I'm going to be re-doing the panel in my old Bonanza and would like to
get rid of the gauge cluster i currently have and replace it with something that can fit in a standard instrument hole. The cluster takes up a lot of real estate. I need fuel pressure, oil pressure, ammeter and fuel gauge in the same hole. And possibly CHT. The oil pressure and fuel pressure are currently the direct feed type, ie lines are directly fed into the gauge. Is there anything out there that can satisfy my needs or close. I have room for an additional instrument hole if needed. Thanks Dave |
Before you install it... and probably before you buy it, I suggest you
check with your local FSDO about getting approval for replacing the factory guages. I strongly believe it will be VERY hard to get approval! Rich dave wrote: I'm going to be re-doing the panel in my old Bonanza and would like to get rid of the gauge cluster i currently have and replace it with something that can fit in a standard instrument hole. The cluster takes up a lot of real estate. I need fuel pressure, oil pressure, ammeter and fuel gauge in the same hole. And possibly CHT. The oil pressure and fuel pressure are currently the direct feed type, ie lines are directly fed into the gauge. Is there anything out there that can satisfy my needs or close. I have room for an additional instrument hole if needed. Thanks Dave |
dave wrote: Is there anything out there that can satisfy my needs or close. I have room for an additional instrument hole if needed. It's usually extremely difficult to get the FSDO to allow you to replace factory instruments such as fuel gauges. Check out back issues of AOPA Pilot from 2001 to get some idea of what can be done. They fixed up a V35 that year. The panel work was done by http://www.jaair.com . George Patterson A diplomat is a person who can tell you to go to hell in such a way that you look forward to the trip. |
"G.R. Patterson III" wrote in message ...
dave wrote: Is there anything out there that can satisfy my needs or close. I have room for an additional instrument hole if needed. It's usually extremely difficult to get the FSDO to allow you to replace factory instruments such as fuel gauges. Check out back issues of AOPA Pilot from 2001 to get some idea of what can be done. They fixed up a V35 that year. The panel work was done by http://www.jaair.com . George Patterson A diplomat is a person who can tell you to go to hell in such a way that you look forward to the trip. Ahhh. The blessing of owning an experimental. I am sooo happy to have sold all my certified planes. I never want to see a 337 form, a yellow tag or visit a FSDO again. Good luck on getting the feds to approve anything like that. Ben Haas N801BH. |
| Thread Tools | |
| Display Modes | |
| Need gauge help/information | dave | Home Built | 3 | February 17th 04 03:39 AM |
| Need gauge help/information | dave | General Aviation | 3 | February 17th 04 03:39 AM |
| Vaccuum Pressure Gauge | Al | Owning | 4 | January 16th 04 06:26 PM |
| Carb Temperature Gauge | fly_the_skies | Home Built | 6 | January 14th 04 04:32 PM |
| Regarding Oil Temp Gauge and Line Repairable | rkane33 | Owning | 0 | September 14th 03 10:54 PM |
