Bulldozing US Homeland Defence.
Old June 8th 04, 03:43 PM
Kevin Brooks
"Peter Skelton" wrote in message
On Tue, 8 Jun 2004 14:50:02 +0100, "Keith Willshaw"
On Tue, 8 Jun 2004 13:15:39 +0100, "Keith Willshaw"
On Tue, 8 Jun 2004 09:19:06 +0100, "Keith Willshaw"
Keithe, you snipped the relevant passage abovve, and snipped the
spot where I repeated it below in explanation. That is bloody
well not honest. Are you Brooks or Fred?
I responded to your claim that no such explosion
occurred with an excerpt from the report
No, you did not. You did exactly what I claimed you did. Go on
back and look.
No answer?
Odd how you yourself managed to snip Keith's bit about (the part you snipped
follows):
That's long since been discredited. The total loss form the
process including the fire was 50 tonnes. You should know this.
Cite please - you keep claiming you have
some special knowledge of this event beyond
that of the various reports in the literature.
I suggest you present it.
Meanwhile I suggest you read the report published
in the journal of Hazardous Materials in 2000
http://hugin.aue.auc.dk/publ/hoiset2000.pdf
(Qutes from cited document supporting keith's claim removed for brevity)
What, no response?
And you are trying to hound *him* for *allegedly* snipping your poppycock
from the discourse? LOL!
Brooks
snip
  #42
Old June 8th 04, 05:16 PM
Kevin Brooks
On Tue, 8 Jun 2004 10:43:05 -0400, "Kevin Brooks"
back and look.
No answer?
snipped
follows):
I marked the snip too. I treat pelople the way they treat me.
Keith has been indulging in inconvenient snips, why shouldn't I?
Because in Keith's case they are justified, and in your's they are just
another typical attempt to run away from facts that prove your buffoonery
to be exactly that? He has proven quite conclusively that you are talking
through your hat (as usual) about this subject, and has offered numerous
sources to back up his assertions--you OTOH puff up and refer to "sekret"
resources that don't exist. Yep, looks like Keith has also pegged you for
what you are--there appears to be a growing list of folks in that category,
if you have not noticed.
Brooks
Peter Skelton
  #43
Old June 8th 04, 07:40 PM
Keith Willshaw
On Tue, 8 Jun 2004 15:30:18 +0100, "Keith Willshaw"
I did not say inaccurately, I said selectively.
There is nothing wrong per se with using a bellows
provided the system is correctly constrained.
This is not a sensible contention. A bellows is inheritly less
robust than other options. You contention here is that a
difficult solution, well implemented is the same thing as a
robust system well implemented. I don't buy it.
Tough - bellow system are widely used to absorb thermal
movements when there is inadequate space for alternate
options such as an expansion loop.
Correctly implemented such system comply with design
codes in place in the industry. Indeed in the type
of installation concerned, the bypass being between
2 reactors more or less in line its hard to see what
other solution was possible.
It was
the lack of such constraint that caused the failure
as the quote from the report accurately showed.
Note further that far from being single sourced
I have provided references to several other studies.
On this point?
Yes, all the sources posted refer to the 'squirming'
of the pipe.
You on the other hand have claimed unspecified
privileged information.
This is not exactly a compelling argument.
Your argument rerduces to absurdity very quickly. Anybody with
any experience at all will understand how material like that you
quoted can get into a report. Up to 2002 (?) there were still
attempts to get this thing reopened.
Sure , Trevor Kletz for example has always maintained that
there was insufficient focus on the excessive plant inventory
of 400 tons of cyclohexane and others have claimed the
initial failure was of just one of the 2 bellows units but the
fact that the piping bypass was badly designed and implemented
has not been challenged.
Your failure to provide the requested cite is noted.
D. doesn't use
bellows. His suggestion that the line fence is important compared
to distance is ludicrous, as is his suggestion that Cyane would
probably oxidize in contact with air. I doubt any chamical
engineer would not be aware that cyane and cyclohexane are the
same thing. I could continue, but that's enough on this sequence/
If you believe cyclohexane wont oxidise how do you explain
the fact that it did do so ? (hint the process is commonly called
burning).
Oxidize is your term, I did you te courtesy of using it. Cyane,
as you certainly should know, does not burn spontaneously at 150
C). It requires an ignition source. (The autoignition temperature
is 250 celcius)
I am aware of that , an ignition source for such a large release
is usually available, as it was in this case.
Sure but that is not what you claimed.
My claim was that Cyclohexane would probably oxidise
when released into the air, the risk of that happening
is described in the literature as high.
No. it is not. The literature describes the risk of ignition when
reaching a source of uingnition as high.
In fact it clearly states no flame is needed
The NFPA rating is 3 = SEVE Can be ignited at all temperatures
A source is needed, release is not sufficient.
The European Safety Database states
Cyclohexane is very flammable and may be ignited by contact with a hot
surface - a naked flame is not necessary.
Certainly.
As you accurately pointed out it has an autognition temperature
of only 260 C meaning devices as varied as a vehicle exhaust
or steam pipe can initiate combustion
Yes. We used 250# steam in the Cyane area (rather than 460)
partly for this reason. (Incidentally, we used to believe that
cyane was not quite as dangerous as gasoline. When I looked the
autoignition table up, gasoline was about 20 C higher than cyane.
Live & learn.)
In other words no flame is required
Probably oxidizing in air
does not bring fire on contact with an ignition source to mind.
It does to anyone who understands what it means, let me
give you a nice definition from one of my chemistry
textbooks
burning - A rapid oxidation reaction between a fuel and oxygen that
produces
heat
People who know what it means should not be so imprecise. Burning
is oxidation, oxidation is not necessarily burning. Your
definition proves you incorrect. (I have a lot of non-burning
oxidation sitting in my son's driveway.)
The meaning was clear.
I'm being a bit bitchy on this because, in your furnace example,
autoignition on excape to atmosphere would be inevitable,
regardless of an ignition source.
This was another example of hazards that may occur.
Keith
