AIR-2A Genie on F-104 true or false ?
Old August 20th 04, 02:28 PM
Peter Stickney
(WaltBJ) writes:
That was the problem with the F104A launching an AIR2A Genie. It's
ASG14T1 radar (highly resembling an AI10 AI set from WW2) didn't even
have a computer. It didn't angle track, either - the pilot did that.
It did have range track and an overtake indicating needle but there
was no precision output reading in range. Some more boxes would have
been needed to get a Genie to go off at the right spot; TLAR wouldn't
have hacked it.
Yeah - the same Genie interface issues would have occurred - I can't
see them sticking an MG-13 in an F-104.
One thing I've been wondering - given the way that the ASG-14 worked,
and its presentation, how hard was it to sort out multiple targets in
its field of view? I can see some potential for real problems, there.
BTW the AIM26A Fat Falcon did have a prox fuze; unfortunately it was
determined that chaff would most likely have set it off so we had to
do odd offset attacks to keep the missile out of the chaff trail. Like
the Genie-launchers, our bellies would have been facing the FF when it
went off. Best use I'd heard for the Genie rocket motors was the idea
to screw a CBU24 to its front and use it for flak supression. Would
have beat a ballistic drop all hollow - nice stand-off weapon!
Yeah - If I were in a "Picking on Hughes" mode, I'd say that a nuke
was the only way that Hughes could get a Prox Fuze to work. That is
slightly unkind - Missile prox fuzes are something that still gives
trouble, and designers still throw up their hands on them, One good
example is the Rapier SAM. They couldn't make a prox fuze for the
first generations, so they made the Marketing Decision to call it a
"Hittile", adn claim that it didn't need one. Oddly enough, when the
second generation Rapiers came out, it had a prox fuze, and all the
"Hittile" talk went away. SA-2s and Nikes were all, AFAIK, command
detonated. They didn't have the space to fit the necessary smarts in
the missile, so they left it up to the guidance computer.
I wonder what the guys flying the F-101s thought. Their options were
2 AIM-4s and 2 Genies. That sounds like a choice between Probably
Miss and really upsetting somebody on the ground's day.
Walt BJ ex-Deuce driver
Thanks, Walt, I was hoping you'd pick it up.
Pete Stickney
A strong conviction that something must be done is the parent of many
bad measures. -- Daniel Webster
Old August 21st 04, 02:38 AM
WaltBJ
Octaflugeron? Is that what happened to me on my first T6 solo ride
when I tried my first loop, way ahead of the syllabus? It was going
well until the amount of back stick I was holding disagreed with the
amount of airspeed left and suddenly I'd completed a very abrupt and
uncoordinated immelmann involving about ninety degrees of ehading
change.
BTW multiple targets in the 104A were no problem - if it was chaff the
bogey was up at the front of the parade. If there was more than one
airplane you took them in order. Note that the bird and its weapons
were optimized for stern attack, and it could catch anything flying
back then. It was not a completely IFR interceptor but it was amazing
how well it coped with thin clouds. The missile seekers were
boresighted with the radar so they would growl when they saw enough IR
- all you had to do was boresight the radar on the target - that is,
have it painting a complete circle in range track mode, and the AIM9
seekers were lined up on him. In addition, if the viz was anything at
all, the IR scanner would show a cross and the intersection was where
his tailpipe was. on a multi-jet, in close, you got a vertical strobe
where each engine was, in close. Only 4 on a 52 because it couldn't
resolve the paired exhausts. Using the IR scanner you could shoot a
blacked-out target at night because all you had to do was fly the
pipper onto the intersection of the strobes and with a radar lockon,
check the range (in guns it read out in feet; in missiles, miles) and
shoot. Well thought out, simple, reliable, accurate. Why did we not
clone Kelly Johnson?
Walt BJ
Old August 21st 04, 03:53 AM
Jack G
Walt - any time in the 331st FIS ?
Jack G.
TRUE AMERICAN!! Grantland Military Aviation 5 May 28th 04 05:15 AM
True He-176 Prototype Photo robert arndt Military Aviation 15 April 28th 04 09:59 PM
Former head of cadet discipline says she never saw a 'true rape' Otis Willie Military Aviation 0 September 11th 03 08:37 PM
How low can you go? (old but true) Ron Military Aviation 1 July 30th 03 05:56 AM
