Bulldozing US Homeland Defence.
Old June 7th 04, 11:57 PM
Keith Willshaw
"Peter Skelton" wrote in message
On Mon, 7 Jun 2004 20:31:42 +0100, "Keith Willshaw"
Gee I just said that
No, you blamed the accident on failure to anchor a bypass.
Which is functionally identical to what you posted.
Did you even read it ?
Yes, the functional equivalency is only at the level of escaped
material. This is not a crucial point, can we move on?
No we cant
The acident happened because when a Reactor was
taken out of service a bypass consisting of sections of pipe
and bellows units was put in its place. This rested on temporary
scaffolding and the load from the liquid slug ruptured the bellows.
http://www.cheresources.com/procacc.shtml
There was no automatic shut-off upstream. The plant lacked modern
process controllers[3] and was, even by standards of the day, not
centrally controlled.
Quite so , not that it would have helped much
It would have ended the fire within fifteen minutes.
Only if it were still functional after the initial explosion, given the
scale of the damage done by what was to all intents a 50 ton
FAE thats unlikely. The issue is moot however since the major
damage was done by the initial explosion
I doubt there'd have been an explosion of anythihg like that
magnitude.
There was , read the bloody report.
A lot of material had to leak fast.
It did, , read the bloody report.
A leak of that
size should automatically close both the upstream and downstream
valves.
What upstream and downstream valves ?
The explosion was 15 tons equivalent of the BLEVE [1] type, the
fire lasted days becuase about 10% of the plant inventory had to
be allowed to burn out [2]. There was minimal effect past the
fence.
Wrong. Even though the explosion occurred on a rural site
53 members of the public received major injuries and
hundreds more sustained minor injuries. The plant was
destroyed as were several others on the same site and
close to two thousand houses, shops, and factories
were damaged with some 3000 residents being left homeless
No part of the plant met modern standards.
There are plenty of 1970's pterochem plants
still out there and the best control system in the
world doesnt help when you dump 50 tons of
Cyclohexane into the environment.
There aren't may fifties plants out there and there aren't any at
all that will dump fifty tons of cyane from a pipe rupture.
There are lots of plants built in 60's and 70's
Certainly. When was this one built?
You mean your sekrit info didnt include that fact ?
Funny the official report did,
Incidentally there are lots
of fifties plants still running but few of them have any original
process equipment still running. Fewer still use original
controll equipment. (I should have phrased my original comment
better.)
You should have kept quiet,
The causes of the
event were internal to the plant. The process affected was
obsolete and hazardous at the time and recognized as such.
A bulldozer tearing open a line would have
had the same effect.
How do you get the bulldozer to the line?
How you ever actually seen a pipe trench ?
We use bridges over here. The reason is frost, or so I was told,
but they use bridges in the southern states too.
Bull****, trenches and bridges are used everywhere. Bridges
are used to cross stuuf like roads, thats why they call em bridges
I think I'd better explain a bit. To aproach Maitland Works, or
Polysar, you've pretty much got to go in at a gate because the
ditches at the road are substantial. The gate is no real barrier
(and I've used a loose definition of "at" because the fencing
between the parking lot and the plant is ordinary chain link.)
Most plants are similar.
So no real barrier at all in fact
The plants are pretty spread out. At Miatland, it's about a
fifteen minute walk from the gate to the Cyane tower, and farther
to the other nasty processes and the tank farm. Ten minutes would
suffice (in 1975) to render the tower (really the associated
piping) safe, so even if the event started in the parking lot,
they should be able to handle the situation. Polysar is more
spread out and easier to shut down.
A LOT can happen in 10 seconds let alone 10 minutes
Then how do you get the
line to dump much more than its contents?
Have you ever calculated how much Cyclohexane
a 14" line 1000 m long contains ?
Try it , just for kicks.
Try to find an continuous kilometer long pipe in a modern,
North-American plant. Besides, without the pressure, you don't
get the explosion.
Jeesus Petey you've just been telling us how big the plants
you worked on were, get a grip will ya.
And who still oxidizes
cyane outside a collum?
It was cyclohexane and its widely used in the production
of Nylon, and any leak is highly likely to oxidise externally.
Maitland Words is nylon intermediates plant. Cyane and
cyclohexane are synonyms here (is it different in Europe?).
Cyclohexane is slighjtly less nasty than high test gasoline.
Which is like saying arsenic isnt as bad as cyanide.
The situation you describe is nothing like this. In your case
vapour burns as soon as it finds an oxidizer, mixing is not
possible. Shut-offs would function automatically and limit the
amount of fuel. There will be no big bang, although there would
be one hell of a whoosh.
You are assuming no coincident or consequential damage occurs, this
is a POOR assumption. What structures are being weakened
by that flame and what happens when they fail.
No an awfull lot. That's what the controlls are about.
Controls dont stop steel losing its structural strength
in a fire
No, they limit the duration and intensity of the fire.
Maybe, maybe not.
BTW, I'm assuming the builldozer doesn't get far into the plant.
It's not all that easy to do here.
Bull**** Peter, all that protects most plant are earth bunds and
chain link wire fences
Not bull****, as I explained above.
Quote "The gate is no real barrier"
It is such risks that are rarely analysed and often
provide the nasty shock when an incident occurs
One of the worst industrial Bleve's happened on a
french plant where a small fire started at a faulty valve.
Trouble is the flame impinged on a LPG storage sphere
BANG
You've still not dealt with the basic question. Which is whether
there was a chemical plant near the incident that was so grossly
mis-constructed and mis-managed as to be vulnerable to such an
attack.
I responded to a claim that it couldnt happen - IT CAN
I think you might have misread the claim or I might have mistyped
it.
The furnace scenario you chose shows little understanding of
explosions or chemical plants.
Really , care to dispute the facts ?
I did. You snipped it without comment.
I'll take that as a no
The plant you chose is ludicrously
different from existing types.
Peter I have worked in this industry since I was 16, I have
seen 2 major Petrochemical incidents and investigated many
others. One of those included a major fire and explosion
caused by a mobile crane striking a pipe bridge.
Go find your Granny and teach her to suck eggs.
You too. Care to try to tell me that F was like a modern plant?
It had cyclohexane lines, so do modern plants.
I've already dealt with that at some length.
Evasion doesnt count
Keith
Old June 8th 04, 03:01 AM
Peter Skelton
On Mon, 7 Jun 2004 23:57:31 +0100, "Keith Willshaw"
No we cant
magnitude.
??????? There was? this is a sequence that did *not* happen. You
might argue that there would have been, but what you typed is
nonsense.
See above
A leak of that
valves.
We're talking here about the effect of valves that were not in
the system. Here's the important text, copied from above:
fence.
I did not say secret. Go back and look.
Sure it did. As you refuse to answer the question I am free to
assume that you've never seen it. (Sauce for the goose. . .)
better.)
I can't see why. So far I've not been corrected on anything
except for a major brain fart I long since admitted.
The causes of the
Have you seen a North American plant?
Certainly, read on.
Yes but there's clearly time to deal with this sort of incursion
which is the point. An air-strike is clearly not called for.
get the explosion.
They just don't run lines (at least of hazardous stuff) that far
inside a plant without valving these days. There was a lot of
retrofitting in the eighties, I doubt many plants still need it.
So you admit cyane and cyclohexane are the same. Now tell us how
gasoline (or cyane) is likely to oxidize externally.
You shudda kept your trap shut.
in a fire
Maybe, maybe not.
That's life. Would you call an air strike in a populated area on
the chance they won'r function?
Quote "Certainly, read on." I made the point about no real
barrier myself and clearly. That's because barrier isn't the
issue, distance/time is.
BANG
attack.
it.
Given that what I said is an explicit "yes", I think you're
erring.
DOH
Evasion ot what?
Peter Skelton
Old June 8th 04, 03:04 AM
Paul J. Adam
In message , Keith Willshaw
writes
In the case of the Flixborough accident in the UK a pressure
vessel was bypassed by the maintenance dept using pipes and bellows units.
Unfortunately the bypass was not properly anchored
and a slug of liquid caused the bypass to tear loose.
How do you prevent this with an air strike?
(FWIW I was too young to remember, but I lived on the edge of S****horpe
at the time: I'm told I was playing outside when my father heard the
explosion, heard the windows rattle, and ran out to see a mushroom cloud
rising. It left quite a mark on him mentally, as he gladly admits, but
did him no physical harm whatsoever)
He thinks too much: such men are dangerous.
Julius Caesar I:2
Paul J. Adam MainBoxatjrwlynch[dot]demon{dot}co(.)uk
Old June 8th 04, 04:43 AM
Nicholas Smid
"Tamas Feher" wrote in message
A home-made armored Caterpillar turns Colorado into Palestine?
Palestine has dead. The authorities ended this one without public
deaths.
Pure chance. They had no absolutely contact with the madman whatsoever .
If he decided to target a chemical plant and cause a Bhopal-scale
industrial disaster, the cops simply couldn't stop him. In the end an
entire county could get killed.
Even if it was possible at a few MPH it will take a long time for an
armoured Bulldozer to get to the plant. Well the cops might well let you
drive around a low rise part of town they have evacuated untill you brake
down, get bored or cap yourself if you are heading for a major chem plant
they will stop you. And no need to call in air strikes, a cop in a truck
crashing into the rear idler/drive sproket will stop any Bulldozer just
fine. Failing that a few petrol bombs will do the job at no risk to a cop.
Old June 8th 04, 05:44 AM
Kevin Brooks
On Mon, 7 Jun 2004 14:59:36 -0400, "Kevin Brooks"
On Mon, 7 Jun 2004 17:03:49 +0100, "Keith Willshaw"
snip
Go and look at the report on what happened at
Flixborough
I have, in detail, often, with access to a lot that isn't
generally available.
Bingo. Another claim of access to information not available to the rest
of
us--to go along with prior claims of attending sensitive briefings on
what
US personnel were doing with the contras in Nicaragua, and battle update
briefings with a command that had troops engaged in Afghanistan? And you
wonder why more and more folks don't believe you?
I expalined quite directly why I had deeper knowledge than
generally available. Anybody who worked at Maitland or the Texas
plant (Victoria?) had the same. As you snipped that, I conclude
you're up to your old bull again, removing context so that you
can invent some. You've recently proven yourself grossly
dishonest three times, isn't that enough?
No, Keith has demonstrated quite amply that you are clueless regarding the
incident at hand, not to mention of questionable veracity regarding the
subject in general, despite your, as he put it "sekret" information...
Sounds like just another example of your trying to pad your background a bit
too much, and as I noted, it ain't the first time you have been caught out
like this.
snip
fence.
Gee, with all that access to information, you did not realize the true
extent of offsite damage and injury, as we can see from Keith's response
below...amazing, huh?
I certainly had a senior moment there. Kieth handled it nicely.
Do you have anything to contribute?
Yeah. Keith did indeed "handle it nicely"; he made you out to be full of
bovine fecal materiel in spite of all that "sekret" stuff you have lying
about and you apparently haven't caught on to it as of yet.
Brooks
Peter Skelton
Old June 8th 04, 09:19 AM
Keith Willshaw
magnitude.
nonsense.
From the report
"Approximately 50 tons of cyclohexane was released, mixed with air, and
exploded"
See above
I repeat from the report
exploded"
Are you going to turn into Tarver now ?
Continually denying that a large explosion occurred
is not smart given the incontrovertible evidence that
it did.
Keith
Keith Willshaw
magnitude.
nonsense.
From the report
exploded"
See above
exploded"
it did.
Keith
Keith Willshaw
"Paul J. Adam" wrote in message
news
writes
units.
You dont and I have never suggested otherwise
Keith
  #29
Old June 8th 04, 11:24 AM
Peter Skelton
On Tue, 8 Jun 2004 00:44:39 -0400, "Kevin Brooks"
snip
Flixborough
of
what
like this.
I'm not going to argue about Kieth with you. You've been caught
yourself more than once recently, as I said. As usual, you have
nothing to contribute. I have two choices, switch things back to
one of your idiot statements, like the bit about artillery
hitting without knowing where the target is, or ignoring you.
I'll take the second.
Peter Skelton
  #30
Old June 8th 04, 12:54 PM
Disagree with them? ROFLOL if you call sending people to blow up busses
and all that are in them disagreements then you need to get to some anger
management classes fast!
"I have seen the worst that man can do.and I can still laugh loudly"
R.J. Goldman
http://www.usidfvets.com
and
http://www.stopfcc.com
"Nicholas Smid" wrote in message
Posse Comitatus Act and such
..do not affect the ANG (Air National Guard), of course. You didn't read
the very post you replied to!
Well given the common side effects of Israils use of air to serface
missiles, for terminating people who dare to disagree with them, sending
in
the ANG to blow **** up might well kill more people than letting the idiot
drive around for a while. And given that if the missile so much as musses
a
bystanders hair the county sheriff gets sued for his liver and lungs you
can
see how they might be a bit reluctant to let the ANG drop bombs all over
their town.
