Looking for a safe plug for a battery that will be routinely removed
from a glider. Any suggestions? JD |
Quote:
Such a very amazing link! Thanks you for the post. |
On 1/30/2011 1:55 PM, wrote:
On Sun, 30 Jan 2011 07:31:01 -0800 (PST), wrote: Looking for a safe plug for a battery that will be routinely removed from a glider. Any suggestions? JD Depends on battery size and poer requirements - anything from a 3mm co-ax plug to an Anderson PowerPole If I were using two separate plugs I'd use two different sizes as a tactile cue to polarity. Colour is nice if one can see clearly, so I guess it depends on installation and daylight. Dan, U.S. Air Force, retired |
| Thread Tools | |
| Display Modes | |
| Power connector for Garmin 400/420/430 | rmhou at yahoo.com | Home Built | 3 | April 7th 09 07:21 AM |
| DG-1000 Tail Battery Connector. Where to get one? | Jeremy Zawodny | Soaring | 7 | January 4th 07 03:50 PM |
| STS connector | Alan & Ruth Glatt | Products | 1 | November 30th 04 09:25 AM |
| Narco pin connector | Eugene Wendland | Home Built | 0 | April 11th 04 03:25 AM |
| Need connector for King KI-206 | DanD | Home Built | 2 | January 14th 04 12:50 AM |
