I fly a an "aircraft which was not originally certificated
with an engine-driven electrical system" under 91.215. I have no transponder, but do carry a handheld radio. I was recently told by an FAA designated pilot examiner that I cannot fly under the outer ring of the local class C airspace. I know I can't enter the class C. I can't find anything in 91.215 (or elsewhere) that says I can't fly under the outer ring of a class C. 91.215(b)(1) says I can't fly into the class C (or any A or B) 91.215(b)(2 and (3) ) apply only to 30nm Mode C veil ops (not applicable here) and say I have to stay below the top of the class C or B (or 10K' if lower) when inside a veil. 91.215(b)(4) says I have to stay over 10K' if overflying the class C and there's no mode C veil. 91.215(b)(5) doesn't apply. Am I missing something or is he wrong? It looks like I can fly under Class B or C airspace even when there is a mode C veil. |
bcjames wrote:
I fly a an "aircraft which was not originally certificated with an engine-driven electrical system" under 91.215. I have no transponder, but do carry a handheld radio. I was recently told by an FAA designated pilot examiner that I cannot fly under the outer ring of the local class C airspace. I know I can't enter the class C. I can't find anything in 91.215 (or elsewhere) that says I can't fly under the outer ring of a class C. 91.215(b)(1) says I can't fly into the class C (or any A or B) 91.215(b)(2 and (3) ) apply only to 30nm Mode C veil ops (not applicable here) and say I have to stay below the top of the class C or B (or 10K' if lower) when inside a veil. 91.215(b)(4) says I have to stay over 10K' if overflying the class C and there's no mode C veil. 91.215(b)(5) doesn't apply. Am I missing something or is he wrong? It looks like I can fly under Class B or C airspace even when there is a mode C veil. I think your DE is wrong. I fly under CCAS and CBAS all the time. They would be denying access to too many airports. Sec. 91.215 - ATC transponder and altitude reporting equipment and use. (a) All airspace: U.S.-registered civil aircraft. For operations not conducted under part 121 or 135 of this chapter, ATC transponder equipment installed must meet the performance and environmental requirements of any class of TSO-C74b (Mode A) or any class of TSO-C74c (Mode A with altitude reporting capability) as appropriate, or the appropriate class of TSO-C112 (Mode S). (b) All airspace. Unless otherwise authorized or directed by ATC, no person may operate an aircraft in the airspace described in paragraphs (b)(1) through (b)(5) of this section, unless that aircraft is equipped with an operable coded radar beacon transponder having either Mode 3/A 4096 code capability, replying to Mode 3/A interrogations with the code specified by ATC, or a Mode S capability, replying to Mode 3/A interrogations with the code specified by ATC and intermode and Mode S interrogations in accordance with the applicable provisions specified in TSO C-112, and that aircraft is equipped with automatic pressure altitude reporting equipment having a Mode C capability that automatically replies to Mode C interrogations by transmitting pressure altitude information in 100-foot increments. This requirement applies -- (1) All aircraft. In Class A, Class B, and Class C airspace areas; (2) All aircraft. In all airspace within 30 nautical miles of an airport listed in appendix D, section 1 of this part from the surface upward to 10,000 feet MSL; (3) Notwithstanding paragraph (b)(2) of this section, any aircraft which was not originally certificated with an engine-driven electrical system or which has not subsequently been certified with such a system installed, balloon or glider may conduct operations in the airspace within 30 nautical miles of an airport listed in appendix D, section 1 of this part provided such operations are conducted -- (i) Outside any Class A, Class B, or Class C airspace area; and (ii) Below the altitude of the ceiling of a Class B or Class C airspace area designated for an airport or 10,000 feet MSL, whichever is lower; and (4) All aircraft in all airspace above the ceiling and within the lateral boundaries of a Class B or Class C airspace area designated for an airport upward to 10,000 feet MSL; and (5) All aircraft except any aircraft which was not originally certificated with an engine-driven electrical system or which has not subsequently been certified with such a system installed, balloon, or glider -- -- (i) In all airspace of the 48 contiguous states and the District of Columbia at and above 10,000 feet MSL, excluding the airspace at and below 2,500 feet above the surface; and (ii) In the airspace from the surface to 10,000 feet MSL within a 10-nautical-mile radius of any airport listed in appendix D, section 2 of this part, excluding the airspace below 1,200 feet outside of the lateral boundaries of the surface area of the airspace designated for that airport. (c) Transponder-on operation. While in the airspace as specified in paragraph (b) of this section or in all controlled airspace, each person operating an aircraft equipped with an operable ATC transponder maintained in accordance with §91.413 of this part shall operate the transponder, including Mode C equipment if installed, and shall reply on the appropriate code or as assigned by ATC. (d) ATC authorized deviations. Requests for ATC authorized deviations must be made to the ATC facility having jurisdiction over the concerned airspace within the time periods specified as follows: (1) For operation of an aircraft with an operating transponder but without operating automatic pressure altitude reporting equipment having a Mode C capability, the request may be made at any time. (2) For operation of an aircraft with an inoperative transponder to the airport of ultimate destination, including any intermediate stops, or to proceed to a place where suitable repairs can be made or both, the request may be made at any time. (3) For operation of an aircraft that is not equipped with a transponder, the request must be made at least one hour before the proposed operation. (Approved by the Office of Management and Budget under control number 2120-0005) [Doc. No. 18334, 54 FR 34304, Aug. 18, 1989, as amended by Amdt. 91-221, 56 FR 469, Jan. 4, 1991; Amdt. 91-227, 56 FR 65660, Dec. 17, 1991; Amdt. 91-227, 7 FR 328, Jan. 3, 1992; Amdt. 91-229, 57 FR 34618, Aug. 5, 1992; Amdt. 91-267, 66 FR 21066, Apr. 27, 2001] |
john smith wrote:
I think your DE is wrong. I fly under CCAS and CBAS all the time. They would be denying access to too many airports. I've read 91.215 until my eyes are bleary, and I think he's wrong too. You say you fly under CCAS and CBAS, all the time, but is that without a transponder? |
bcjames wrote:
john smith wrote: I think your DE is wrong. I fly under CCAS and CBAS all the time. They would be denying access to too many airports. I've read 91.215 until my eyes are bleary, and I think he's wrong too. You say you fly under CCAS and CBAS, all the time, but is that without a transponder? 1945 Aeronca 7AC |
bcjames wrote:
I fly a an "aircraft which was not originally certificated with an engine-driven electrical system" under 91.215. I have no transponder, but do carry a handheld radio. I was recently told by an FAA designated pilot examiner that I cannot fly under the outer ring of the local class C airspace. I know I can't enter the class C. I can't find anything in 91.215 (or elsewhere) that says I can't fly under the outer ring of a class C. 91.215(b)(1) says I can't fly into the class C (or any A or B) 91.215(b)(2 and (3) ) apply only to 30nm Mode C veil ops (not applicable here) and say I have to stay below the top of the class C or B (or 10K' if lower) when inside a veil. 91.215(b)(4) says I have to stay over 10K' if overflying the class C and there's no mode C veil. 91.215(b)(5) doesn't apply. Am I missing something or is he wrong? It looks like I can fly under Class B or C airspace even when there is a mode C veil. http://members.eaa.org/home/homebuil...%20Veil.ht ml |
john smith wrote:
http://members.eaa.org/home/homebuil...%20Veil.ht ml That link's mostly about flying in the veil, not in the veil under the outer ring or under an outer ring where there is no veil. I'd feel a bit more comfortable if I got some more opinions from the "FAR experts" here before I go challenging a designated examiner. |
bcjames wrote:
john smith wrote: http://members.eaa.org/home/homebuil...%20Veil.ht ml That link's mostly about flying in the veil, not in the veil under the outer ring or under an outer ring where there is no veil. I'd feel a bit more comfortable if I got some more opinions from the "FAR experts" here before I go challenging a designated examiner. I thought this was pretty clear, especially (i)... "(3) Notwithstanding paragraph (b)(2) of this section, any aircraft which was not originally certificated with an engine-driven electrical system or which has not subsequently been certified with such a system installed, balloon or glider may conduct operations in the airspace within 30 nautical miles of an airport listed in appendix D, section 1 of this part provided such operations are conducted - (i) Outside any Class A, Class B, or Class C airspace area; and (ii) Below the altitude of the ceiling of a Class B or Class C airspace area designated for an airport or 10,000 feet MSL, whichever is lower;" |
I live on a private airstrip within the Mode C veil of DFW. We have 3 Piper
Cubs based here and they have been flying without an electrical system or transponder, within the 30nm veil but underneath the Class B airspace, for many, many years. Stay out of class B and you'll be OK. Mike "bcjames" wrote in message ... john smith wrote: http://members.eaa.org/home/homebuil...o%20Radio%20No %20Transponder%20Operations%20in%20Class%20D%20Air space%20in%20a%20Mode%20C% 20Veil.html That link's mostly about flying in the veil, not in the veil under the outer ring or under an outer ring where there is no veil. I'd feel a bit more comfortable if I got some more opinions from the "FAR experts" here before I go challenging a designated examiner. |
"bcjames" wrote in message news ![]() I fly a an "aircraft which was not originally certificated with an engine-driven electrical system" under 91.215. I have no transponder, but do carry a handheld radio. I was recently told by an FAA designated pilot examiner that I cannot fly under the outer ring of the local class C airspace. I know I can't enter the class C. I can't find anything in 91.215 (or elsewhere) that says I can't fly under the outer ring of a class C. 91.215(b)(1) says I can't fly into the class C (or any A or B) 91.215(b)(2 and (3) ) apply only to 30nm Mode C veil ops (not applicable here) and say I have to stay below the top of the class C or B (or 10K' if lower) when inside a veil. 91.215(b)(4) says I have to stay over 10K' if overflying the class C and there's no mode C veil. 91.215(b)(5) doesn't apply. Am I missing something or is he wrong? It looks like I can fly under Class B or C airspace even when there is a mode C veil. You're missing nothing, he's wrong. |
| Thread Tools | |
| Display Modes | |
| Two airspace classes for one airspace? (KOQU) | John R | Piloting | 8 | June 30th 04 05:46 AM |
| Overlapping class C & D | Andrew Sarangan | Piloting | 14 | May 6th 04 05:08 AM |
| when does a "remain clear" instruction end? | Arden Prinz | Piloting | 171 | March 2nd 04 01:26 AM |
| "I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 10th 04 12:35 AM |
| USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 04:17 PM |
