new cleaning product: Simple Green for aircraft
Old February 9th 05, 06:58 PM
Default new cleaning product: Simple Green for aircraft
Anybody try this (rather expensive) new product (approved for
aircraft)? In particular, it's advertised as OK for aluminum, rubber
and plastic (unlike mineral spirits).
http://industrial.simplegreen.com/ind_prod_ext_mor.php
Old February 9th 05, 07:45 PM
Paul Anton
If left in the faying surfaces, it WILL cause corrosion.
Try this yourself, take a small square of new shiny aluminum and leave it in
Simple Green for a day or so.
Old February 10th 05, 02:41 PM
OtisWinslow
Try WashWaxAll. I've tried and wasn't particularly impressed by Simple
Green. Have
used WWA for quite a while.
http://www.washwax.com/
Old February 11th 05, 09:05 PM
Mike Rapoport
I have some but haven't tried it yet.
Mike
MU-2
Old February 13th 05, 09:00 AM
Roger
On Fri, 11 Feb 2005 20:05:24 GMT, "Mike Rapoport"
Just don't get it where it can't be washed off or out. it will
corrode, but then again I've seen people cleaning their airplanes with
Formula 7, or is it 9 over at Oshkosh. That stuff has Ammonia in it
and will corrode Aluminum in a heartbeat.
it does clean well, but if no flushed off thoroughly it can be
expensive.
www.rogerhalstead.com
Mike
MU-2
Old February 13th 05, 03:50 PM
Mike Rapoport
We are talking about different products. The simple green for aircraft
doesn't corrode aluminium.
Mike
MU-2
"Roger" wrote in message
expensive.
Mike
MU-2
roups.com...
Old February 14th 05, 04:05 AM
Roger
On Sun, 13 Feb 2005 14:50:16 GMT, "Mike Rapoport"
I have a bottle of "Simple Green(TM) here and it will turn polished
Aluminum white if not thoroughly rinsed. That leads me to believe it
would not be a good idea to use it in areas where it could not be
thoroughly flushed.
Or do they make one version specifically for aircraft?
Mike
MU-2
expensive.
Mike
MU-2
groups.com...
Old February 14th 05, 04:37 AM
John Clonts
thoroughly flushed.
Yes, read the subject line, and the link in the original post!
Belly Cleaning...? zatatime Owning 48 July 6th 04 05:33 AM
