I’m trying to understand Figures 4.45, and have a question about a technique shown in 4.44. First, 4.44 – here they show fabricating an inner tube by cutting, reforming and welding outer tube material. Is there any reason this can’t be done with round tubing if one can’t locate the correct size inner tubing for an internal splice? Second, 4.45 – are they showing cutting slots in the outer tubing? In the lower drawing what is that streamline shape illustrating? Thanks for your time - Mike |
On Wed, 5 Aug 2009 05:19:21 -0700 (PDT), mhorowit
wrote: I’m trying to understand Figures 4.45, and have a question about a technique shown in 4.44. First, 4.44 – here they show fabricating an inner tube by cutting, reforming and welding outer tube material. Is there any reason this can’t be done with round tubing if one can’t locate the correct size inner tubing for an internal splice? my answer. yes, the reason is that the round tubing isnt used here is that it isnt stiff enough and would provide only line contact. you may as well just use a piece of flat for all that achieves. the use of a streamline tube inside a streamline tube provides full support for the damaged wall and it also provides the necessary wall contact for the rosette welds. streamline tube might be about $35 a foot but I'm sure aircraft spruce can sell you a foot or so. if you look carefully you will notice that the repair is made in the same size streamline tube as what you are trying to repair. you cut it at 80% of the chord, heat it and persuade it into a shape that will slide neatly into the other tube, then weld the back edge up again. Second, 4.45 – are they showing cutting slots in the outer tubing? In the lower drawing what is that streamline shape illustrating? the top view is from the wide side, the lower view is from the narrow side and all it really shows is the appearance of the end of the oblique slice through the tube. the left most illustration at the top is an end on view of the tube showing how the plates protrude through each side. that method of repair uses two plates slotted into the streamline tube. each plate is made slightly wider (not thicker, wider) than the slot it goes into. mike what you are trying to achieve with each of these welds is a repair that will resist the buckling under compression that an undercarriage strut will see. round tube would simply not provide the necessary buckling resistance. I should imagine that there are a few failed undercarriage struts behind those recommendations. Stealth Pilot |
On Aug 5, 9:34*am, Stealth Pilot
wrote: On Wed, 5 Aug 2009 05:19:21 -0700 (PDT), mhorowit wrote: * I’m trying to understand Figures 4.45, and have a question about a technique shown in 4.44. * First, 4.44 – here they show fabricating an inner tube by cutting, reforming and welding outer tube material. Is there any reason this can’t be done with round tubing if one can’t locate the correct size inner tubing for an internal splice? my answer. yes, the reason is that the round tubing isnt used here is that it isnt stiff enough and would provide only line contact. you may as well just use a piece of flat for all that achieves. the use of a streamline tube inside a streamline tube provides full support for the damaged wall and it also provides the necessary wall contact for the rosette welds. streamline tube might be about $35 a foot but I'm sure aircraft spruce can sell you a foot or so. if you look carefully you will notice that the repair is made in the same size streamline tube as what you are trying to repair. you cut it at 80% of the chord, heat it and persuade it into a shape that will slide neatly into the other tube, then weld the back edge up again. * Second, 4.45 – are they showing cutting slots in the outer tubing? In the lower drawing what is that streamline shape illustrating? the top view is from the wide side, the lower view is from the narrow side and all it really shows is the appearance of the end of the oblique slice through the tube. the left most illustration at the top is an end on view of the tube showing how the plates protrude through each side. that method of repair uses two plates slotted into the streamline tube. each plate is made slightly wider (not thicker, wider) than the slot it goes into. mike what you are trying to achieve with each of these welds is a repair that will resist the buckling under compression that an undercarriage strut will see. round tube would simply not provide the necessary buckling resistance. I should imagine that there are a few failed undercarriage struts behind those recommendations. Stealth Pilot Hi Stealth - thanks for the reply. In the first example I apparently wasn't clear - I was generalizing from one example to another. In other words, if you can cut/form/weld using streamlined tubing, is there any reason I can't cut/form/weld for round tubing? - Mike |
On Wed, 5 Aug 2009 08:41:55 -0700 (PDT), Mike
wrote: On Aug 5, 9:34*am, Stealth Pilot wrote: On Wed, 5 Aug 2009 05:19:21 -0700 (PDT), mhorowit wrote: * I’m trying to understand Figures 4.45, and have a question about a technique shown in 4.44. * First, 4.44 – here they show fabricating an inner tube by cutting, reforming and welding outer tube material. Is there any reason this can’t be done with round tubing if one can’t locate the correct size inner tubing for an internal splice? Hi Stealth - thanks for the reply. In the first example I apparently wasn't clear - I was generalizing from one example to another. In other words, if you can cut/form/weld using streamlined tubing, is there any reason I can't cut/form/weld for round tubing? - Mike there no reason at all. it is the wall thickness that matters not how it was formed. just dont hurry the work do it neatly. on my Auster we didnt have round tubing so the repair was formed from flat sheet. heated to red heat 4130 becomes quite plastic and is easily formed. if you ever get to see the back end of a bucker jungman (rudder and fin) you'll see beautifully tapered tubes all formed by taking a slice out of the tube and then beating it down almost conical. beautiful stuff. Stealth Pilot |
| Thread Tools | |
| Display Modes | |
| Help needed understanding turbojets | Hul Tytus | Home Built | 2 | June 21st 09 12:15 AM |
| Help understanding Aspen VOR/DME approach | SimGuy | Instrument Flight Rules | 34 | August 8th 06 09:02 PM |
| Need help understanding KFC-200 operation | Roy Smith | Instrument Flight Rules | 11 | July 1st 06 01:22 AM |
| Hmm. REALLY not understanding circulation | xerj | Piloting | 22 | September 20th 05 12:32 AM |
| Bends, kinks and splices | Michael Horowitz | Home Built | 9 | August 17th 05 03:41 PM |
