Bendix King KMA20 - Stuck mike open.
Old October 12th 04, 02:52 AM
Roy Page
Default Bendix King KMA20 - Stuck mike open.
I had a "mike stuck open" problem on my 1977 Piper Archer.
The PTT switch tests out fine and seems that the KMA20 audio panel is the
culprit.
I worked all the front panel switches many times and the problem has gone
away for the moment.
The mike unstuck as I was working the Marker Hi Lo switch [Extreme right]
I can't locate a either a user manual or maintenance manual.
Can any one help with suggestions on obtaining a circuit diagram so that I
can trouble shoot the electronics.
Also any tips on using and fault finding the KMA20 would be appreciated.
Thanks guys.
Roy Page
Beloit, OH 44609
Old October 12th 04, 05:18 AM
John_F
Look for wires that run tightly across sharp metal surfaces.
Look for signs of water causing corrosion.
Make sure that the mic plug is fully inserted.
On Tue, 12 Oct 2004 00:52:54 GMT, "Roy Page"
culprit.
Thanks guys.
Roy Page
Beloit, OH 44609
Old October 12th 04, 04:40 PM
James M. Knox
"Roy Page" wrote in
k.net:
the culprit.
gone away for the moment.
right] I can't locate a either a user manual or maintenance manual.
that I can trouble shoot the electronics.
appreciated.
Hmmm... Could be, but not likely.
First off, pull the KMA20 and push it back in (a time or two). Won't hurt
anything, and you never know. I am still suspecting a mechanical problem
in the wiring somewhere. UNPLUG the handheld microphone. The PTT on the
mike is wired in parallel with your other PTT, and the swinging mike cable
has a habit of wearing through the insulation internal, right at the plug.
I'm betting the problem is NOT the KMA20. [But I have been wrong once or
twice in my life. G]
jmk
value of Bendix / King klx100 mah Aviation Marketplace 1 December 19th 03 04:19 AM
Bendix King GPS Updates Matthew Waugh Instrument Flight Rules 1 August 5th 03 07:11 PM
Bendix King GPS Updates Matthew Waugh Owning 1 August 5th 03 07:11 PM
