I'm interested in trying to learn how to fly instrument approaches so
I checked out the lesson section of FS9. The lessons work OK but here's the problem. I cannot find a way to switch airplanes while taking a lesson. I have a number of downloaded planes that fly a whole lot better than the plane I'm stuck in for the lesson. I spend the first two minutes just trying to stabilize the altitude. Am I stuck with that plane or is their some way to change the default "lesson" plane? Thanks. Rich Russel |
Richard Russell wrote:
I'm interested in trying to learn how to fly instrument approaches so I checked out the lesson section of FS9. The lessons work OK but here's the problem. I cannot find a way to switch airplanes while taking a lesson. I have a number of downloaded planes that fly a whole lot better than the plane I'm stuck in for the lesson. I spend the first two minutes just trying to stabilize the altitude. Am I stuck with that plane or is their some way to change the default "lesson" plane? Thanks. Rich Russel In the FS9 home folder there is a sub-folder "lessons" with further sub-folders. If you look in "student" you see a number of .FLT files, with corresponding .ABL files. The airplane type is in the .FLT file. I have absolutely no idea what will happen if you change the aircraft, but maybe if you study those two files, you can decode enough information out of them, so that you could create your own "lesson", with a different aircraft. -- God grant me the serenity to accept the things I cannot change, the courage to change the things I can, and the wisdom to know the difference. --- Serenity Prayer |
On Fri, 10 Oct 2003 01:12:24 GMT, Icebound
wrote: Richard Russell wrote: I'm interested in trying to learn how to fly instrument approaches so I checked out the lesson section of FS9. The lessons work OK but here's the problem. I cannot find a way to switch airplanes while taking a lesson. I have a number of downloaded planes that fly a whole lot better than the plane I'm stuck in for the lesson. I spend the first two minutes just trying to stabilize the altitude. Am I stuck with that plane or is their some way to change the default "lesson" plane? Thanks. Rich Russel In the FS9 home folder there is a sub-folder "lessons" with further sub-folders. If you look in "student" you see a number of .FLT files, with corresponding .ABL files. The airplane type is in the .FLT file. I have absolutely no idea what will happen if you change the aircraft, but maybe if you study those two files, you can decode enough information out of them, so that you could create your own "lesson", with a different aircraft. Thanks much for the heads-up. I'll check that out tonight and hopefully won't cause too much damage. Rich Russell |
| Thread Tools | |
| Display Modes | |
| Pirep: Garmin GPSMAP 296 versus 295. (very long) | Jon Woellhaf | Piloting | 12 | September 5th 04 12:55 AM |
| Conspiracy Theorists (amusing) | Grantland | Military Aviation | 1 | October 2nd 03 01:17 AM |
| USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 04:17 PM |
| FS: 1989 "War Planes" (Of The World) Cards with Box | Jim Sinclair | Aviation Marketplace | 0 | August 23rd 03 05:43 AM |
| Real World Specs for FS 2004 | Paul H. | Simulators | 16 | August 18th 03 10:25 AM |
