It's not complete protection, it just loads the odds a bit more in your
favor. The aircraft is as likely to be broken by a panicked response by the pilot or a botched attempt to recover from an unusual attitude and being at Va will reduce that probability significantly. -- Roger Long "Peter" wrote in message ... I think I understand the reasoning behind Va, the max maneuvering speed, being that the wing will stall (and thus dispose of the loading) before it breaks. This is why Va falls as the weight falls, because at any given IAS a higher weight takes the aircraft closer to stall already. So, how is it possible to have aircraft destruction due to weather, e.g. flying into a strong updraught in a CB, if flying below Va? A DOWNdraught would do it more easily because most aircraft designs have a lower design limit for negative G. Peter. -- Return address is invalid to help stop junk mail. E-mail replies to but remove the X and the Y. Please do NOT copy usenet posts to email - it is NOT necessary. |
"Peter" wrote in message ... I think I understand the reasoning behind Va, the max maneuvering speed, being that the wing will stall (and thus dispose of the loading) before it breaks. This is why Va falls as the weight falls, because at any given IAS a higher weight takes the aircraft closer to stall already. So, how is it possible to have aircraft destruction due to weather, e.g. flying into a strong updraught in a CB, if flying below Va? Flying into an updraught (updraft) in a CB can cause destruction for other reasons that just the consideration of Va. The windshear may put the aircraft into an unusual attitude from which recovery may be impossible before, say, Vne is exceeded. |
Peter wrote:
I think I understand the reasoning behind Va, the max maneuvering speed, being that the wing will stall (and thus dispose of the loading) before it breaks. This is why Va falls as the weight falls, because at any given IAS a higher weight takes the aircraft closer to stall already. So, how is it possible to have aircraft destruction due to weather, e.g. flying into a strong updraught in a CB, if flying below Va? A DOWNdraught would do it more easily because most aircraft designs have a lower design limit for negative G. Find a copy of "FLYING THE BEECH BONANZA", by John C Eckalbar. There is a section in the book expressly dealing with this topic. |
Turbulence is gusts which change the airspeed. I recall reading one account
of a thunderstorm accident where the plane encountered a 80kt vertical gust. In the Sierra Wave Project loads of +16G and -20G were encountered in a rotor cloud at below Va.. I think it should be understood that these are extreme examples i.e. flying into the worst part of the worst thunderstorm at the worst time. A one in a million event. The usual breakup story is loss of control followed by an overspeed were the pilot pulls the wings off in the recovery. Mike MU-2 "Peter" wrote in message ... I think I understand the reasoning behind Va, the max maneuvering speed, being that the wing will stall (and thus dispose of the loading) before it breaks. This is why Va falls as the weight falls, because at any given IAS a higher weight takes the aircraft closer to stall already. So, how is it possible to have aircraft destruction due to weather, e.g. flying into a strong updraught in a CB, if flying below Va? A DOWNdraught would do it more easily because most aircraft designs have a lower design limit for negative G. Peter. -- Return address is invalid to help stop junk mail. E-mail replies to but remove the X and the Y. Please do NOT copy usenet posts to email - it is NOT necessary. |
Mike Rapoport wrote:
Turbulence is gusts which change the airspeed. I recall reading one account of a thunderstorm accident where the plane encountered a 80kt vertical gust. In the Sierra Wave Project loads of +16G and -20G were encountered in a rotor cloud at below Va.. I think it should be understood that these are extreme examples i.e. flying into the worst part of the worst thunderstorm at the worst time. A one in a million event. The usual breakup story is loss of control followed by an overspeed were the pilot pulls the wings off in the recovery. Mike MU-2 "Peter" wrote in message ... I think I understand the reasoning behind Va, the max maneuvering speed, being that the wing will stall (and thus dispose of the loading) before it breaks. This is why Va falls as the weight falls, because at any given IAS a higher weight takes the aircraft closer to stall already. So, how is it possible to have aircraft destruction due to weather, e.g. flying into a strong updraught in a CB, if flying below Va? A DOWNdraught would do it more easily because most aircraft designs have a lower design limit for negative G. Peter. -- Return address is invalid to help stop junk mail. E-mail replies to but remove the X and the Y. Please do NOT copy usenet posts to email - it is NOT necessary. Is it the tail or the wings that get snapped off. Hauling back on the yoke loads up the elevator. The wings are near the center of gravity so they don't get stressed as much. |
In article MwxLc.67$eM2.51@attbi_s51,
"William W. Plummer" wrote: Mike Rapoport wrote: Turbulence is gusts which change the airspeed. I recall reading one account of a thunderstorm accident where the plane encountered a 80kt vertical gust. In the Sierra Wave Project loads of +16G and -20G were encountered in a rotor cloud at below Va.. I think it should be understood that these are extreme examples i.e. flying into the worst part of the worst thunderstorm at the worst time. A one in a million event. The usual breakup story is loss of control followed by an overspeed were the pilot pulls the wings off in the recovery. Mike MU-2 "Peter" wrote in message ... I think I understand the reasoning behind Va, the max maneuvering speed, being that the wing will stall (and thus dispose of the loading) before it breaks. This is why Va falls as the weight falls, because at any given IAS a higher weight takes the aircraft closer to stall already. So, how is it possible to have aircraft destruction due to weather, e.g. flying into a strong updraught in a CB, if flying below Va? A DOWNdraught would do it more easily because most aircraft designs have a lower design limit for negative G. Peter. -- Return address is invalid to help stop junk mail. E-mail replies to but remove the X and the Y. Please do NOT copy usenet posts to email - it is NOT necessary. Is it the tail or the wings that get snapped off. Hauling back on the yoke loads up the elevator. The wings are near the center of gravity so they don't get stressed as much. Sometimes it is aircraft components -- engine mounts, baggage compartments, etc. that fail. |
"William W. Plummer" wrote in message news:MwxLc.67$eM2.51@attbi_s51... Mike Rapoport wrote: Turbulence is gusts which change the airspeed. I recall reading one account of a thunderstorm accident where the plane encountered a 80kt vertical gust. In the Sierra Wave Project loads of +16G and -20G were encountered in a rotor cloud at below Va.. I think it should be understood that these are extreme examples i.e. flying into the worst part of the worst thunderstorm at the worst time. A one in a million event. The usual breakup story is loss of control followed by an overspeed were the pilot pulls the wings off in the recovery. Mike MU-2 "Peter" wrote in message ... I think I understand the reasoning behind Va, the max maneuvering speed, being that the wing will stall (and thus dispose of the loading) before it breaks. This is why Va falls as the weight falls, because at any given IAS a higher weight takes the aircraft closer to stall already. So, how is it possible to have aircraft destruction due to weather, e.g. flying into a strong updraught in a CB, if flying below Va? A DOWNdraught would do it more easily because most aircraft designs have a lower design limit for negative G. Peter. -- Return address is invalid to help stop junk mail. E-mail replies to but remove the X and the Y. Please do NOT copy usenet posts to email - it is NOT necessary. Is it the tail or the wings that get snapped off. Hauling back on the yoke loads up the elevator. The wings are near the center of gravity so they don't get stressed as much. I guess I don't understand what you are trying to say. If you pull back on the yoke, the wing supports the weight of the airplane plus the load on the tail multiplied by the load factor. Mike MU-2 |
"William W. Plummer" wrote in message Is it the tail or the wings that
get snapped off. Hauling back on the yoke loads up the elevator. The wings are near the center of gravity so they don't get stressed as much. It depends on the structure. The T-28 Trojan was used by the South Vietnamese in their conflict for ground attack roles. The pilots were pulling the wings off much too often and the engineers couldn't understand because those wings should support a battleship. It turns out that the horizontal stabilizer was actually the first component to fail. After it failed, the plane would pitch over with enough force to break the wings off. This happens in less than a second. Once the engineers understood the problem and strenghtened the horizontal stabilizer, the problem went away. Other planes break apart in different ways. The T-34 has been in the news quite a bit lately because of wings falling off. It appears that the tail isn't breaking. The cause is attributed to metal fatigue from repeated large stresses. A C-130 water bomber was videotaped as the wings came off. The cause has been determined to be undetected cracks in the bottom wing skins that were hidden by doublers. An airworthiness directive was recently aimed at the Cessna 400 series because of a wing seperation. It turns out that the causal factors of the seperation were damage during building by the manufacturer and repeated overstressing during years of abuse in Alaska. D. |
Capt.Doug wrote:
It depends on the structure. The T-28 Trojan was used by the South Vietnamese in their conflict for ground attack roles. The pilots were pulling the wings off much too often and the engineers couldn't understand because those wings should support a battleship. It turns out that the horizontal stabilizer was actually the first component to fail. After it failed, the plane would pitch over with enough force to break the wings off. This happens in less than a second. Once the engineers understood the problem and strenghtened the horizontal stabilizer, the problem went away. T-28 breaking point occurs at 428 kts. (As related to me by a retired North American engineer many years ago.) |
Capt.Doug wrote:
"William W. Plummer" wrote in message Is it the tail or the wings that get snapped off. Hauling back on the yoke loads up the elevator. The wings are near the center of gravity so they don't get stressed as much. It depends on the structure. The T-28 Trojan was used by the South Vietnamese in their conflict for ground attack roles. The pilots were pulling the wings off much too often and the engineers couldn't understand because those wings should support a battleship. It turns out that the horizontal stabilizer was actually the first component to fail. After it failed, the plane would pitch over with enough force to break the wings off. This happens in less than a second. Once the engineers understood the problem and strenghtened the horizontal stabilizer, the problem went away. Other planes break apart in different ways. The T-34 has been in the news quite a bit lately because of wings falling off. It appears that the tail isn't breaking. The cause is attributed to metal fatigue from repeated large stresses. A C-130 water bomber was videotaped as the wings came off. The cause has been determined to be undetected cracks in the bottom wing skins that were hidden by doublers. An airworthiness directive was recently aimed at the Cessna 400 series because of a wing seperation. It turns out that the causal factors of the seperation were damage during building by the manufacturer and repeated overstressing during years of abuse in Alaska. D. Metal fatigue, cracks and construction defects are not caused by turbulence although turbulence may be the straw that breaks the camel's back when those problems exist. IIRC the Convair Electra was the first plane that metal fatigue was determined to be the cause of its wings coming off. And, it took years. What caused the fatigue? Gyroscopic motion of the wings. |
| Weapons of Mass Destruction | running with scissors | Instrument Flight Rules | 23 | April 24th 04 03:00 PM |
| My First Time In Severe Turbulence (Long) | David B. Cole | Instrument Flight Rules | 6 | March 10th 04 11:21 PM |
| Budgets of Mass Destruction | B2431 | Military Aviation | 4 | February 4th 04 05:38 AM |
| please stop bashing France | Grantland | Military Aviation | 233 | October 29th 03 02:23 AM |
| How much turbulence is too much? | Marty Ross | Instrument Flight Rules | 8 | August 21st 03 06:30 PM |
