Every time I apply full thorttle the plane tends to go to the left, it
doesn't matter if it is a 747 or a cessna, they both show the same behavior. Rudder Pedals are calibrated, wind is 0. what could be the problem? |
webmaster wrote:
Every time I apply full thorttle the plane tends to go to the left, it doesn't matter if it is a 747 or a cessna, they both show the same behavior. Rudder Pedals are calibrated, wind is 0. what could be the problem? I have a similar problem. My Saitek Cyborg 3d joystick never calibrates properly on the rudder axis. The centre is always a little out. If it were just with single prop aircraft I would have said P-factor but with multi-engined jets... You could try adjusting the dead zone on the rudder axis in the settings in FS. Or try using the rudder trim to correct for the effect. |
On Tue, 06 Jan 2004 13:02:31 GMT, "webmaster"
wrote: Every time I apply full thorttle the plane tends to go to the left, it doesn't matter if it is a 747 or a cessna, they both show the same behavior. Rudder Pedals are calibrated, wind is 0. what could be the problem? The Cessna should. The 747 shouldn't. With the 172 it's a portrayal of the torque, but I don't know why the 747 does. To me that would be a bug unless the throttles are not all going forward. I take it all 4 engines are spooling up to 100%? Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
I've had the ssame probalem forever with all of the FS models. Strangely, If I
immediately reset the flight, the take off is right down the middle. It happens only when I first try to fly. This is not P factor as it happens with couter-rotating prop planes. |
