Hi,
I am looking forward to selling the Trig TT21 transponder in the USA once they receive approval from the FAA (or whomever they need approvals from). However, I just talked to someone who told me that his avionics person said he could install one in his experimental aircraft - now - even though the unit is not approved for use in the USA. Can that be true? I don't think it is, but I'm not certain. I would think it would be illegal to use it in the USA until it receives US approvals. Best Regards, Paul Remde Cumulus Soaring, Inc. |
a transponder has to be approved before it can get involved in the US ATC
system....otherwise we'd be using home made toys to mingel with airliners and fighter jets...the controllers wouldn't appreciate this....but lawyers might tim "Paul Remde" wrote in message ... Hi, I am looking forward to selling the Trig TT21 transponder in the USA once they receive approval from the FAA (or whomever they need approvals from). However, I just talked to someone who told me that his avionics person said he could install one in his experimental aircraft - now - even though the unit is not approved for use in the USA. Can that be true? I don't think it is, but I'm not certain. I would think it would be illegal to use it in the USA until it receives US approvals. Best Regards, Paul Remde Cumulus Soaring, Inc. |
On Jul 2, 4:07*pm, "Tim Mara" wrote:
a transponder has to be approved before it can get involved in the US ATC system....otherwise we'd be using home made toys to mingel with airliners and fighter jets...the controllers wouldn't appreciate this....but lawyers might tim "Paul Remde" wrote in message ... Hi, I am looking forward to selling the Trig TT21 transponder in the USA once they receive approval from the FAA (or whomever they need approvals from). However, I just talked to someone who told me that his avionics person said he could install one in his experimental aircraft - now - even though the unit is not approved for use in the USA. *Can that be true? * I don't think it is, but I'm not certain. *I would think it would be illegal to use it in the USA until it receives US approvals. Best Regards, Paul Remde Cumulus Soaring, Inc. This may be a "meets requirements of TSO..." situation. And if so one gate to this is finding an approved technician who will sign off on the required tests. See FAR 93.413 (c) 1. As an owner of an experimental glider you do not get to sign off on those yourself. So personally I would start by explain the situation and ask a local installer/avionics guy if he can/is willing to do this. Darryl Darryl |
On Jul 2, 4:27*pm, Darryl Ramm wrote:
On Jul 2, 4:07*pm, "Tim Mara" wrote: a transponder has to be approved before it can get involved in the US ATC system....otherwise we'd be using home made toys to mingel with airliners and fighter jets...the controllers wouldn't appreciate this....but lawyers might tim "Paul Remde" wrote in message ... Hi, I am looking forward to selling the Trig TT21 transponder in the USA once they receive approval from the FAA (or whomever they need approvals from). However, I just talked to someone who told me that his avionics person said he could install one in his experimental aircraft - now - even though the unit is not approved for use in the USA. *Can that be true? * I don't think it is, but I'm not certain. *I would think it would be illegal to use it in the USA until it receives US approvals. Best Regards, Paul Remde Cumulus Soaring, Inc. This may be a "meets requirements of TSO..." situation. And if so one gate to this is *finding an approved technician who will sign off on the required tests. See FAR 93.413 (c) 1. As an owner of an experimental glider you do not get to sign off on those yourself. So personally I would start by explain the situation and ask a local installer/avionics guy if he can/is willing to do this. Darryl Darryl BTW I forgot, the "meets requirements" part is in FAR 91.215 The main relevant TSO is C112 (Mode-S) which traces back to RTCA/ DO-181 standards. The European ETSO 2C112b traces back to EUROCAE ED-73B stabndards. I might have the latest subversions of the standards wrong. There can be subtle differences between EUROCAE and RTCA compliance so you can just assume they are exactly the same. The question again still is would a technician doing the post-install tests be willing to sign off on a transponder that "meets requirements of TSO C112" and how would they determine that? I am not defending this or suggesting trying to do it. Just clarifying what I think the situation is. If somebody disagrees please mention the relevant FARs. I'd still love to get to play with a Trig TT21. Darryl |
Paul,
It is legal to install anything in an experiential. However with transponders they must meet the TSO requirements if they are to be turned on. Doesn’t matter what type of aircraft. TSO required for all aircraft and all airspce. Just wish the certification would get done on the Trig 21. Mark Mahan 2K § 91.215 ATC transponder and altitude reporting equipment and use. (a) All airspace: U.S.-registered civil aircraft. For operations not conducted under part 121 or 135 of this chapter, ATC transponder equipment installed must meet the performance and environmental requirements of any class of TSO-C74b (Mode A) or any class of TSO- C74c (Mode A with altitude reporting capability) as appropriate, or the appropriate class of TSO-C112 (Mode S). On Jul 2, 4:07*pm, "Tim Mara" wrote: a transponder has to be approved before it can get involved in the US ATC system....otherwise we'd be using home made toys to mingel with airliners and fighter jets...the controllers wouldn't appreciate this....but lawyers might tim "Paul Remde" wrote in message ... Hi, I am looking forward to selling the Trig TT21 transponder in the USA once they receive approval from the FAA (or whomever they need approvals from). However, I just talked to someone who told me that his avionics person said he could install one in his experimental aircraft - now - even though the unit is not approved for use in the USA. *Can that be true? * I don't think it is, but I'm not certain. *I would think it would be illegal to use it in the USA until it receives US approvals. Best Regards, Paul Remde Cumulus Soaring, Inc. This may be a "meets requirements of TSO..." situation. And if so one gate to this is *finding an approved technician who will sign off on the required tests. See FAR 93.413 (c) 1. As an owner of an experimental glider you do not get to sign off on those yourself. So personally I would start by explain the situation and ask a local installer/avionics guy if he can/is willing to do this. Darryl Darryl BTW I forgot, the "meets requirements" part is in FAR 91.215 The main relevant TSO is C112 (Mode-S) which traces back to RTCA/ DO-181 standards. The European ETSO 2C112b traces back to EUROCAE ED-73B stabndards. I might have the latest subversions of the standards wrong. There can be subtle differences between EUROCAE and RTCA compliance so you can just assume they are exactly the same. The question again still is would a technician doing the post-install tests be willing to sign off on a transponder that "meets requirements of TSO C112" and how would they determine that? I am not defending this or suggesting trying to do it. Just clarifying what I think the situation is. If somebody disagrees please mention the relevant FARs. I'd still love to get to play with a Trig TT21. Darryl- Hide quoted text - - Show quoted text - |
On Jul 4, 2:10*pm, Janus2k wrote:
Paul, It is legal to install anything in an experiential. However with transponders they must meet the TSO requirements if they are to be turned on. Doesn’t matter what type of aircraft. TSO required for all aircraft and all airspce. Just wish the certification would get done on the Trig 21. Mark Mahan 2K § 91.215 * ATC transponder and altitude reporting equipment and use. (a) * * All airspace: U.S.-registered civil aircraft. For operations not conducted under part 121 or 135 of this chapter, ATC transponder equipment installed must meet the performance and environmental requirements of any class of TSO-C74b (Mode A) or any class of TSO- C74c (Mode A with altitude reporting capability) as appropriate, or the appropriate class of TSO-C112 (Mode S). On Jul 2, 4:07*pm, "Tim Mara" wrote: a transponder has to be approved before it can get involved in the US ATC system....otherwise we'd be using home made toys to mingel with airliners and fighter jets...the controllers wouldn't appreciate this....but lawyers might tim "Paul Remde" wrote in message ... Hi, I am looking forward to selling the Trig TT21 transponder in the USA once they receive approval from the FAA (or whomever they need approvals from). However, I just talked to someone who told me that his avionics person said he could install one in his experimental aircraft - now - even though the unit is not approved for use in the USA. *Can that be true? * I don't think it is, but I'm not certain. *I would think it would be illegal to use it in the USA until it receives US approvals. Best Regards, Paul Remde Cumulus Soaring, Inc. This may be a "meets requirements of TSO..." situation. And if so one gate to this is *finding an approved technician who will sign off on the required tests. See FAR 93.413 (c) 1. As an owner of an experimental glider you do not get to sign off on those yourself. So personally I would start by explain the situation and ask a local installer/avionics guy if he can/is willing to do this. Darryl Darryl BTW I forgot, the "meets requirements" part is in FAR 91.215 The main relevant TSO is C112 (Mode-S) which traces back to RTCA/ DO-181 standards. The European ETSO 2C112b traces back to EUROCAE ED-73B stabndards. I might have the latest subversions of the standards wrong. There can be subtle differences between EUROCAE and RTCA compliance so you can just assume they are exactly the same. The question again still is would a technician doing the post-install tests be willing to sign off on a transponder that "meets requirements of TSO C112" and how would they determine that? I am not defending this or suggesting trying to do it. Just clarifying what I think the situation is. If somebody disagrees please mention the relevant FARs. I'd still love to get to play with a Trig TT21. Darryl- Hide quoted text - - Show quoted text - Did you read my post you quoted? The FAR you quoted (the same one I had quoted) says you have to meet the TSO requirement. OK sofar, we all can read and agree on that. Now next step here folks. Hold on tight... Meeting the specs of a TSO is different than being "TSO approved" aka having a manufacturer TSO authorization. I kind of already tried to explain that in this thread. If somebody sees a requirement for TSO approved/manufactured under a TSO authorization please provide the FAR. Darryl |
| Thread Tools | |
| Display Modes | |
| Experimental aircraft and towing | Marc Ramsey | Soaring | 8 | January 28th 17 09:23 AM |
| Trig TT21 Transponder Thoughts? | jcarlyle | Soaring | 16 | June 23rd 09 05:38 PM |
| forgotten trig for climb angle... | xerj | Piloting | 5 | January 29th 07 02:08 PM |
| Financing for Experimental Aircraft | James Keane | Owning | 2 | September 1st 04 03:18 AM |
| Experimental Aircraft Pictures | Jay Honeck | Piloting | 0 | December 5th 03 11:12 PM |
