FAA grants AOPA demand for investigation into Meigs closure
Old February 12th 04, 04:58 PM
Larry Dighera
Default FAA grants AOPA demand for investigation into Meigs closure
What do airmen feel the appropriate penalty might be?
http://www.aopa.org/whatsnew/newsite...04-1-087x.html
Feb. 11 — AOPA's claim that the city of Chicago violated federal law
and aviation regulations when it shut down Meigs Field last March has
merit, says the FAA, and will be investigated. AOPA filed a formal
complaint following the destruction of Meigs's runway on Mayor Richard
M. Daley's order, claiming the city failed to provide adequate notice,
as required by the FARs. The complaint will not result in the
airport's reopening but can lead to the mayor and the city being
punished for their actions.
"AOPA intends to push for the appropriate penalty to be imposed on the
city," said AOPA President Phil Boyer. "Mayor Daley and any other
state or local official who may want to follow Daley's lead must be
made to understand they cannot unilaterally change the National
Airspace System."
The manager of the FAA's Enforcement Division sent a letter of
response to AOPA's complaint against both the mayor and the city,
saying "reasonable grounds exist" to begin an informal investigation
into the allegations.
AOPA maintains that Daley and the city of Chicago violated both the
U.S. Code and Federal Aviation Regulations. The U.S. Code states that
an airport or landing area not involving the expenditure of federal
money may be altered substantially "only if the Administrator of the
Federal Aviation Administration is given reasonable prior notice, so
that the Administrator may provide advice on the effects" of the
alteration. In order for the administrator to carry out that
obligation, Federal Aviation Regulations state that anyone intending
to alter a runway, deactivate a runway or airport, or change the
status of an airport must submit notice of that intent at least 90
days prior to taking such action.
The FARs do provide for immediate emergency action, such as in the
case of national security, which was Daley's original claim. However,
even in the case of an emergency, if the airport has a charted
instrument approach, which Meigs Field did, a minimum of 30 days'
notice must be given.
Old February 12th 04, 05:05 PM
G.R. Patterson III
A ban on holding any type of political post for the remainder of his life.
George Patterson
A diplomat is a person who can tell you to go to hell in such a way that
you look forward to the trip.
Old February 12th 04, 06:59 PM
Larry Dighera
On Thu, 12 Feb 2004 16:05:13 GMT, "G.R. Patterson III"
wrote in Message-Id:
He'd just run his wife as a candidate. But the penalty is to levied
against the city of Chicago if I'm not mistaken.
Old February 12th 04, 10:41 PM
Andrew Gideon
Fine the city all funds paid for Meigs over all time multiplied by some
"penalty clause" factor.
This would never happen again.
- Andrew
Old February 16th 04, 12:33 PM
Larry Dighera
On Thu, 12 Feb 2004 16:41:17 -0500, Andrew Gideon
ne.com:
- Andrew
Unfortunately, it looks like the fine, _IF_ Daley is found guilty, is
going to be $1,100.00 per day. But the real question here is, why did
it take AOPA to demand FAA enforce the notice provision requirements?
Or, what prevented the FAA from imposing the mandated fine on Chicago
for Daily's hubris in the first place? Does the Chicago boss have the
Administrator under mob control?
AVflash Volume 10, Number 08a -- February 16, 2004
CHICAGO FACES LITTLE FINES FOR MEIGS
The city of Chicago could face almost $100,000 in fines for its sudden
closure of Meigs Field last March 30 but an incipient FAA
investigation won't bring the beloved airport back to life. As AVweb
told you last Thursday, the FAA has agreed (almost a year later) to an
investigation into the late-night destruction of Meigs' lone runway
while aircraft were parked on the ramp. The closure allegedly violated
notice provisions, which require an airport owner to provide at least
30 and up to 90 days of warning to the FAA that it intends to close an
airport. Mayor Richard Daley at midnight sent a battalion of heavy
equipment, under police guard, into the sealed-off airport and ordered
workmen to carve large X's out of the runway.
http://www.avweb.com/eletter/archive...ll.html#186723
....CLOSURE NOTICE NOT SUPPLIED...
Soon after the excavators had done their work, the FAA acknowledged
that Daley had the legal right to close the airport. However, federal
law requires that an airport owner give at least 90 days of notice. In
an emergency, or for national security concerns, only 30 days of
notice is required if the airport has a published instrument approach,
which Meigs had. Chicago notified the FAA of Meigs' closure the day
after the runway was wrecked. If the FAA finds Chicago guilty, it can
fine the city $1,100 per day for anywhere from two to 90 days of
absent notice.
http://www.avweb.com/eletter/archive...ll.html#186724
....FRIENDS LOOK FOR BRIGHT SIDE
Chicago officials have vigorously defended Meigs' closure and the
relatively small fine isn't going to change their minds on the future
of the airport. However, Meigs supporters did their best to draw what
encouragement they could from the announcement of the investigation.
"It's good there will be an investigation and the public will hear
about it," said Rachel Goodstein, president of Friends of Meigs (FOM).
The group also hopes the investigation will raise the profile of an
alternative plan they've devised for Meigs that would include a park
and an airport.
http://www.avweb.com/eletter/archive...ll.html#186725
Old February 13th 04, 12:34 AM
G.R. Patterson III
But the penalty is to levied against the city of Chicago if I'm not mistaken.
You're probably right. AOPA talks about "the mayor and the city being punished",
but then talks about the "appropriate penalty to be imposed on the city".
George Patterson
Old February 14th 04, 06:15 PM
Cecil E. Chapman
Take the "Mob Boss of The Month" award certificate away from him ... ;-)
Good Flights!
Cecil
PP-ASEL
Check out my personal flying adventures complete with pictures and text at:
www.bayareapilot.com
"I fly because it releases my mind from the tyranny of petty things."
- Antoine de Saint-Exupery -
"We who fly, do so for the love of flying. We are alive in the air with
this miracle that lies in our hands and beneath our feet"
- Cecil Day Lewis -
George Patterson
that
Old February 12th 04, 05:50 PM
Teacherjh
Turn his house into a heliport.
Jose
(for Email, make the obvious changes in my address)
Old February 12th 04, 06:06 PM
Bob Chilcoat
Make him live in the derelict FBO through a Chicago winter without any
utilities.
Actually, I like George's suggestion better.
Bob (Chief Pilot, White Knuckle Airways)
"Teacherjh" wrote in message
Jose
Old February 12th 04, 06:22 PM
Big John
Larry
Ban him from flying on any aircraft for 10 years. Let him ride the
bus.
Big John
On Thu, 12 Feb 2004 15:58:28 GMT, Larry Dighera
Airspace System."
AOPA Sells-Out California Pilots in Military Airspace Grab? Larry Dighera Instrument Flight Rules 12 April 26th 04 07:12 PM
AOPA and ATC Privatization Chip Jones Instrument Flight Rules 139 November 12th 03 09:26 PM
AOPA and ATC Privatization Chip Jones Piloting 133 November 12th 03 09:26 PM
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) Rich Stowell Piloting 25 September 11th 03 02:27 PM
