I recently saw an article in KitPlanes or maybe Sport Pilot about how
to repair / rebuild a plastic instrument panel overlay. Whichever mag I saw it in, I've managed to throw away. Anyone know what issue this was? Could you email me a copy? Thanks for the help. Jeff |
I think it was 'Sport Aviation' but I also traded it.
Jim |
Jerry Mader makes a product called POLYFIX. He sells it in kit form. My father and Jerry used to demonstrate it in the Aircraft Spruce booth at Sun N Fun and at Oshkosh. For information, go to www.redam.com |
Thanks for the help. There is a very fine product called "JB Weld" that my A&P recommended to me. It works extremely well on the plastic instrument panel parts. JB Weld is amazing stuff. It comes in two separate tubes, and you mix it together like epoxy. It stays workable for over an hour, and "gravity smoothes" itself into a very nice surface. When it is fully cured (overnight) you can drill it, sand it, saw it -- just like the original plastic. I have used it to repair several parts, and -- after painting -- you can't see the repair at all. On the last thing I repaired (the stupidly designed fuel sump access door that every back-seat passenger seems to step on and break) I actually used it to not only fix the break, but I was able to get it to "surround" and encapsulate a small piece of aluminum sheet metal, to act as a reinforcement. To further strengthen the piece, I drilled and pop-riveted the aluminum piece to the plastic before gluing. The JB Weld fills voids extremely well. (Every time I fix this stupid part, I make it stronger. This is my third attempt -- if my kids break it again, I'm installing a piano hinge on the danged door!) -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
Would have been nice if Piper had put the sump drain actuator *outside* on the
belly near where you need to hold the collection bottle, wouldn't it? Even if it were behind some sort of door (like it is on the inside), it would have avoided all the passenger induced damage, as well as many of the gas spots on asphalt ramps. (I assume the 235 has a similar set up as a Six with the push down lever thingy behind the cheesy plastic door with the spring hinges). Maybe someone can come up with an STC to put the drain actuator on the belly where it belongs. Jay Honeck wrote: Thanks for the help. There is a very fine product called "JB Weld" that my A&P recommended to me. It works extremely well on the plastic instrument panel parts. JB Weld is amazing stuff. It comes in two separate tubes, and you mix it together like epoxy. It stays workable for over an hour, and "gravity smoothes" itself into a very nice surface. When it is fully cured (overnight) you can drill it, sand it, saw it -- just like the original plastic. I have used it to repair several parts, and -- after painting -- you can't see the repair at all. On the last thing I repaired (the stupidly designed fuel sump access door that every back-seat passenger seems to step on and break) I actually used it to not only fix the break, but I was able to get it to "surround" and encapsulate a small piece of aluminum sheet metal, to act as a reinforcement. To further strengthen the piece, I drilled and pop-riveted the aluminum piece to the plastic before gluing. The JB Weld fills voids extremely well. (Every time I fix this stupid part, I make it stronger. This is my third attempt -- if my kids break it again, I'm installing a piano hinge on the danged door!) -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" -- --Ray Andraka, P.E. President, the Andraka Consulting Group, Inc. 401/884-7930 Fax 401/884-7950 http://www.andraka.com "They that give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety." -Benjamin Franklin, 1759 |
Do you guys carry a bucket to catch the gas you drain if you remain
overnight somewhere? Eleven seconds minimum for each tip and six seconds for each main spills a lot of gas. Don On Mon, 26 Jan 2004 16:51:48 -0500, Ray Andraka wrote: Would have been nice if Piper had put the sump drain actuator *outside* on the belly near where you need to hold the collection bottle, wouldn't it? Even if it were behind some sort of door (like it is on the inside), it would have avoided all the passenger induced damage, as well as many of the gas spots on asphalt ramps. (I assume the 235 has a similar set up as a Six with the push down lever thingy behind the cheesy plastic door with the spring hinges). Maybe someone can come up with an STC to put the drain actuator on the belly where it belongs. Jay Honeck wrote: Thanks for the help. There is a very fine product called "JB Weld" that my A&P recommended to me. It works extremely well on the plastic instrument panel parts. JB Weld is amazing stuff. It comes in two separate tubes, and you mix it together like epoxy. It stays workable for over an hour, and "gravity smoothes" itself into a very nice surface. When it is fully cured (overnight) you can drill it, sand it, saw it -- just like the original plastic. I have used it to repair several parts, and -- after painting -- you can't see the repair at all. On the last thing I repaired (the stupidly designed fuel sump access door that every back-seat passenger seems to step on and break) I actually used it to not only fix the break, but I was able to get it to "surround" and encapsulate a small piece of aluminum sheet metal, to act as a reinforcement. To further strengthen the piece, I drilled and pop-riveted the aluminum piece to the plastic before gluing. The JB Weld fills voids extremely well. (Every time I fix this stupid part, I make it stronger. This is my third attempt -- if my kids break it again, I'm installing a piano hinge on the danged door!) -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
overnight somewhere? Eleven seconds minimum for each tip and six seconds for each main spills a lot of gas. Where did you get those numbers? Never heard that before -- we sump them into the clear plastic tube, check for debris and water, and go on our merry way... -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
On Mon, 26 Jan 2004 23:54:34 GMT, "Jay Honeck"
wrote: Do you guys carry a bucket to catch the gas you drain if you remain overnight somewhere? Eleven seconds minimum for each tip and six seconds for each main spills a lot of gas. Where did you get those numbers? Never heard that before -- we sump them into the clear plastic tube, check for debris and water, and go on our merry way... Bear in mind ours is a '69. While going through old W&B stuff, I found this Piper document that says it's supposed to be kept with the aircraft. The last page and a half contains a description of how to drain the tanks through the belly so that you collect all the water that might be in the gas lines between the tanks and the sump. Goes: start with the selector on OFF, then left-tip, left-main, right-main, right-tip, 11-seconds, 6-seconds, 6-seconds, 11-seconds. The times are minimums, for when the tanks are full -- it says it might take more time if the tanks aren't full. Makes a certain amount of sense if you think about it. You can have gas in the belly-drain sump and water in a tank line where the water's below the level of the tank drain, but is blocked from entering the selector valve by its check-valve. When you select a new tank, the check-valve is opened, and yes water will flow down the line and into the sump, displacing the gas that's there, but it won't happen instantaneously. The procedure should apply to all Cherokees with four tanks. I'll look up chapter and verse tomorrow. I bet the procedure isn't well known, and it wouldn't be well liked, because you wind up draining close to a pint of gas -- onto the ramp if you don't have a bucket and a Gatt jar. I'll bring it up on the 235 BBS after I see what responses come up here on the NG. Don |
Jay Honeck wrote: Do you guys carry a bucket to catch the gas you drain if you remain overnight somewhere? Eleven seconds minimum for each tip and six seconds for each main spills a lot of gas. Where did you get those numbers? Out of the AOM (POH for those whose planes are too young to remember the AOM). I imagine the 235 has similar numbers. Never heard that before -- we sump them into the clear plastic tube, check for debris and water, and go on our merry way... -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" -- --Ray Andraka, P.E. President, the Andraka Consulting Group, Inc. 401/884-7930 Fax 401/884-7950 http://www.andraka.com "They that give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety." -Benjamin Franklin, 1759 |
In article _MhRb.160023$na.268733@attbi_s04, Jay Honeck
wrote: Do you guys carry a bucket to catch the gas you drain if you remain overnight somewhere? Eleven seconds minimum for each tip and six seconds for each main spills a lot of gas. Where did you get those numbers? Piper PA32-300 Information Manual (Issued July 1973), Chapter 2 "Airplane and Systems", "Fuel System" Piper PA32-300 Infomration Manual (Issued August 1976, revised September 1978), Chapter 4 "Normal Procedures", 4.9 Preflight Check, Miscellaneous. Apparently, this was revised when Piper changed from the separate four tanks/four lines feed fuel selector, of the older models (four separate fuel tank gauges), to four tanks, tips flow into mains, mains feed fuel selector (two fuel tank gauges). The instructions are listed based on aircraft serial number and specifies the sequence for draining the tanks. The six second time is retained while the 11 second time is deleted and a note to the effect that a less than full tank my require an additional few seconds. Both these manuals contain drawings of the fuel systems. The Piper PA28-236 Information Manual (Issued July 1978) only mentions the right/left wing tank sumps. This manual also contains a fuel system drawing in Chapter 7, Description and Operations. |
| Instrument Checkride passed (Long) | Paul Folbrecht | Instrument Flight Rules | 10 | February 11th 05 03:41 AM |
| Instrument panel labelling options | John Galban | Home Built | 12 | November 18th 04 11:42 PM |
| Logging approaches | Ron Garrison | Instrument Flight Rules | 109 | March 2nd 04 06:54 PM |
| replacing plastic panel overlay w/aluminum | Dave | Owning | 7 | January 10th 04 11:52 PM |
| PC flight simulators | Bjørnar Bolsøy | Military Aviation | 178 | December 14th 03 01:14 PM |
