| FS: AL-KO 14 inch brake kit for Cobra Trailers | [email protected] | Soaring | 0 | December 21st 07 04:22 AM |
| Cobra Brake Parts or Axle | WDM | Soaring | 1 | October 11th 04 06:09 AM |
| FS: Cobra Trailer | Ed Byars | Soaring | 0 | September 22nd 03 05:47 PM |
