Light gun work with ATC COMS - Video
Old July 16th 09, 09:59 PM posted to rec.aviation.ifr
Mark Hansen
Default Light gun work with ATC COMS - Video
On 07/16/09 13:48, BeechSundowner wrote:
On Jul 16, 3:46 pm, BeechSundowner wrote:
On Jul 16, 3:41 am, Sam Spade wrote:
So, you are saying I need a clearance to land when NORDO and proceeding
under the provisions of 91.185?
Correct. I am sure you know clearance for an approach is NOT a
clearance to land. I don't see anything in the above that says I am
allowed to land (hence the light signals).
No light signals, no clearance to land. I better be squawking 7700 if
I plan to land without a LANDING clearance. The above pertains to
enroute and approach clearances.
I beg to differ with you. When operating under 91.185 you don't have an
approach clearance any more than you have a landing clearance.
Lets go this route. The system has built in a communication way for
getting a clearance to land via light gun?
What makes you think that 91.185 would trump the clearance to land
procedures?
I realize this is more theoretical talk as in the real world, ATC will
move traffic to get us in safely and it's a matter of "semantics" but
in the theory world, what you gave as reference pertains to enroute
operations (center and approaches), not tower operations (landing)
I hit send too fast! Landing is a VFR operation, not a IFR
operation. You would be visual from DH to wheels down so I really
don't think 91.185 applies.
Oh good grief! If you break out of the clouds at DA and proceed to
land visually, do you really believe you're flying under VFR?
Why don't you think 91.185 applies once you break out of the clouds?
Did you cancel your IFR clearance at that point? If not, aren't you
still flying by IFR?
Mark Hansen, PP-ASEL, Instrument Airplane, USUA Ultralight Pilot
Cal Aggie Flying Farmers
Sacramento, CA
Old July 16th 09, 10:12 PM posted to rec.aviation.ifr
A Lieberman[_3_]
Actually it's a visual, I didn't mean VFR.
My point being landing is not an instrument procedure and has it's own
set of rules.
I don't think light guns apply to IFR procedures, but we all have to
land, and that landing clearance rules are distinctly different then
the approach clearance rules given in 91.185. Otherwise, I would
imagine the 91.185 would have light gun references in there?
Old July 16th 09, 10:38 PM posted to rec.aviation.ifr
Mark Hansen
No. If you break out at DA and continue to land, you're not executing
a visual approach. See the Pilot/Controller glossary for details.
set of rules.
When flying IFR and landing through the use of an IAP, the landing is
certainly part of the procedure.
I'm a little confused as to what you're trying to get here. If you're
on an IFR flight and lose radio and get to your destination, fly
the approach, break out at DA, etc., if you are able to land and
don't because you don't see a light gun signal... well - I won't
finish that sentence :-)
However, I think this whole thread started with a Visual approach and
landing to a towered field with no radio. I think the question was
asked at that time: What has this to do with IFR flight? This is an
IFR group, right?
Sacramento, CA
Old July 16th 09, 11:38 PM posted to rec.aviation.ifr
BeechSundowner
set of rules.
Bear with me Mark. If what you say is true, then why do you get a
clearance to land? Why are you NOTcleared to land on the approach
when you receive your clearance to execute the approach.
In the real world, you land and deal with the paper work afterwards or
that's how I would deal with it:-) But it would appear to me the
landing clearance has absolutely nothing to do with the instrument
approach clearance. See above why.
IFR group, right?
Well, the way I see it, to land you have to be cleared :-) The light
signal does that. The instrument approach is only part of the process
Old July 17th 09, 04:25 PM posted to rec.aviation.ifr
Sam Spade
procedures?
Light guns were built primarily to be used when two-way radios weren't
mandatory for takeoff and landing at an airport with a control tower.
Actually, their genesis was really World War II military operations.
What makes me thing 91.185 would trump light signals? Answer:
1. A landing is the presumed conculsion of a successful instrument approach.
2. Clouds
Old July 17th 09, 04:26 PM posted to rec.aviation.ifr
Sam Spade
procedures?
If landing is a VFR operation than I can't land out of an IAP when the
weather is less than VFR (1,000 and 3 at an airport with an operating ATCT)
Old July 17th 09, 04:30 PM posted to rec.aviation.ifr
Sam Spade
set of rules.
"VMC" is the term you are searching for. VMC does not necessairly mean
I can see the ATCT or that they can see me. And, even if I "break out"
at 400 feet, my priority is alignment with the runway and landing.
And, on some approaches you never do "break out," rather the visual cues
progressively come into view. Have you ever flown an ILS IAP with the
weather reported "zero zero" and the RVR at 2,400 (or becoming more
prevailent, 1800)?
Old July 17th 09, 04:31 PM posted to rec.aviation.ifr
Sam Spade
set of rules.
IFR group, right?
Your way of seeing it doesn't make it a reality.
Old July 17th 09, 05:36 PM posted to rec.aviation.ifr
BeechSundowner
On Jul 17, 10:25*am, Sam Spade wrote:
What makes me thing 91.185 would trump light signals? *Answer:
2. Clouds
Number 2 certainly won't apply. No visual on runway environment, no
landing.
Lets suffice it to say we will have to agree to disagree. I really
think the two clearances do not intertwine and if you land without a
clearance, that's a no no in spite of you getting a clearance for the
approach. 7600 is not a clearance for landing.
Otherwise, on an instrument approach, you wouldn't have to hear those
magic words clear to land. The lights only replace the aural part
"cleared to land". JMHO.
Like I said earlier, in the real world, I would land and deal with any
paper work later.
Old July 17th 09, 05:39 PM posted to rec.aviation.ifr
Mark Hansen
2. Clouds
landing.
Come on Allen. Are you saying that you cannot land if you don't have
the Control Tower in view?
paper work later.
Sacramento, CA
Light gun work with ATC COMS - Video [email protected] Piloting 5 July 15th 09 03:20 AM
Pop up IFR clearance with ATC COMS - Video [email protected] Piloting 0 November 15th 08 05:05 PM
Pop up IFR clearance with ATC COMS - Video A Lieberma[_2_] Owning 0 November 15th 08 05:04 PM
Pop up IFR clearance with ATC COMS - Video [email protected] Instrument Flight Rules 0 November 15th 08 05:04 PM
