I am in the process of restoring a Cessna 170. It is a major restoration
with many fuselage and wing skin pieces being replaced. How should I treat the interior surfaces? I initially planned to paint everything with zinc chromate. But the more I look into this, the more I worry about the toxicity of the zinc chromate and the lack of effectiveness in terms of corrosion proofing. I've heard of folks using self-etching primers, wash primers, epoxy primers, nothing at all, or even spray can enamels. What would you recommend? Thanks, Alex N170W Cessna 170B |
| Naval Air Refueling Needs Deferred in Air Force Tanker Plan | Henry J Cobb | Military Aviation | 47 | May 22nd 04 04:36 AM |
| Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart Hull | Home Built | 2 | November 24th 03 06:23 AM |
| Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart Hull | Home Built | 0 | November 24th 03 04:52 AM |
| Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart D. Hull | Home Built | 0 | November 22nd 03 07:24 AM |
| Long-range Spitfires and daylight Bomber Command raids (was: #1 Jet of World War II) | The Revolution Will Not Be Televised | Military Aviation | 20 | August 27th 03 10:14 AM |
