I'm about to start building the "furniture" for the hangar. After a lifetime of
building "manly" workbenches out of DF 4x4s milled to take 2x4 crossmembers, and having the concomitant rot and deterioration of wood, I'm considering making the framing out of 1¼ PVC Schedule 40 pipe and fittings. The problem is what to use for the bench tops and shelving underneath. So far, all my "heavy duty" workbenches have been made out of 3/4" plywood with a 2" doubler plate along the front and back, and my electronic workbenches have been either solid core or hollow core doors with an appropriate varnish or Deft coating on them. However, since I'm going to a new method of framing, I'd like thoughts on what you have used as workbench/shelving materials. The benches will be about 2' wide and 6' long. Yes, I know, solid moulded Teflon would be best, but quick and cheap is high on the list of attributes I'm looking for. Thoughts appreciated. Jim Jim Weir (A&P/IA, CFI, & other good alphabet soup) VP Eng RST Pres. Cyberchapter EAA Tech. Counselor http://www.rst-engr.com |
Jim Weir wrote:
I'm about to start building the "furniture" for the hangar. After a lifetime of building "manly" workbenches out of DF 4x4s milled to take 2x4 crossmembers, and having the concomitant rot and deterioration of wood, I'm considering making the framing out of 1¼ PVC Schedule 40 pipe and fittings. The problem is what to use for the bench tops and shelving underneath. So far, all my "heavy duty" workbenches have been made out of 3/4" plywood with a 2" doubler plate along the front and back, and my electronic workbenches have been either solid core or hollow core doors with an appropriate varnish or Deft coating on them. However, since I'm going to a new method of framing, I'd like thoughts on what you have used as workbench/shelving materials. The benches will be about 2' wide and 6' long. Yes, I know, solid moulded Teflon would be best, but quick and cheap is high on the list of attributes I'm looking for. Thoughts appreciated. Jim Jim Weir (A&P/IA, CFI, & other good alphabet soup) VP Eng RST Pres. Cyberchapter EAA Tech. Counselor http://www.rst-engr.com Just out of curiosity what's wrong with "manly" workbenches? And why would DF 4x4's rot away during your lifetime in a hanger that one presumes is dry enough to do good work on an airplane and/or anything else? I'd stick with the "manly" frame and use replaceable particle board tops. When driving something apart with a "meanit" hammer there's nothing like a good stout structure underneath. Shelving and storage compartments can be lighter duty but a workbench is for WORK. The first time you set something heavy on that pvc base you'll remember with fondness those old "manly" benches:-) Gary Thomas |
On 3-Mar-2004, Gary Thomas wrote: Just out of curiosity what's wrong with "manly" workbenches? And why would DF 4x4's rot away during your lifetime in a hanger that one presumes is dry enough to do good work on an airplane and/or anything else? I'd stick with the "manly" frame and use replaceable particle board tops. I agree. 25 years ago I built a workbench in my unheated garage. It has a framework of untreated 2X4s and a screwed-down benchtop of 3/4 inch particle board. Legs are 4X4s. Despite our damp Pacific Northwest climate, it seems as strong today as when it was built. -- -Elliott Drucker |
My favorite bench is still 2x4 legs, 2- 2x6 stringers under the top (add a couple cross braces) a top glued up of about 3-4 layers
of particle board to around 2+ inches thick. Then just nail a couple cross pieces in the legs and lay on a shelf. Build it like a dock. Fast, easy, sturdy as heck and pretty cheap. You can stiffen up the shelf with a 2x4 glued and nailed on each edge so it won't sag. Probably can't in your hanger but even easier if you can nail or screw one stringer to the wall. Mike Z "Jim Weir" wrote in message ... I'm about to start building the "furniture" for the hangar. After a lifetime of building "manly" workbenches out of DF 4x4s milled to take 2x4 crossmembers, and having the concomitant rot and deterioration of wood, I'm considering making the framing out of 1¼ PVC Schedule 40 pipe and fittings. The problem is what to use for the bench tops and shelving underneath. So far, all my "heavy duty" workbenches have been made out of 3/4" plywood with a 2" doubler plate along the front and back, and my electronic workbenches have been either solid core or hollow core doors with an appropriate varnish or Deft coating on them. However, since I'm going to a new method of framing, I'd like thoughts on what you have used as workbench/shelving materials. The benches will be about 2' wide and 6' long. Yes, I know, solid moulded Teflon would be best, but quick and cheap is high on the list of attributes I'm looking for. Thoughts appreciated. Jim Jim Weir (A&P/IA, CFI, & other good alphabet soup) VP Eng RST Pres. Cyberchapter EAA Tech. Counselor http://www.rst-engr.com |
In Jim Weir wrote:
However, since I'm going to a new method of framing, I'd like thoughts on what you have used as workbench/shelving materials. The benches will be about 2' wide and 6' long. Yes, I know, solid moulded Teflon would be best, but quick and cheap is high on the list of attributes I'm looking for. I know you are looking for something other than wood, but these are my favorite workbenches: http://www.eaa1000.av.org/technicl/w...l/worktabl.htm Cheap will depend on the cost of materials in your locality, but as for quick I can knock out 3-4 of these in an afternoon/evening. I like to paint them with cheap latex house paint more to make them easier to clean rather than prevent rot. If they start to get messed up you can just run a sander over the tops and paint them again. If you want a special benchtop just lay some mdf over the top and when it gets messed up, turn it over. ---------------------------------------------------- Del Rawlins- Remove _kills_spammers_ to reply via email. Unofficial Bearhawk FAQ website: http://www.rawlinsbrothers.org/bhfaq/ |
"Jim Weir" wrote in message ... I'm about to start building the "furniture" for the hangar. After a lifetime of building "manly" workbenches out of DF 4x4s milled to take 2x4 crossmembers, and having the concomitant rot and deterioration of wood, I'm considering making the framing out of 1¼ PVC Schedule 40 pipe and fittings. The problem is what to use for the bench tops and shelving underneath. So far, all my "heavy duty" workbenches have been made out of 3/4" plywood with a 2" doubler plate along the front and back, and my electronic workbenches have been either solid core or hollow core doors with an appropriate varnish or Deft coating on them. However, since I'm going to a new method of framing, I'd like thoughts on what you have used as workbench/shelving materials. The benches will be about 2' wide and 6' long. Yes, I know, solid moulded Teflon would be best, but quick and cheap is high on the list of attributes I'm looking for. Thoughts appreciated. Jim Jim Weir (A&P/IA, CFI, & other good alphabet soup) VP Eng RST Pres. Cyberchapter EAA Tech. Counselor http://www.rst-engr.com The best workbench top I have ever seen was an old bowling alley. It seems that a local alley was damaged by fire but several of the alleys survived. A friend of mine talked the insurance company into giving him the alleys if he would remove them to clear the site for rebuilding. It took a lot of friends with chain saws and a rented truck with a crane but two of the alleys made it back to his shop and became spar benches. They were dead flat, about 6" thick, and made of very hard laminated wood. They sat on welded 2" square steel tube frames. My friend is long dead but the work benches are probably still in use. Bill Daniels |
Oooookay, let me try again.
What NONLUMBER bench tops have you ever seen or considered that might work? I'm not making 747s, fellers, nor am I building spars. The worst I might want to do is bend up a 4" x 6" bracket out of 5052H32 and drill it with a Harbor Freight benchtop drill press. Jim Jim Weir shared these priceless pearls of wisdom: -However, since I'm going to a new method of framing, I'd like thoughts on what -you have used as workbench/shelving materials. The benches will be about 2' -wide and 6' long. Yes, I know, solid moulded Teflon would be best, but quick -and cheap is high on the list of attributes I'm looking for. - -Thoughts appreciated. Jim Weir (A&P/IA, CFI, & other good alphabet soup) VP Eng RST Pres. Cyberchapter EAA Tech. Counselor http://www.rst-engr.com |
Jim Weir wrote: What NONLUMBER bench tops have you ever seen or considered that might work? Sorry, I misunderstood. Since you put it that way, none. I do have an old table saw base and top that I use for metalwork, but I think you will not find one that's six feet long. Anything else I can think of is either too flimsy or has a wooden base structure (like Formica kitchen countertops). George Patterson A diplomat is a person who can tell you to go to hell in such a way that you look forward to the trip. |
In rec.aviation.owning Jim Weir wrote:
Oooookay, let me try again. What NONLUMBER bench tops have you ever seen or considered that might work? I'm not making 747s, fellers, nor am I building spars. The worst I might want to do is bend up a 4" x 6" bracket out of 5052H32 and drill it with a Harbor Freight benchtop drill press. Jim Jim Weir shared these priceless pearls of wisdom: -However, since I'm going to a new method of framing, I'd like thoughts on what -you have used as workbench/shelving materials. The benches will be about 2' -wide and 6' long. Yes, I know, solid moulded Teflon would be best, but quick -and cheap is high on the list of attributes I'm looking for. - -Thoughts appreciated. Jim Weir (A&P/IA, CFI, & other good alphabet soup) VP Eng RST Pres. Cyberchapter EAA Tech. Counselor http://www.rst-engr.com Well, I have a couple I covered with thin (about 16 Ga) sheet steel. When I want a "soft" top, I drop a piece of plywood on top. Of course, they are supported by a welded 1 inch steel tube frame, not PVC pipe and spot welded to the frame. The sheet steel was given to me and the steel tube cost about $30. Got any friends in the scrap metal business? -- Jim Pennino Remove -spam-sux to reply. |
Dip the ends of the legs in penta preservative and your rot problems are
over. If you can pick up your present benches, it can still be done. "Jim Weir" wrote in message ... Oooookay, let me try again. What NONLUMBER bench tops have you ever seen or considered that might work? I'm not making 747s, fellers, nor am I building spars. The worst I might want to do is bend up a 4" x 6" bracket out of 5052H32 and drill it with a Harbor Freight benchtop drill press. Jim Jim Weir shared these priceless pearls of wisdom: -However, since I'm going to a new method of framing, I'd like thoughts on what -you have used as workbench/shelving materials. The benches will be about 2' -wide and 6' long. Yes, I know, solid moulded Teflon would be best, but quick -and cheap is high on the list of attributes I'm looking for. - -Thoughts appreciated. Jim Weir (A&P/IA, CFI, & other good alphabet soup) VP Eng RST Pres. Cyberchapter EAA Tech. Counselor http://www.rst-engr.com |
| Benchtops & Shelving | Jim Weir | Home Built | 30 | March 6th 04 02:32 PM |
