Leaning for taxi
Old September 6th 04, 01:46 AM
Jim Rosinski
Default Leaning for taxi
Earlier this summer I had a problem with a 400 rpm or so mag drop
during runup. Leaning aggressively at 2100 rpm solved the problem, but
it recurred on numerous occasions. I tried leaning aggressively during
all taxi operations, to the point that the engine would barely run,
and that seems to have solved the problem. No unacceptable mag drop
now for the past month. And a lower throttle setting can be used to
achieve the same taxi rpm as in the past, where the leaning procedure
was "pull the mixture out an inch or so from full rich" (my home base,
2V2, is just over 5000 feet elevation). But I still use the same "lean
to peak rpm then enrichen slightly" pre-takeoff procedure as I always
have at this altitude.
What do folks think of this procedure? Can it harm the engine? It's a
Lycoming O320-D2G in a Skyhawk. Thanks in advance.
Jim Rosinski
N3825Q
Old September 6th 04, 02:58 AM
Michael 182
Hi Jim,
I'm at 2V2 as well. I lean for taxi in my TR-182, (IO-540) although not as
aggressively as you seem to. Full rich for takeoff, because of the turbo.
By the way, I'm always looking for a safety pilot if you want to trade some
time...
Michael
"Jim Rosinski" wrote in message
om...
Jim Rosinski
N3825Q
Old September 6th 04, 03:05 AM
The Weiss Family
om...
Jim Rosinski
N3825Q
A buddy at work and I are both pilots, and we rent two different Skyhawks.
He told be about a similar experience.
His instructor (and owner) told him that a plug in one cylinder kept
fouling, and at runup, put it up to 2500 for 20 seconds to clear it out.
I don't know if this is at all similar, but just rang a bell for some
reason...
Adam
Old September 6th 04, 03:10 AM
Bob Gardner
"Full rich for taxi" is an anachronism. Always lean for taxi.
Bob Gardner
om...
Jim Rosinski
N3825Q
Old September 6th 04, 07:59 PM
Robert M. Gary
"Bob Gardner" wrote in message ...
The test pilot for Mooney said the lawyers made them put that on the
checklist because they were afraid someone would forget and take off
with the mixture leaned. However, if you lean properly, you could
never get anywhere near takeoff power when leaned. I lean so that
additional throttle does not cause any increase in RPM. It took me 3
plug cleanings to figure this out. I've now never had a plug cleaned
outside of annual.
-Robert
Old September 7th 04, 07:19 PM
Bob Gardner
If you forget to go to full rich for takeoff, the engine should quit (or at
least complain) when takeoff power is applied. I agree with "the lawyers
made me do it."
Bob
om...
outside of annual.
-Robert
Old September 6th 04, 05:04 AM
Ben Jackson
I started doing this when I bought my plane. Eventually I quit pushing
the mixture to full rich at start. I only push it in about an inch now
when it first catches, and I don't advance it until I do the runup.
Ben Jackson
http://www.ben.com/
Old September 6th 04, 05:44 AM
Casey Wilson
om...
Summertime density altitude at KEDW is almost always over 5Kft.
We pull the mixture out before we leave the chocks.
Old September 7th 04, 09:01 AM
Bela P. Havasreti
On Sun, 05 Sep 2004 23:05:18 -0600, Scott D. wrote:
I do the same thing at sea level (only push the mixture in
1/2 an inch or so to start it, I start it lean and it stays lean until
I pull out onto the runway for take off).
Bela P. Havasreti
Jim Rosinski
N3825Q
Here are COS (elv 6100), we don't even start the engine at full rich.
We keep it about an inch out when we crank up on the 172's. Then I
even lean it a little more for the taxi. then I perform the run up and
lean as recommended. I have yet seen a fouled plug on run up doing
this in over 2 years.
Scott D,
Ground speed control with leaning Roger Long Piloting 11 June 8th 04 10:22 PM
Leaning / step climbing? aaronw Piloting 30 November 17th 03 06:44 PM
O-320 leaning Roger Long Piloting 5 November 9th 03 12:40 AM
Leaning with EGT? Chris W Home Built 3 September 18th 03 08:28 PM
More About Leaning During Climb Dan Luke Owning 13 July 11th 03 03:36 PM
