How would you react to a Jabiru 2200 with these characteristics:
- Build in 95 (sn #60) - 125h TT - NEW cylinders & pistons in 2004 (larger fins) - NEW conrods in 2008, including replacement of all seals & gaskets in the low end Such an engine is past the time-based TBO. Is it equivalent (value- wise) to a run-out core?? Or is it closer to a 2004 engine with 125 TT?? |
"Paul Folbrecht" wrote in message
... How would you react to a Jabiru 2200 with these characteristics: - Build in 95 (sn #60) - 125h TT - NEW cylinders & pistons in 2004 (larger fins) - NEW conrods in 2008, including replacement of all seals & gaskets in the low end Such an engine is past the time-based TBO. Is it equivalent (value- wise) to a run-out core?? Or is it closer to a 2004 engine with 125 TT?? I admit to being something of a novice, especially regarding the Jab--even though I have been very impressed with their specs--but I would have VERY serious reservations about that one! Basically, I can not imagine a sensible reason that the connecting rods would ever be newer than the pistons in any internal combustion engine. That leaves me with the impression that thare is something very wrong with the story. If your local swamp is free of alligators, crocodiles and water mocasins; it should be a decent engine for a very small airboat. Otherwise, I would probably just use it as a mock up for cowling dimensions; and weight and balance during construction. Just my $0.02 Peter |
On Apr 23, 7:39*pm, "Peter Dohm" wrote:
"Paul Folbrecht" wrote in message ... How would you react to a Jabiru 2200 with these characteristics: - Build in 95 (sn #60) - 125h TT - NEW cylinders & pistons in 2004 (larger fins) - NEW conrods in 2008, including replacement of all seals & gaskets in the low end Such an engine is past the time-based TBO. Is it equivalent (value- wise) to a run-out core?? Or is it closer to a 2004 engine with 125 TT?? I admit to being something of a novice, especially regarding the Jab--even though I have been very impressed with their specs--but I would have VERY serious reservations about that one! Basically, I can not imagine a sensible reason that the connecting rods would ever be newer than the pistons in any internal combustion engine. That leaves me with the impression that thare is something very wrong with the story. *If your local swamp is free of alligators, crocodiles and water mocasins; it should be a decent engine for a very small airboat. *Otherwise, I would probably just use it as a mock up for cowling dimensions; and weight and balance during construction. Just my $0.02 Peter I should have said - the rods were replaced for a reason - the new ones are better. There was nothing wrong with the engine or the old rods. All of this work was done at Jabiru U.S. headquarters. There is probably really no good answer to my question, I think. Nobody is going to be able to say with any certainty how to value this engine. |
"Paul Folbrecht" wrote in message ... On Apr 23, 7:39 pm, "Peter Dohm" wrote: "Paul Folbrecht" wrote in message ... How would you react to a Jabiru 2200 with these characteristics: - Build in 95 (sn #60) - 125h TT - NEW cylinders & pistons in 2004 (larger fins) - NEW conrods in 2008, including replacement of all seals & gaskets in the low end Such an engine is past the time-based TBO. Is it equivalent (value- wise) to a run-out core?? Or is it closer to a 2004 engine with 125 TT?? I admit to being something of a novice, especially regarding the Jab--even though I have been very impressed with their specs--but I would have VERY serious reservations about that one! Basically, I can not imagine a sensible reason that the connecting rods would ever be newer than the pistons in any internal combustion engine. That leaves me with the impression that thare is something very wrong with the story. If your local swamp is free of alligators, crocodiles and water mocasins; it should be a decent engine for a very small airboat. Otherwise, I would probably just use it as a mock up for cowling dimensions; and weight and balance during construction. Just my $0.02 Peter I should have said - the rods were replaced for a reason - the new ones are better. There was nothing wrong with the engine or the old rods. All of this work was done at Jabiru U.S. headquarters. There is probably really no good answer to my question, I think. Nobody is going to be able to say with any certainty how to value this engine. Well, I'm still not quite sure how connecting rods in a 3200 rpm, carbureted and normally aspirated engine can be enough better to justify the expense; but, if Jabiru US headquarters did the work, then it certainly looks like the engine was healthy and in very nearly rebuilt condition only two years ago. Presuming that I read what you wrote correctly, it would strongly suggest that the engine was recently pretty close to the far end of the spectrum from where I presumed. All the best. Peter |
On Apr 23, 5:44*pm, Paul Folbrecht wrote:
How would you react to a Jabiru 2200 with these characteristics: - Build in 95 (sn #60) - 125h TT - NEW cylinders & pistons in 2004 (larger fins) - NEW conrods in 2008, including replacement of all seals & gaskets in the low end Such an engine is past the time-based TBO. Is it equivalent (value- wise) to a run-out core?? Or is it closer to a 2004 engine with 125 TT?? If the factory signed off on it, then what's the problem? |
| Older Bo's | The Weiss Family | Owning | 13 | July 13th 04 06:34 PM |
| Older airframes | Jim | Naval Aviation | 14 | June 27th 04 09:31 AM |
| Older Pilots and Safety | Bob Johnson | Soaring | 5 | May 21st 04 02:08 AM |
| New law for older airplanes? | Jim B | Owning | 25 | May 13th 04 09:26 PM |
| Older versions of X-plane | Fred the Red Shirt | Simulators | 0 | March 20th 04 10:23 PM |
