My 1980 B-55 has uneven load distribution on the two alternators, with the
right side consistently reading around 15% lower than the left. Is this an indication of a problem with the alternator like a bad diode, or is this normal operating behavior? |
"Viperdoc" wrote in message ...
My 1980 B-55 has uneven load distribution on the two alternators, with the right side consistently reading around 15% lower than the left. Is this an indication of a problem with the alternator like a bad diode, or is this normal operating behavior? They match within 15%? That's great. Even tho the POH suggests better. You should check to verify that each can handle the load by itself, even at fairly low RPM like 1500. That will eliminate the possibility of failed diodes. You do switch between regulators on each trip, don't you? That way you know both regulators work. T'aint redundant otherwise. Bill Hale, BPPP instructor |
Yes, I switch the voltage regulator on every flight. The concerns that I
voiced regarding the alternator load came from an article in the American Bonanza Society magazine, where another Baron owner saw similar behavior. This article suggested that it might be a bad diode in the weaker alternator. As a matter of fact, I called the ABS today, and they suggested that the observed difference could be due to a poor ground, and suggested investigation of the same. I hope to do this in the near future. Thanks. |
"Viperdoc" writes:
Yes, I switch the voltage regulator on every flight. The concerns that I voiced regarding the alternator load came from an article in the American Bonanza Society magazine, where another Baron owner saw similar behavior. This article suggested that it might be a bad diode in the weaker alternator. As a matter of fact, I called the ABS today, and they suggested that the observed difference could be due to a poor ground, and suggested investigation of the same. I hope to do this in the near future. Could be bad grounds. Could be bad diodes. But unless the two voltage regulators EXACTLY track {and they never do} one will work harder than the other. That's life. You can test for bad diodes with a fair degree of success as follows. With one alternator on line at idle, load it down, say the landing lights. Listen carefully in your headset for whine, dependent on RPM. Then swap to the other alternator. If one is missing a diode, it likely will have far more audible whine than the other. (I'm having a hard time picturing how you swap regulators. Does this aircraft use one regulator for both alternators???) -- A host is a host from coast to & no one will talk to a host that's close........[v].(301) 56-LINUX Unless the host (that isn't close).........................pob 1433 is busy, hung or dead....................................20915-1433 |
The B-55 has two voltage regulators, which are switchable from inside the
cockpit. I plan on flying locally tomorrow, and will check the diodes for each alternator. |
Just thinking: does cutting the alternator (belt driven) in and out with the
engine running damage anything? |
In article , "Viperdoc"
writes: Just thinking: does cutting the alternator (belt driven) in and out with the engine running damage anything? I hope not. I start my Archer with the Gen field off and then turn it on after engine start. Chuck |
My 1980 B-55 has uneven load distribution on the two alternators, with the right side consistently reading around 15% lower than the left. Is this an indication of a problem with the alternator like a bad diode, or is this normal operating behavior? I had a similar problem with a Seneca. Except is was more like 80/20. Turned out to be the voltage regulators being set higher on one alternator than another. -Nathan |
| Distribution of armor on a B-52 | B2431 | Military Aviation | 12 | August 16th 04 10:07 PM |
| Beach Baron Crash | Kevin | Owning | 0 | November 22nd 03 01:40 AM |
| Red Baron vs. Rickenbacker? | Gregorso | Military Aviation | 28 | October 13th 03 08:26 PM |
| Red Baron reports and other stuff Qs | Zajcevi | Military Aviation | 5 | September 7th 03 06:32 PM |
| Riddle me this, pilots | Chip Jones | Instrument Flight Rules | 137 | August 30th 03 05:02 AM |
