Tying down the bird
Old September 15th 03, 04:31 PM
david whitley
Default Tying down the bird
Hi group
I need some basic instruction.... I've been noticing tie down ropes. The
knots folks use are all over the map. Is there a basic "best" knot for tying
down the bird? We're looking at windy weather here in the NE this weekend.
The ropes here on the Vineyard are poly-something.
A link to a picture would be nice.
Dave
Old September 15th 03, 04:47 PM
hnelson
I have always been "knot challenged". For about $15 I got a set of nylon
tiedown straps with vinyl coated hooks from Costco. Set of 4. Two long and
two short. The long ones work great for the wing tiedowns on my 182 short
one for the tail. Worked great during a tropical storm in LaPaz.
Howard
"david whitley" wrote in message
Hi group
tying
Dave
Old September 15th 03, 05:08 PM
Ron Natalie
"hnelson" wrote in message m...
Only if they have closed hooks. I had my plane bust loose at Oshkosh the
first year because I used tie downs with open hooks. Just takes some slackening
of the rope to get them to pop out of the eye.
Old September 16th 03, 02:06 AM
BTIZ
do not use open hooks especially with high winds..
look at www.aviation-salvage.com/n51Y.htm for results of open hooks letting
go in a 57knt gust front..
m...
Howard
Hi group
tying
weekend.
Dave
Old September 16th 03, 06:09 PM
John Clonts
Not Found
The requested URL /n51Y.htm was not found on this server.
So the plane blew away and was never found, eh?
Cheers,
John Clonts
Temple, Texas
N7NZ
BTIZ wrote in message
news:Zrs9b.56831$Qy4.7945@fed1read05...
letting
m...
and
short
Howard
Hi group
The
tying
weekend.
Dave
Old September 17th 03, 02:56 AM
BTIZ
http://www.aviation-salvage.com/N51Y.htm
must be a capital N thing.. it's still there... did a couple of cart wheels,
thankfully it was away from the tie down line... it could have been ugly...
there was about $1M worth of gliders on that tie down line... when the gust
front hit.. the other $500K where either in trailers or out on course.
BT
"John Clonts" wrote in message
Not Found
Cheers,
John Clonts
Temple, Texas
N7NZ
letting
m...
nylon
and
short
Howard
Hi group
The
for
tying
weekend.
Dave
Old September 17th 03, 03:11 AM
john price
Buy a copy of F.E. Potts "Guide to Bush Flying", or read the section
on tying down airplanes on-line at:
http://www.fepco.com/BF.images.gentle.breeze.html
John Price
CFII/AGI/IGI
http://home.att.net/~jm.price
m...
Howard
Hi group
tying
weekend.
Dave
Old September 15th 03, 05:36 PM
G.R. Patterson III
I usually use a canoe hitch. Before the storm hits, I will head out to the
airport and change the knots to as many half hitches as I have rope for. I may
have to cut them loose later, but I'm not leaving slack in the ropes or using
a knot that might slip and produce slack. Some posters recommend a knot called
a "hurricane hitch", and links to photos have been posted in the past. You might
run a Google search for that.
My usual tiedown ropes are 5/8" nylon. They were sold as boat hawsers and came
with loops braided into the ends. I have run those ends through the tiedown
anchors. This week, I will also be running doubled 1/2" nylon ropes from the
anchors to my wing struts as backups.
If your ropes are polypropylene, I would replace them with nylon. Poly will not
stand up to sunlight very well and deteriorates in only a few years.
George Patterson
A man who carries a cat by the tail learns something that cannot
be learned any other way. Samuel Clemens
Old September 15th 03, 07:39 PM
ShawnD2112
The important thing to remember is to tie it down tight. You don't want any
slack in the ropes at all which the wind can exploit and rock the airplane
around. I typically use a round turn and two half hitches (standard
sailor's knot) and don't leave the extra rope dangling as it can become a
whip in a high wind and damage the airplane. Make sure you tie down the
tail, too - just doing the wings isn't enough.
Good luck!
Shawn
Hi group
tying
Dave
Old September 15th 03, 09:28 PM
Steve Robertson
Best tiedowns I've ever used were made of seatbelt webbing with a hook on each
end. Had the seat belt buckle and everything. Tighten just like the one in your
plane. It won't loosen.
Best regards,
Steve Robertson
N4732J 1967 Beechcraft A23-24 Musketeer
Hi group
Dave
Would the AH-6J (Little Bird make a good, low cost, helicopter for force protection? John Hairell Military Aviation 1 May 17th 04 05:21 PM
FS - Bird 43 Wattmeter element for Aviation repair Lou Aviation Marketplace 0 March 15th 04 02:27 AM
T Bird - ZackGSD Home Built 1 December 15th 03 02:47 PM
Bird control David Naugler Aviation Marketplace 7 September 22nd 03 04:40 PM
Finally got to fly my new bird Jay Honeck Owning 35 August 23rd 03 06:01 AM
