General aviation Aircraft mic inputs are designed for resistive CARBON
microphones. Now most modern aircraft mics are NOT carbon mics but they still emulate the old carbon mics and are powered by the bias current that is supplied by the radio to power the old carbon mic. The reason that some mics are not compatible is the electronic amplifiers in the new NON carbon mics seek to bias them selves at some voltage level between 3 and 8 volts. If you connect two of the amplifiers together directly without DC isolation resistors and caps the mic amp that has the lowest bias point wins and only it works well. Good intercoms have independent bias resistors for EACH microphone input. The cheap intercoms have only one bias resistor and tie the microphones together directly. This will only work if the mics are truly carbon elements but not if you use a modern mic that emulates a carbon mic. On Wed, 18 Jun 2003 22:51:45 +0100, "Andrew" wrote: I am trying to get to grips with why a pair of headsets will work fine in some aircraft but not in others. Headset suppliers say that this is not uncommon and try to sell a 'Matcher Unit' I would like to know what these units do and how they work (they intercept the mike jack and are powered by a nine volt battery) Does anybody have any technical info on this problem?? Many thanks |
| Thread Tools | |
| Display Modes | |
| ANR headset experience | Corky Scott | Piloting | 12 | August 20th 04 04:11 AM |
| Peltor Headset Experience | Mark T. Mueller | Owning | 7 | June 6th 04 08:40 PM |
| Headset music | Neil Bratney | Piloting | 23 | April 27th 04 01:59 PM |
| Bose makes good on my wife's headset. | Kyler Laird | General Aviation | 3 | March 10th 04 03:08 PM |
| Bose makes good on my wife's headset. | Kyler Laird | Piloting | 3 | March 10th 04 03:08 PM |
