USA: Experimental Certificates
Old October 27th 03, 10:28 PM
C.Fleming
Default USA: Experimental Certificates
Do new gliders delivered to USA customers have Experimental Certificates?
If so, why? If not, why do most second-hand gliders have Experimental
Certificates?
Please reference any replies.
Thanks!
Chris
Old October 28th 03, 12:07 AM
Judy Ruprecht
At 22:00 27 October 2003, Todd Pattist wrote:
My understanding is that the (US) process is
much easier now if the glider is certified in its home
country.
Perhaps some European ras-ers can comment on whether
and how individual countries' aircraft certification
processes are up for revision with the EU craze. Do
I understand correctly that there are some interim
procedures attempting to 'harmonize' things right now?
What lies ahead?
Judy
Old October 30th 03, 11:48 PM
Ivan Kahn
"C.Fleming" wrote in message
Certificates?
Thanks!
Chris
I think you will find that gliders are delivered to the US without any
certificate at all - the owner makes an application to the FAA for the
airworthiness certificate. If the glider was certificated under the Joint
Aviation Regulations (JAR) then it is eligible for a standard certificate.
Otherwise, there are other hoops to jump through to get a standard
certificate, if one can be had at all. So in many cases the experimental
certificate is issued because the glider is either not eligle, or because it
was too much touble to get the standard.
Having an experimental certificate also gives you more latitude in making
modifications to the glider and so some gliders that are eligible for a
standard certificate have an experimental instead - in these cases the owner
felt the benefits of the experimental certificate outweighed the
limitations.
As to why so may used ships have experimental certificates, all the above
applies plus I think you will find that the further back you go the small
the population of gliders that were eligible for a standard certificate.
Ivan
PA-32 on Experimental Certificate Mike Granby Owning 3 July 21st 04 04:04 AM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 April 5th 04 04:04 PM
Crashing Experimental on America's Funniest Home Videos Jay Home Built 7 March 10th 04 01:11 AM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 2 February 3rd 04 12:41 AM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 1 January 2nd 04 10:02 PM
