Has any one changed the landing and taxi lights on the tr182? I have 100w
28 volt lamps on my 82 tr182 and have temp replaced with 250W......any comments? |
Mark Hudgens wrote: Has any one changed the landing and taxi lights on the tr182? I have 100w 28 volt lamps on my 82 tr182 and have temp replaced with 250W......any comments? This will cause the Landing light circuit breker to blow at the most innoportune time!!! I had this happen to me on our CAP TR182. I was flying a search dog team to Escalante, UT at 3:00am. 1L7 has a black hole approach. (http://www.airnav.com/airport/1L7). The landing lights went off on short final, and I landed using only the runway edge marker lights. Come to find out that some idiot had replaced the specified 100W landing lamp with a 250 Watter. My recollection (but it has been a few years) is that when the breaker tripped it took out both the landing light and taxi light... If you do the math, the current drawn by (250+100)/28 exceeds the 10A rating of the breaker. MikeM Skylane '1mm Pacer '00z |
Mark Hudgens wrote: Has any one changed the landing and taxi lights on the tr182? I have 100w 28 volt lamps on my 82 tr182 and have temp replaced with 250W......any comments? Yep, that's a fire waiting to happen. |
Mark Hudgens wrote:
: Has any one changed the landing and taxi lights on the tr182? I have 100w : 28 volt lamps on my 82 tr182 and have temp replaced with 250W......any : comments? Yeah, don't. It's things like this that the FAA maintenance regulations were set up for. Put in the right bulb and do yourself (and plane) a favor. To use it, you'd need to verify (both through the service manual and visually to ensure no previous wiring modifications) the wire gauge through the airframe is adequate for the larger capacity. Then, change out the breaker for one of adequate capacity. Then, check to make sure the switch can handle the larger current. Then, verify that with everything one you don't exceed the 80% capacity of the alternator. Of course, before you do any of this, you need to do a 337 and get it approved from your friendly, neighborhood FSDO. -Cory -- ************************************************** *********************** * The prime directive of Linux: * * - learn what you don't know, * * - teach what you do. * * (Just my 20 USm$) * ************************************************** *********************** |
| Landing Light Flasher Circuit | ELIPPSE | Home Built | 1 | January 12th 05 07:05 PM |
| Landing light | Hankal | Aviation Marketplace | 0 | July 14th 04 02:23 AM |
| Would a 3 million Candlepower spotlight make a good landing light? | Legrande Harris | Home Built | 6 | June 15th 04 07:32 AM |
| The light bulb | Greasy Rider | Military Aviation | 6 | March 2nd 04 01:07 PM |
| "I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 10th 04 12:35 AM |
