Hmmm. I did find one once, but as I can't remember where, tis is only to
give you hope. "karel adams" wrote in message ... Every version of FS I have known has a file called MAGDEC.BGL In FS2002 it is FS2002/SCENERY/MAGDEC.BGL It's size has remained constant since 5.1 and I reckon the contents haven't changed much either... This file must contain data for magnetic variation i.e. by reading this file it should be possible to determine the magvar for a given longitude/lattitude. Does anyone know how to do this? In other words how is the data organised in the file? Maybe a bit of code that actually reads this file? Or is there a place on the web where the various .BGL formats are explained? Somewhere on flighsim.com praps? TIA for any hint, Karel Adams |
In ,
karel adams wrote: Every version of FS I have known has a file called MAGDEC.BGL In FS2002 it is FS2002/SCENERY/MAGDEC.BGL It's size has remained constant since 5.1 and I reckon the contents haven't changed much either... This file must contain data for magnetic variation i.e. by reading this file it should be possible to determine the magvar for a given longitude/lattitude. Does anyone know how to do this? In other words how is the data organised in the file? Maybe a bit of code that actually reads this file? Or is there a place on the web where the various .BGL formats are explained? Somewhere on flighsim.com praps? TIA for any hint, Karel Adams Somebody once released details of the FS5.1 magvars, extracted from the .bgl and converted to text file format. I had a copy of it once but can't remember where I downloaded it from, nor where I've put it. Apparently, people did notice differences in the magvars when FS95 was released, so maybe more have happened since. Perhaps it would be possible for the values to change but the file size stays the same because the data is in fields, padded as necessary? It's not clear how the data extraction was done though, so repeating the task for a newer version of the file means working that out for yourself. What exactly would you need the data for? Does the Jeppeson database provided with 2002 not list magvars for the places you're interested in? -- regards, Mark |
| Thread Tools | |
| Display Modes | |
| Altimeters and air pressure variation | jharper aaatttt cisco dddooottt com | Piloting | 22 | January 12th 05 10:21 PM |
| Dynon EFIS D-10 Magnetic heading | Paul Lee | Home Built | 3 | November 15th 04 09:41 PM |
| Do you use your magnetic compass? | Roger Long | Piloting | 42 | May 25th 04 01:08 PM |
| Denver Terminal Area Chart Question - BVR vor/dme | Robert Easton | Piloting | 35 | February 8th 04 04:07 AM |
| Great circle formulae, True cource and actual heading | Sims | Piloting | 27 | October 11th 03 02:55 PM |
