Removing old antennas
Old March 18th 04, 03:21 AM
Jay Honeck
Default Removing old antennas
Is it worth the bother?
We're coming up on our annual inspection in May, and there are at least four
antennas on our bird that do nothing. I'll bet there's a few feet of cable
going to each one, too.
Does removing an antenna net you any extra speed, or is it mainly a weight
reduction thing?
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old March 18th 04, 03:25 AM
G.R. Patterson III
reduction thing?
I never saw any speed decrease when I added an antenna, so I wouldn't expect to
see an increase when I removed one. I've never added more than one at a time,
though.
George Patterson
Battle, n; A method of untying with the teeth a political knot that would
not yield to the tongue.
Old March 18th 04, 03:36 AM
Roy Smith
In article iI76c.32458$_w.542610@attbi_s53,
reduction thing?
Antennae increase drag (especially when they're attached to bugs
squashed onto the leading edge of the wing). So, yes, removing them
should result in increased airspeed. The big question is, "how much".
I think the answer tends to be "less than you'd hope".
One good clue is to read the optional equipment supplements in most
POH's. They'll typically list a half dozen different radios that could
be installed, each with their own protuberance on the outside.
Generally, under "performance changes" they'll say something like "no
significant change".
You've really got two choices. You can spend a lot of time and money
doing really careful performance measurements before and after and see
if removing them really made any difference. Or, you can just pay the
guy to take them off and be happy in your believe that you've made the
airplane faster. It certainly won't make it any slower.
Old March 18th 04, 04:21 AM
kage
"Jay Honeck" wrote in message
news:iI76c.32458$_w.542610@attbi_s53...
four
cable
reduction thing?
Jay Honeck
Iowa City, IA
Pathfinder N56993
Jay,
You have no choice. You are REQUIRED to remove inoperative equipment. Part
91.405 (c).
Best,
Karl.
BTW, the reg says the equipment must be repaired, replaced, removed or
inspected at the next required inspection. What they mean by "inspected" is
if a required inspection is due. Not just the mechanic peering at a piece of
inop equipment and letting it go for another year! This rule is regularily
ignored by the GA community. But it would never fly at a reputable repair
facility. Once the antennas are removed you will have to revise the
equipment list and weight and balance.
"Curator" N185KG, fire breathing Skywagon!
Old March 18th 04, 04:46 AM
Jim Weir
Oh, Christ. Here we go again...
"kage"
-You have no choice. You are REQUIRED to remove inoperative equipment. Part
-91.405 (c).
-Best,
-Karl.
http://www.rst-engr.com
Old March 18th 04, 02:02 PM
Stu Gotts
That's EXACTLY (word for word) what my response was going to be!
Old March 18th 04, 05:01 AM
Michelle P
They are working spares so they can Stay :-)
Michelle
four
cable
reduction thing?
Jay Honeck
Iowa City, IA
Pathfinder N56993
Jay,
91.405 (c).
Best,
Karl.
Michelle P ATP-ASEL, CP-AMEL, and AMT-A&P
"Elisabeth" a Maule M-7-235B (no two are alike)
Volunteer Pilot, Angel Flight Mid-Atlantic
Volunteer Builder, Habitat for Humanity
Old March 18th 04, 05:07 AM
G.R. Patterson III
All of these antennae work just fine, so they don't have to be removed. There's
no reg that says they have to be connected to anything.
George Patterson
Old March 20th 04, 02:02 AM
joe mamma
"kage" wrote in message ...
Jay,
91.405 (c).
Best,
Karl.
WRONG!!!!!
91.405(c)
each owner operator blah blah blah (c)shall have any inoperative
instrument or item of equipment permitted to be blah blah blah.
Inspected means. You have that piece of equipment inspected to be
sure it is still deactivated.
For an example: Say I have a Piper Arrow with inop air conditioning.
I can deactivate and placard that system. Never have it fixed. As long
as. At the next required inspection.(IE 100 hr or annual), I inspect
it to make sure it is still deactivated and placarded AND Make a
logbook entry of such.
Good to go till next inspection....
Joe A&P/IA
Old March 20th 04, 05:22 AM
kage
Dream on mamma,
Say what you want. Like I said, it is generally ignored by shade tree
mechanics working on Piper Arrows. But if you bring your Gulfstream into a
legitimate shop your inoperative equipment WILL be repaired, replaced,
removed or required inspections performed and the equipment returned to
service.
inspected"joe mamma" wrote in message
om...
Jay,
Part
91.405 (c).
Best,
Karl.
is
piece of
regularily
repair
WRONG!!!!!
91.405(c)
Joe A&P/IA
Removing water repelent from fiberglass lay-up? Roger Home Built 2 December 3rd 04 12:15 AM
Do ADF antennas need replacing if changing the receiver? [email protected] Owning 5 December 11th 03 11:13 PM
Choice of Paint for use over Copper foil Antennas Charlie Precourt Home Built 1 December 2nd 03 03:51 AM
Hidden Antennas Dick Goff Home Built 2 August 20th 03 06:23 PM
F-14 squadrons removing refueling cover plate? dave999 Military Aviation 7 August 6th 03 10:45 AM
