Measuring the effectiveness of a sandblaster?
Old June 12th 09, 09:56 PM posted to rec.aviation.homebuilt
Michael Horowitz
Default Measuring the effectiveness of a sandblaster?
I know the compressor requirements are stated when considering a
sandblaster, but is there anyway to measure the effectiveness e.g. is
my blaster taking off paint as quickly as someone elses?
As an example, I can take off an 1/8" strip of paint at about
1"/second, but have no idea what should be happening - Mike
Old June 12th 09, 10:45 PM posted to rec.aviation.homebuilt
Anyolmouse
"Michael Horowitz" wrote in message
To take a lot off in one pass you have to have a industrial capacity
compressor and nozzle. 100 to 115psi @ 5 to 7cfm doesn't give you much
except for cleaning small parts. A water separator is a must. A
commercial shop I use shuts down when the humidity is high. They use an
old Military surplus compressor that puts out close to 100cfm @ 150psi
or there-a-bouts. FWIW yours is doing about what my old Sears
compressor/blaster used to do.
But a Constitution of Government once changed from Freedom, can never be
restored. Liberty, once lost, is lost forever.
John Adams, letter to Abigail Adams, July 17, 1775
Anyolmouse
Old June 13th 09, 01:30 AM posted to rec.aviation.homebuilt
Morgans[_2_]
WoW! I can't even comprehend a compressor that big!
What is the power source; IC engine, or electric, and do you know how big the
power source is, in either HP or amps? That would help me try to put it into
size.
Old June 13th 09, 02:42 AM posted to rec.aviation.homebuilt
Anyolmouse
"Morgans" wrote in message
much
an
150psi
big the
it into
| size.
| Jim in NC
The compressor is diesel powered and is about the size of my Safari van,
maybe a little bigger. The sand hopper is roughly a 10 ft square funnel
at the top that tapers down to an outlet at the bottom.
The guy that operates it has a helmet with a face plate that has a
leather/canvas breastplate and apron. The delivery hose is about the
size of a fire hose. Filtered air is fed to his helmet to make sure he
has good air to breathe.
They sand blasted a friends old VW beetle in about a half hour. I think
almost half of that was prep time.
"We have no government armed with power capable of contending with human
passions unbridled by morality and religion. Avarice, ambition, revenge,
or gallantry, would break the strongest cords of our Constitution as a
whale goes through a net. Our Constitution was made only for a moral and
religious people. It is wholly inadequate to the government of any
other." --John Adams, October 11, 1798
Anyolmouse
Old June 13th 09, 05:58 AM posted to rec.aviation.homebuilt
Bob
On Jun 12, 4:30*pm, "Morgans" wrote:
*WoW! *I can't even comprehend a compressor that big!
power source is, in either HP or amps? *That would help me try to put it into
size.
Dear Jim,
A modified VW engine makes a pretty good media blaster in the medium-
size range. This is a 96cid engine that is modified so that two
barrels are constantly pumping whilst the other two serve as the power
source (ie, about 15hp). Using a VW bug body as an example, it will
usually take from six to eight hours to strip one of paint, tar, etc.
Tthe really big units are found at dry docks, for treatment of
concrete piers and other heavily encrusted objects.
-R.S.Hoover
-(USN Retired)
Old June 13th 09, 06:21 AM posted to rec.aviation.homebuilt
Dan[_12_]
size.
Dear Jim,
-R.S.Hoover
-(USN Retired)
The VW engine idea sounds interesting. Any suggestions where to find
plans? I don't think Id build one, but it should be an interesting read.
I would imagine such Navy machines would be a tad noisy. I have
never had the pleasure of hearing a rivet gun used in building large sea
going vessels. I have the feeling it also would be a bit loud.
Dan, U.S. Air Force, retired
Old June 13th 09, 07:01 AM posted to rec.aviation.homebuilt
Tim[_8_]
"Dan" wrote in message
-R.S.Hoover
-(USN Retired)
I would imagine such Navy machines would be a tad noisy. I have never
had the pleasure of hearing a rivet gun used in building large sea going
You can do the same with the old 289/302 Ford engines. I rented a jack
hammer from a local rental supply company many years ago, that was a
tankless compressor built on a trailer with nothing more than a 302 Ford
with one stock head, and one compressor head.
Old June 13th 09, 07:37 AM posted to rec.aviation.homebuilt
[email protected][_2_]
On Jun 12, 10:21*pm, Dan wrote:
* * The VW engine idea sounds interesting. Any suggestions where to find
http://dunnrightinc.com/
Great use for those VW parts that really shouldn't be put back on the
road much less in the air..........................
Leon McAtee
Old June 13th 09, 02:13 PM posted to rec.aviation.homebuilt
routund
size.
Dear Jim,
-R.S.Hoover
-(USN Retired)
Here is an exchange from several years ago hear on RAH.
"Bruce A. Frank" wrote:
I helped build a Chevy 327 into a compressor many years ago. We kept it
simple and crude. Every other cylinder in the firing sequence was made
into a pumping cylinder. The intake manifold runners to each compressor
cylinder was plugged with a chunk of wood and JB Weld epoxy to prevent
fuel mixture from flowing there. A hole was drilled in each compressor
cylinder runner between the epoxied plug and the intake valve. those
four holes were piped together to draw air from an air cleaner element.
The rocker arms on each of the compressor cylinders were removed and a
hardware store light spring installed in place of the normal intake
valve spring. This allowed the intake valve to open every time the
piston headed down, rather than just on the "intake cycle" of the
cylinder. A check valve replaced the spark plugs so every up stroke of
the piston compressed air. The Chevy 327 ran like a top and produced
enough air at 4000 rpm to power a small jack hammer. It seems we
calculated 200+ cfm at 100 psi. Intake and exhaust were muffled so it
ran very quietly.
Bruce A. Frank, Editor "Ford 3.8/4.2L Engine and V-6 STOL
BAFRANK(at)worldnet.att.net Homebuilt Aircraft Newsletter"
| Publishing interesting material|
| on all aspects of alternative |
| engines and homebuilt aircraft.|
\(-o-)/ AIRCRAFT PROJECTS CO.
\___/ Manufacturing parts & pieces
/ \ for homebuilt aircraft,
0 0 TIG welding
While trying to find the time to finish mine.
Tony P wrote:
HI Bruce.
So YOU'RE the guy who built that one I saw! That explains it. I even
think it was an SBC engine.
Sounds pretty similar to what I saw, but somehow I think the thing
plugged along at idle most of the time and just accelerated as needed.
Maybe it vented off surplus?
Also had a neat loping sound. The powered cylinders clearly had no
difficulty keeping up, probably ridiculously overpowered.
Tony Pucillo
I speak only for myself unless otherwise stated.
One personality is enough, thank you.
"Irony better befits a gentleman than buffoonery;
the ironical man jokes to amuse himself,
the buffoon to amuse other people." (Aristotle, 'Rhetoric')
From empty tank to full, from start up to pop off, was about 20
seconds (50 gal tank). While we were using it it ran at about 1000 rpm.
With the jack hammer we turned it up to 4000 rpm and with the JH running
full bore the pop off valve was always blowing. When we put the
commercially mfg. controller on it the rpm hardly ever got above 500 (the
tank would fully pressureize before the engine reached its controller
set 2500 rpm). Last I heard it was still running just fine (30 years
now! and the engine had 90,000 miles when we converted it with no
overhaul) Ours had a sort of pocketta-pocketta sound, much like an
antique 4 cylinder engine.
An interesting side note, the air out of that engine was as oil free and
clean as if it had been charcoal filtered. There was no exhaust gas
blow-by smell or gasoline smell. A friend in PA built the same thing for
a sandblast outfit. It'll pump through 600 lbs of sand at 130 psi in
about 15 minutes.
0 0 TIG welding
Old June 13th 09, 06:15 PM posted to rec.aviation.homebuilt
Bob
There used to be a company named 'Dunn-Rite' (sp?) which supplied a
conversion kit, but the idea dates from the 1930's and the conversion
of anu I-4 or V-8 engine for that purpose. The VW is especially easy
to convert and the DIY method has been explained several times on VW-
specific Groups. Basically, you simply select a pair of sequenctially-
firing cylinders as your power pair (ie, 1-3 or 2-4) and use the other
pair as your 'pumping' cylinders. The spark plugs of the pumping
cylinders are modified to act as ball-type check valves while the
exhaust stack is modified to become an input valve by the use of a
flapper valve made of light-gauge spring steel. The push-rods &
rocker arms of the pumping pair are modified so as to always be
open.
* * I would imagine such Navy machines would be a ta
d noisy. I have
Actually, they sound remarkably like welding machines :-)
(I don't think the Navy hasn't used riveted hulls since the 1920's)
-Bob
Clarke sandblaster gun - moisture? Michael Horowitz Home Built 16 May 24th 09 04:38 PM
TRMM - Tropical Rainfall Measuring Mission sen Piloting 0 October 31st 07 06:13 AM
measuring flap angles for rigging [email protected] Home Built 12 April 28th 06 03:46 PM
measuring arm distances Heino & Deanne Weisberg Home Built 1 October 21st 05 06:49 PM
Metric measuring tool source? DL152279546231 Home Built 12 April 29th 04 03:13 AM
