Here's a silly question: Is there any way to convert a t-hangar's
manually opening bi-fold door to a motorized one? I just rented a t-hangar that uses a circular chain hanging off a large pulley near the top of the hangar to control the door. The chain must be pulled thirty to forty times to fully open or close the bi-fold door. Perhaps some type of conversion to an automatic garage door opener? Has anyone ever done anything like this? -- Peter |
Peter R. wrote: Here's a silly question: Is there any way to convert a t-hangar's manually opening bi-fold door to a motorized one? I just rented a t-hangar that uses a circular chain hanging off a large pulley near the top of the hangar to control the door. The chain must be pulled thirty to forty times to fully open or close the bi-fold door. Perhaps some type of conversion to an automatic garage door opener? Has anyone ever done anything like this? Or ditch the stupid crappy bi fold completely and get a hydroswing to really go first class. |
manually opening bi-fold door to a motorized one? If you figure this one out, please let us all know. Our hangar is over 40 years old, and it would sure be nice to just push a button to open the door. Of course, you'd put my kids out of business. (We pay them 25 cents for each opening...) -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
Jay Honeck wrote:
Of course, you'd put my kids out of business. (We pay them 25 cents for each opening...) 25 cents? Wow, that cheap labor. ![]() -- Peter |
"Peter R." wrote in message
... Jay Honeck wrote: Of course, you'd put my kids out of business. (We pay them 25 cents for each opening...) 25 cents? Wow, that cheap labor. ![]() Assuming 1 minute to open the door, that's 60 * 0.25 = $15 an hour. Paul |
"Peter R." wrote: Perhaps some type of conversion to an automatic garage door opener? Garage door openers drive a sprocket that operates a circular chain. Some of the older units had a block on the chain that tripped a switch when the door was raised. This block could be adjusted to fine-tune the system. My Genie units do not have this. I assume (but do not know) that they simply pull the chain for a fixed distance (most doors are 7' tall). So. Measure the distance you have to pull your chain to open the hangar door. Work out the ratio between that and 7'. Rig a reduction gear out of two appropriately sized pulleys and a belt and drive that from a chain driven by a garage door opener. You can probably use your existing chain pulley as one pulley in the reduction gear and mount the whole thing high on the wall. George Patterson If you want to know God's opinion of money, just look at the people he gives it to. |
G.R. Patterson III wrote:
Garage door openers drive a sprocket that operates a circular chain. Some of the older units had a block on the chain that tripped a switch when the door was raised. This block could be adjusted to fine-tune the system. My Genie units do not have this. I assume (but do not know) that they simply pull the chain for a fixed distance (most doors are 7' tall). So. Measure the distance you have to pull your chain to open the hangar door. Work out the ratio between that and 7'. Rig a reduction gear out of two appropriately sized pulleys and a belt and drive that from a chain driven by a garage door opener. You can probably use your existing chain pulley as one pulley in the reduction gear and mount the whole thing high on the wall. Thanks, George. I might just try this project. -- Peter |
Peter R. wrote in message ...
G.R. Patterson III wrote: Garage door openers drive a sprocket that operates a circular chain. Some of the older units had a block on the chain that tripped a switch when the door was raised. This block could be adjusted to fine-tune the system. My Genie units do not have this. I assume (but do not know) that they simply pull the chain for a fixed distance (most doors are 7' tall). So. Measure the distance you have to pull your chain to open the hangar door. Work out the ratio between that and 7'. Rig a reduction gear out of two appropriately sized pulleys and a belt and drive that from a chain driven by a garage door opener. You can probably use your existing chain pulley as one pulley in the reduction gear and mount the whole thing high on the wall. Thanks, George. I might just try this project. Actually many residential garage doors will open up a 10' high door when they have the right length rail & chain. So if your door is 10' tall you do not need to change the reduction at all, but if your door is taller then 10' you would have to change the reduction. However if you change the reduction very much (depends on door height) you are also going to increase the speed that the door opens which may result in an unsafe operating condition & is also going to put more wear & tear on the door. Residential garage door openers are not designed for this type of use & for your own safety is not something I would personally recommend doing. Doordoc |
Doordoc wrote: So if your door is 10' tall you do not need to change the reduction at all, but if your door is taller then 10' you would have to change the reduction. Since this is a folding door, it's not a matter of the door height at all. It's purely a matter of how much of the chain on his door he needs to pull to raise it versus how much chain the opener pulls before it hits its limit switch. If the limit switch on the GDO is adjustable, there's no need for a reduction mechanism at all. George Patterson If you want to know God's opinion of money, just look at the people he gives it to. |
"Doordoc" wrote in message om... Peter R. wrote in message ... G.R. Patterson III wrote: Garage door openers drive a sprocket that operates a circular chain. Some of the older units had a block on the chain that tripped a switch when the door was raised. This block could be adjusted to fine-tune the system. My Genie units do not have this. I assume (but do not know) that they simply pull the chain for a fixed distance (most doors are 7' tall). So. Measure the distance you have to pull your chain to open the hangar door. Work out the ratio between that and 7'. Rig a reduction gear out of two appropriately sized pulleys and a belt and drive that from a chain driven by a garage door opener. You can probably use your existing chain pulley as one pulley in the reduction gear and mount the whole thing high on the wall. Thanks, George. I might just try this project. Actually many residential garage doors will open up a 10' high door when they have the right length rail & chain. So if your door is 10' tall you do not need to change the reduction at all, but if your door is taller then 10' you would have to change the reduction. However if you change the reduction very much (depends on door height) you are also going to increase the speed that the door opens which may result in an unsafe operating condition & is also going to put more wear & tear on the door. Residential garage door openers are not designed for this type of use & for your own safety is not something I would personally recommend doing. Doordoc I would say, that a proper application of a residential opener could be safe, and reliable. It would take some doing. Gear the output of the opener, so that the door moves at a speed comparable to how fast the door would move, if it were being opened manually. This would mean a much longer cycle time than the electric opener was designed for, so the original limit switches would not work. A Craftsman (Sears) opener, of older design had built in limit switches run by a threaded rod, to control the start and stop locations, and thus times. Keep the concept, but instead of pushing the switches using the built in threaded rod, relocate new switches, so the doors physically push on the new switches to start, stop, and reverse the movement. I have my show sawdust system run by an old opener. The only parts I had to buy were two new limit switches, and a bit of wire. The two new switches are actuated by the threaded rod, but the original switches still start and stop the opener. The new switches hold in the coil for the magnetic starter circuit, and still let the pushbutton stations operate normally when the remote is not being used. Good luck. Contact me, if you want to make a go at it. I do happen to have one more old opener on hand, :-)) -- Jim in NC --- Outgoing mail is certified Virus Free. Checked by AVG anti-virus system (http://www.grisoft.com). Version: 6.0.737 / Virus Database: 491 - Release Date: 8/11/2004 |
