Fantastic concept, however as a homebuilder I think that my little pile of
unfinished aluminium and cloth is probably going to be a tad out of place in this. (I will have to stick to dismantling it and storing it in my garage at home.) "geo" wrote in message ... http://monolithicdome.com/gallery/co...s03/index.html Monolithic Dome Airplane Hangars |
Why build at all? Just encase your kit or raw materials inside a solid mound
of concrete for eternity and *say* there's an airplane within. Who could prove you wrong? Eric |
In article , geo
wrote: http://monolithicdome.com/gallery/co...s03/index.html Monolithic Dome Airplane Hangars Pffft! We built our hangar from $20 plans. No door, total cost was a little less than $3000. This includes the crushed limestone apron and hangar floor. |
"EDR" wrote in message
... In article , geo wrote: http://monolithicdome.com/gallery/co...s03/index.html Monolithic Dome Airplane Hangars Pffft! We built our hangar from $20 plans. No door, total cost was a little less than $3000. This includes the crushed limestone apron and hangar floor. You can spend less than that on a basic version just using rebar, concrete & the airform and it would be much stronger. Or you can go whole hog with the insulated version with electronic sliding door, etc. It's a very flexible system. |
geo wrote:
You can spend less than that on a basic version just using rebar, concrete & the airform and it would be much stronger. Or you can go whole hog with the insulated version with electronic sliding door, etc. It's a very flexible system. Foam concrete (or concrete foam)? Come to think of it, one could use the construction methods used by college Civil Engineering departments to fabricate concrete canoes and entrained air to create a lightweight structure. The airform would provide the support for the couple layers, then spray on the successive layers. That would be an interesting college challenge problem. Materials could be donated, the military would provide research grants. Forget the college challenge, I'll just apply for the grant! |
A problem I can see is given that hangar plots at airports are usually rectangular-shaped, you usually try to maximixe use of the land and squeeze in as many hangars in as you can, with walls adjoining one another. Round hangars will waste a lot of ground surface area around them. I'd rather see a standard rectangular-shaped hangar, but perhaps built with this stuff for the exterior walls and roof: http://www.agriboard.com/brochure.html http://www.agriboard.com/pdfs/tornado.pdf http://www.agriboard.com/fires.html |
Well, you could combine the dome hangar with this idea:
http://www.carouselhangars.com/ Bill Daniels "Neal" wrote in message ... A problem I can see is given that hangar plots at airports are usually rectangular-shaped, you usually try to maximixe use of the land and squeeze in as many hangars in as you can, with walls adjoining one another. Round hangars will waste a lot of ground surface area around them. I'd rather see a standard rectangular-shaped hangar, but perhaps built with this stuff for the exterior walls and roof: http://www.agriboard.com/brochure.html http://www.agriboard.com/pdfs/tornado.pdf http://www.agriboard.com/fires.html |
Argh! Beat me to it!
![]() "Bill Daniels" wrote in message k.net... Well, you could combine the dome hangar with this idea: http://www.carouselhangars.com/ Bill Daniels "Neal" wrote in message ... A problem I can see is given that hangar plots at airports are usually rectangular-shaped, you usually try to maximixe use of the land and squeeze in as many hangars in as you can, with walls adjoining one another. Round hangars will waste a lot of ground surface area around them. I'd rather see a standard rectangular-shaped hangar, but perhaps built with this stuff for the exterior walls and roof: http://www.agriboard.com/brochure.html http://www.agriboard.com/pdfs/tornado.pdf http://www.agriboard.com/fires.html |
But round hangars can be configured to be much more efficient than square
hangars. Just add one of these. ![]() http://www.carouselhangars.com/ Juan "Neal" wrote in message ... A problem I can see is given that hangar plots at airports are usually rectangular-shaped, you usually try to maximixe use of the land and squeeze in as many hangars in as you can, with walls adjoining one another. Round hangars will waste a lot of ground surface area around them. I'd rather see a standard rectangular-shaped hangar, but perhaps built with this stuff for the exterior walls and roof: http://www.agriboard.com/brochure.html http://www.agriboard.com/pdfs/tornado.pdf http://www.agriboard.com/fires.html |
| Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | October 1st 04 03:31 PM |
| Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | April 5th 04 04:04 PM |
| "I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 10th 04 12:35 AM |
| airplane hangars | geo | Home Built | 23 | October 22nd 03 05:04 PM |
| Homebuilt Aircraft Frequently-Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | July 4th 03 05:50 PM |
