A corner of the wing step "tread" is peeling up on my Cherokee 180. Is there
a particular glue or epoxy to use/stay away from? I can just see a big chemical hole being eaten right through my wing... ;-) Thanks! -- PP-ASEL, instrument |
On Fri, 26 Nov 2004 21:32:53 GMT, "Steven Barnes"
wrote: A corner of the wing step "tread" is peeling up on my Cherokee 180. Is there a particular glue or epoxy to use/stay away from? I can just see a big chemical hole being eaten right through my wing... ;-) Thanks! There's stuff made for that specifically. I think it's calle Wing Walk. Spruce will have what you need. HTH z |
Steve,
Is it strips or one "piece"? if it is one piece it was painted on wing walk compound. Strips 3M Scotch 1300L. Michelle Steven Barnes wrote: A corner of the wing step "tread" is peeling up on my Cherokee 180. Is there a particular glue or epoxy to use/stay away from? I can just see a big chemical hole being eaten right through my wing... ;-) Thanks! -- Michelle P ATP-ASEL, CP-AMEL, and AMT-A&P "Elisabeth" a Maule M-7-235B (no two are alike) Volunteer Pilot, Angel Flight Mid-Atlantic Volunteer Builder, Habitat for Humanity |
It's like 2 pieces. Each about 2.5 feet long & 1.5 feet wide. They "overlap"
a bit right in front of the door jam. Where the top/front one lays on top of the bottom/back one, it's rolling up a bit on the outside corner. I've got a billion pics of the plane but no good ones of the wing tread. "Michelle P" wrote in message k.net... Steve, Is it strips or one "piece"? if it is one piece it was painted on wing walk compound. Strips 3M Scotch 1300L. Michelle Steven Barnes wrote: A corner of the wing step "tread" is peeling up on my Cherokee 180. Is there a particular glue or epoxy to use/stay away from? I can just see a big chemical hole being eaten right through my wing... ;-) Thanks! -- Michelle P ATP-ASEL, CP-AMEL, and AMT-A&P "Elisabeth" a Maule M-7-235B (no two are alike) Volunteer Pilot, Angel Flight Mid-Atlantic Volunteer Builder, Habitat for Humanity |
wrote: A corner of the wing step "tread" is peeling up on my Cherokee 180. Is there a particular glue or epoxy to use/stay away from? I can just see a big chemical hole being eaten right through my wing... ;-) I just had my Cherokee painted this summer. They used a single-piece wing walk. It had the adhesive already installed - just had to clean the surface, peel, and apply. -Nathan |
"Nathan Young" wrote in message
... On Fri, 26 Nov 2004 21:32:53 GMT, "Steven Barnes" wrote: A corner of the wing step "tread" is peeling up on my Cherokee 180. Is there a particular glue or epoxy to use/stay away from? I can just see a big chemical hole being eaten right through my wing... ;-) I just had my Cherokee painted this summer. They used a single-piece wing walk. It had the adhesive already installed - just had to clean the surface, peel, and apply. .... and then you end up with peeling problems on the wing walk. The stick on wing walks are crap, they tend to peel. They should be painted on... |
On Sun, 28 Nov 2004 15:52:04 GMT, "Mike V." wrote:
"Nathan Young" wrote in message .. . On Fri, 26 Nov 2004 21:32:53 GMT, "Steven Barnes" wrote: A corner of the wing step "tread" is peeling up on my Cherokee 180. Is there a particular glue or epoxy to use/stay away from? I can just see a big chemical hole being eaten right through my wing... ;-) I just had my Cherokee painted this summer. They used a single-piece wing walk. It had the adhesive already installed - just had to clean the surface, peel, and apply. ... and then you end up with peeling problems on the wing walk. The stick on wing walks are crap, they tend to peel. They should be painted on... Time will tell. 4 months and all is well ![]() |
| Thread Tools | |
| Display Modes | |
