What's going on here?
Old November 22nd 04, 12:40 AM
Jay Honeck
Default What's going on here?
Our JPI EDM-700 engine analyzer may have paid for itself today.
Here's the scenario:
Mary is PIC. During her run-up, the left mag dropped a bit more than the
right. She leaned it back (the usual fouled-plug procedure) and it smoothed
out to within specs. Still not as smooth at the right, but with less than a
75 rpm drop.
Climb out was normal, with that O-540 pulling like a tractor at over 1000
feet per minute. Life was good, especially after surviving the
Wisconsin-versus-Iowa Big Ten football game...
Upon leveling out, and getting everything cleaned up, I was messing around
with our new CO detector, which is mounted on the pilot's-side at elbow
height. (Recommendation: Don't reach across your pilot like this unless
you're married to her! :-)
As I was tinkering with it, my eyes were drawn to the EDM-700, which was
clearly showing something amiss with the #2 cylinder. EGT was over 1630
degrees (we try to keep them under 1500), and the CHT was way low -- like in
the low 200s.
We tried leaning, and enrichening, and different throttle settings, but that
cylinder stayed way out of line with all the others. Strangely, nothing
sounded amiss at all, and the engine seemed to be performing normally.
I was about to suspect something wrong with the JPI, when I suggested that
we try switching to one mag, then the other, in flight. On the right mag,
all was well -- but on the left mag, the engine started shaking, and the #2
EGT shot off the scale!
Switching back to "both" everything smoothed out. In fact, we still could
not detect anything amiss "by ear" -- but the #2 cylinder was still "out of
whack" with the others.
Since we were closer to our destination than home, we elected to continue on
and land. On the ramp Mary did a run-up, and the #2 cylinder was still
clearly not firing on the left mag. We then ran it up on "both", and leaned
it severely -- again, the usual procedure for a fouled plug.
After this it was better, but not perfect -- so we de-cowled the engine, and
checked everything thoroughly. Other than the #2 cylinder's bottom spark
plug wire being oily (actually, all the bottom wires are), I couldn't find
anything amiss. I wiggled all the wires, made sure they were not bent over
too sharply, checked all connections at the mags -- and then went to dinner.
Of course, this bothered me throughout dinner, and I really couldn't enjoy
myself.
On the return flight, with me acting as PIC, I did a VERY thorough run-up,
with a long, brutally leaned 2000 RPM test. Everything tested and ran
fine -- and remained fine all the way home, at all throttle, prop and
mixture settings.
What's going on here? We burn unleaded car gas, so it seems unlikely that
we had a lead-fouled spark plug (we haven't bought avgas in several
weeks) -- could it be a bad plug? Or a bad spark plug wire?
Can a mag fail in such a way as to only hinder a single spark plug from
firing?
I'm going to call my A&P tomorrow to have him check it over, but anyone got
any ideas?
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old November 22nd 04, 12:51 AM
Chris
"Jay Honeck" wrote in message
news:cI9od.66570$V41.11973@attbi_s52...
smoothed out to within specs. Still not as smooth at the right, but with
less than a 75 rpm drop.
in the low 200s.
that cylinder stayed way out of line with all the others. Strangely,
nothing sounded amiss at all, and the engine seemed to be performing
normally.
#2 EGT shot off the scale!
of whack" with the others.
on and land. On the ramp Mary did a run-up, and the #2 cylinder was still
leaned it severely -- again, the usual procedure for a fouled plug.
and checked everything thoroughly. Other than the #2 cylinder's bottom
spark plug wire being oily (actually, all the bottom wires are), I
couldn't find anything amiss. I wiggled all the wires, made sure they
were not bent over too sharply, checked all connections at the mags -- and
myself.
mixture settings.
that we had a lead-fouled spark plug (we haven't bought avgas in several
firing?
got any ideas?
I would guess you have a bad plug. Something similar happened to me when
landing at Everglades City in Fl.
Putting on some power to turn and back track, the engine started running
rough. I went through the leaning process on the ramp and found the problem
went away when running on only one set of mags.
As it was a rental plane, an engineer came down from Naples and in 5 mins
determined that it was a bad plug just using that chalk that changes colour
when it gets hot.
He isolated the problem, changed the plug and the problem disappeared.
Mind you flying the plane back to Naples had me listening out for every
single sound.
Glad I managed to spot the landing and not need to go around.
Chris
Old November 22nd 04, 01:32 AM
Matt Whiting
75 rpm drop.
the low 200s.
myself.
mixture settings.
firing?
any ideas?
I'm guessing your airplane is female and just doesn't like your wife
being PIC. :-)
Matt
Old November 22nd 04, 01:52 AM
tony roberts
Hi Jay
High EGT an low CHT one cylinder:
Fouled plug,
Burned valve,
Broken ring,
Bad mag wire
That's according to the trouble shooting guidwe for my EI engine
analyzer.
HTH
Tony
Tony Roberts
PP-ASEL
VFR OTT
Night
Cessna 172H C-GICE
Old November 22nd 04, 07:57 AM
John Clonts
"tony roberts" wrote in message news:nospam-ABD905.16523021112004@shawnews...
Hi Jay
Fouled plug,
Burned valve,
Broken ring,
Bad mag wire
analyzer.
Not likely to be the valve or the ring since it performed differently on one mag than the other. I would
suggest swapping the plugs and noting whether the problem moved to the other mag or not. Testing the wires is
an easy quick test with an HV tester...when I recently had a similar problem it turned out to be a spark plug
wire.
Cheers,
John Clonts
Temple, Texas
N7NZ
Old November 22nd 04, 06:05 AM
john smith
What Tony said.
Have you downloaded the data yet?
Old November 22nd 04, 01:37 PM
Almarz
Okay, after looking at all the replies, you need to stop and analyze
the info given to you on the instrument. If there was a bad plug,
when he switched mags, (he should have leaned it out), the temps would
drop because there was no fire. Same with any other ignition part.
If there was no fuel getting to the chamber, same thing. What you're
seeing is a bad valve, probably exhaust.
Go do another run up and on each mag lean the **** out of it until
it's just about running smooth as it can be with the **** leaned out
of it, then watch the engine instrument. If the temps drop out of a
certain cylinder on a certain mag, you have a plug (or ignition)
problem. That'll be the first test. If that doesn't happen, take her
back and check compression on the cylinder.
Keep us posted.
On Sun, 21 Nov 2004 23:40:56 GMT, "Jay Honeck"
75 rpm drop.
the low 200s.
myself.
mixture settings.
firing?
any ideas?
Old November 22nd 04, 02:00 PM
Jay Honeck
How could a bad valve on #2 work okay on "both" mags -- but not on the left
mag?
Jay Honeck
Iowa City, IA
Pathfinder N56993
Old November 22nd 04, 07:58 PM
Aaron Coolidge
Jay Honeck wrote:
: Okay, after looking at all the replies, you need to stop and analyze
: the info given to you on the instrument. If there was a bad plug,
: when he switched mags, (he should have leaned it out), the temps would
: drop because there was no fire. Same with any other ignition part.
: If there was no fuel getting to the chamber, same thing. What you're
: seeing is a bad valve, probably exhaust.
: How could a bad valve on #2 work okay on "both" mags -- but not on the left
: mag?
It can't, you've got a bad plug or wire. Pull the plug and clean it. Spray
the oily plug wires with contact cleaner and clean the inside of the plug
where the wire goes. Put on silicone rocker cover gaskets to prevent future
oil leaks.
Aaron Coolidge
Old November 23rd 04, 12:03 AM
John Galban
"Jay Honeck" wrote in message news:Mplod.135318$R05.23672@attbi_s53...
mag?
I think there's some confusion about your troubleshooting. In the
original post, I (possibly by mistake) assumed that when you switched
to the rough mag, the #2 EGT "shot off the scale" to the low end (i.e.
cold). If you're saying it shot off the high end of the scale, this
would not be the kind of reading you'd expect from a cylinder that is
not firing.
On the other hand, like you, I have a hard time imagining how a
stuck valve would behave differently by switching the mags. If an
exhaust valve is stuck open, your EGT should shoot upward off the
scale, but it shouldn't go back to normal by switching mags.
If the symptom is truly that the #2 EGT shoots up when switching to
the rough mag, then something isn't adding up.
