Last night, on a short hop back to home base after an
instrument lesson (read: extended low power ops), engine shuddered and ran very rough just after level-off and power reduction. Run-up and takeoff were normal, and as usual I leaned like heck for taxi and during runup. About 80 degrees with blissfully low humidity, carb ice unlikely esp. in our installation, not very carb ice prone. Ground ran with brutal leaning afterwards and checked all chts/egts on both, r and l mag. r mag ran rougher, with higher EGT on #4 cyl. Suggestions? Going out to clean plugs and make sure all 4 cyl have compression this afternoon, what else to check? I'm hoping for a badly fouled plug, but would that produce high EGT on 1 mag? BTW I envy the chap in the other thread who posted about "continuing as normal as possible" because an engine w/ a blown valve will continue to make normal power for a long time. Personally when my engine is running rough I'm not capable of such savoire-faire, I operate on the assumption that I really don't know what's up and the b**ch may quit on me any second. I want as much energy as I can bank until I have the runway made. Cheers, Sydney |
"Sydney Hoeltzli" wrote in message ... Last night, on a short hop back to home base after an instrument lesson (read: extended low power ops), engine shuddered and ran very rough just after level-off and power reduction. Run-up and takeoff were normal, and as usual I leaned like heck for taxi and during runup. About 80 degrees with blissfully low humidity, carb ice unlikely esp. in our installation, not very carb ice prone. Ground ran with brutal leaning afterwards and checked all chts/egts on both, r and l mag. r mag ran rougher, with higher EGT on #4 cyl. Suggestions? Going out to clean plugs and make sure all 4 cyl have compression this afternoon, what else to check? I'm hoping for a badly fouled plug, but would that produce high EGT on 1 mag? BTW I envy the chap in the other thread who posted about "continuing as normal as possible" because an engine w/ a blown valve will continue to make normal power for a long time. Personally when my engine is running rough I'm not capable of such savoire-faire, I operate on the assumption that I really don't know what's up and the b**ch may quit on me any second. I want as much energy as I can bank until I have the runway made. Cheers, Sydney Hi Sydney I've had two rough engine scenarios in flight. Once in '69 in a Cardinal and it just cleared up with leaning. The other time in a Skyhawk; Dropped an exhaust valve and I landed at the nearest airport. Both cases carbureted Lycoming 4's. Never had ice that I noticed. H. N502TB Oh yes, my Baron is still sitting there. Seven weeks. |
Sydney Hoeltzli wrote:
Last night, on a short hop back to home base after an instrument lesson (read: extended low power ops), engine shuddered and ran very rough just after level-off and power reduction. Wow, this is the first time I've heard an actual first-hand account of the engine running rough after the initial power reduction. Good job handling it, Sydney. Ground ran with brutal leaning afterwards and checked all chts/egts on both, r and l mag. r mag ran rougher, with higher EGT on #4 cyl. Suggestions? Going out to clean plugs and make sure all 4 cyl have compression this afternoon, what else to check? I'm hoping for a badly fouled plug, but would that produce high EGT on 1 mag? Fouled spark plug, faulty spark plug, bad lead, bad distributor... all possibilities. Was there any drop in CHT on cyl. #4? If so, it could be a burned exhaust valve. Let's hope it wasn't anything expensive. -Ryan CFII-A/MEI/CFI-H |
Sydney Hoeltzli wrote: to check? I'm hoping for a badly fouled plug, but would that produce high EGT on 1 mag? I'm not an expert, but I understand you can get weird effects if the combustion is still going on during the exhaust cycle. I thought that was usually due to a leaking exhaust valve, though. -- Ben Jackson http://www.ben.com/ |
Sydney Hoeltzli wrote in message ...
snip Ground ran with brutal leaning afterwards and checked all chts/egts on both, r and l mag. r mag ran rougher, with higher EGT on #4 cyl. Suggestions? Going out to clean plugs and make sure all 4 cyl have compression this afternoon, what else to check? I'm hoping for a badly fouled plug, but would that produce high EGT on 1 mag? Puzzling! It sounds like a bad or fouled plug, but the EGT doesn't make sense. If you were running on both mags, a bad plug would show up as a higher EGT on that cylinder. If you switched to the rough running mag, the EGT for the bad plug should drop. Running on a single (good) plug causes the EGT to rise since the fuel air mixture doesn't burn as quickly and is still burning when ejected into the exhaust. If you're running on a single plug that is firing intermittently, I'd expect the overall EGT to be lower, since there are (cold) unburned charges exiting the cylinder. Could the high EGT reading be coming from unburned charges being ignited in the exhaust stack by subsequent burning charges? John Galban=====N4BQ (PA28-180) BTW I envy the chap in the other thread who posted about "continuing as normal as possible" because an engine w/ a blown valve will continue to make normal power for a long time. Personally when my engine is running rough I'm not capable of such savoire-faire, I operate on the assumption that I really don't know what's up and the b**ch may quit on me any second. I want as much energy as I can bank until I have the runway made. Cheers, Sydney |
John Galban wrote:
Puzzling! It sounds like a bad or fouled plug, but the EGT doesn't make sense. If you were running on both mags, a bad plug would show up as a higher EGT on that cylinder. And it was higher, a bit, on a cylinder which usually isn't the hottest... If you switched to the rough running mag, the EGT for the bad plug should drop. 'swhat I would have thought too. Well, there was a lot of lead fouling in all the bottom plugs (which were cleaned recently -- ugh!). But nothing that looked as though it should have put one plug out of commission. Unless I burnt it off with ground running, I'm suspicious that this isn't the end of the problem. Just pulling through the prop, it's clear that #4 cylinder (the one w/ the high EGT) doesn't have as much compression as the others. Still got compression though. Dunno how quantitative. Pulled the rocker box cover, no sign of soot in the oil (the poor man's "exhaust valve going bad" warning system). #4 happens to be our only remaining NuChrome cylinder and had lower compression than I'd like last annual (no leakage past the valve though, and the wobble check was good) How does one check the ignition wires for proper function, and if one plug isn't producing spark as George suggested, would it be fouled? Methinks a compression check is in our future. Meworries about another sort of check. Meworries more about not tracking down the problem...of course some people would say I worry too much about 1 minute of rough running. Cheers, Sydney |
Sydney,
Why don't you swap the top an bottom plugs, if they both look fine. The next time it happens, and IF it is on a different mag, then you know for sure this is a plug gone bad, and you'll know which one. If the same mag, suspect wiring or a sticky valve. A can of Rislone in the oil can solve it if it is minor. If not, the valve guide needs a reamer shot and this is not a minor procedure. Guess you better be sure you are on the right culprit first. Just for the record, absolute EGT temperature doesn't mean a thing if you have not assessed its relationship to peak. An unusual change in EGT while cruising is a revelating event, but a power setting change can (and will) change it too (particularely on carburated engine). If your original comment that EGT#4 read higher, was it a "not the usual reading I see" or "while it got rough, I saw it change". The first one is normal (well, you didn't quantify the change, but I assume here it was minimal), since on a power reduction you don't necessarely see the same charge distribution across every cylinders (particularely if your intakes aren't tuned). The other case is more revealing but symptomatic of either a valve problem or a plug problem (so it just confirms you that you were not dreaming about the rougness). Trouble with those intermitents is that they are! Francois (also get worried when his engine goes rough) Marquis Sydney Hoeltzli wrote: John Galban wrote: Puzzling! It sounds like a bad or fouled plug, but the EGT doesn't make sense. If you were running on both mags, a bad plug would show up as a higher EGT on that cylinder. And it was higher, a bit, on a cylinder which usually isn't the hottest... If you switched to the rough running mag, the EGT for the bad plug should drop. 'swhat I would have thought too. Well, there was a lot of lead fouling in all the bottom plugs (which were cleaned recently -- ugh!). But nothing that looked as though it should have put one plug out of commission. Unless I burnt it off with ground running, I'm suspicious that this isn't the end of the problem. Just pulling through the prop, it's clear that #4 cylinder (the one w/ the high EGT) doesn't have as much compression as the others. Still got compression though. Dunno how quantitative. Pulled the rocker box cover, no sign of soot in the oil (the poor man's "exhaust valve going bad" warning system). #4 happens to be our only remaining NuChrome cylinder and had lower compression than I'd like last annual (no leakage past the valve though, and the wobble check was good) How does one check the ignition wires for proper function, and if one plug isn't producing spark as George suggested, would it be fouled? Methinks a compression check is in our future. Meworries about another sort of check. Meworries more about not tracking down the problem...of course some people would say I worry too much about 1 minute of rough running. Cheers, Sydney |
Francois Marquis wrote:
Just for the record, absolute EGT temperature doesn't mean a thing if you have not assessed its relationship to peak. Of course An unusual change in EGT while cruising is a revelating event I wasn't perusing the EGT in flight. More interested in putting myself in a position to make the airport. , but a power setting change can (and will) change it too (particularely on carburated engine). If your original comment that EGT#4 read higher, was it a "not the usual reading I see" or "while it got rough, I saw it change". The first one is normal (well, you didn't quantify the change, but I assume here it was minimal) Actually, no, it was significant. Normally during ground run before shutdown (I follow the Lycoming SB for plug fouling, ground run at ~mag check rpm while lean), I see EGTs in the 1000s. That day they were all higher -- closer to cruise EGT of about 1200-1300 with #4 being 1400 and on R mag 1490. Peak is about 1500 in my plane. After cleaning the plugs, ground run EGTs back to normal. Still not sure why fouled plugs = higher EGTs but I'll take it Thanks Sydney |
Sydney Hoeltzli wrote: Suggestions? Going out to clean plugs and make sure all 4 cyl have compression this afternoon, what else to check? I'm hoping for a badly fouled plug, but would that produce high EGT on 1 mag? It could do that. High EGTs can be produced by a slow fuel burn in that cylinder, and this can be produced by fouled plugs. Make sure you check the wiring harness too. Last time I had this sort of problem, one plug was fouled *because* the other one wasn't firing and she was running too rich on that cylinder. The other plug wasn't firing because the plug wire had quit conducting electrons. George Patterson The optimist feels that we live in the best of all possible worlds. The pessimist is afraid that he's correct. James Branch Cavel |
I have Glasair II with I-O360. When training and running low power for
extended periods I get a little roughness. If I run it harder then I don't get the roughness. It may pop on final or while taxing, my mech said it is because the plugs get "loaded up". Meaning a little fouling. When my instructor wants me to stay at 90kts my power settings are very low and the engine oil heats up to a little over 200F. Other wise it runs 190-195. This is because airflow and nose high attitude. Steve |
| Dennis Fetters Mini 500 | EmailMe | Home Built | 70 | June 21st 04 10:36 PM |
| Proposals for air breathing hypersonic craft. I | Robert Clark | Military Aviation | 2 | May 26th 04 07:42 PM |
| What if the germans... | Charles Gray | Military Aviation | 119 | January 27th 04 12:20 AM |
| Aircraft engine certification FAR's | Corky Scott | Home Built | 4 | July 25th 03 07:46 PM |
| First Emergency (Long Post) | [email protected] | Owning | 14 | July 23rd 03 03:46 AM |
