Flaps and V-Tails of Death
Old November 17th 03, 09:32 PM
Wallace Berry
Default Flaps and V-Tails of Death
Hi all,
I'm here to report that I cheated death and survived a flight in a
glider with the dreaded "Landing Flaps and V-Tails of Death". Jim Harper
graciously allowed me to fly his beautiful HP-16. What's an HP-16 you
say? Well, looks to be just like the HP-18 (or I should say the HP-18 is
just like the -16) except that the -16 has a large and comfortable all
metal cockpit instead of the narrow composite cockpit of the -18.
Jim's -16 is equipped with winglets and, as far as I know, the ailerons
are standard (not with the J.D. Colling mod, correct me if I'm wrong
Jim). Center stick. Tow was behind our 180hp Cessna 175 on a 275 foot
long rope. Started out in -2 flap position, went to + 5 at 40 knots. Had
no trouble keeping the wings level. The bird lifted off level and was
easy to fly on tow. Released and tried slow flight (no stalls), flight
up to 90 knots. Steep turns, etc. Well sealed and quiet. Good rudder
response and easy to coordinate compared to my 301 Libelle. More stable
in a thermal than my Libelle. Aileron response was a little slower than
my Libelle at thermaling speeds, but was positive and more than adequate
for centering thermals. Climbed a few hundred feet in a very week
thermal. Very nice thermalling glider.
Landing was the best part. I stayed high and close in the pattern. I
rolled on some flap on downwind, maybe 30 degrees or so. I was way high
on final so I started rolling in more flaps. I never quite got to the
full 90 degrees mark as I had the nose down at a truly obscene angle
just to maintain 50 knots. Steeper than my 301 with the tailchute and
full divebrakes. Steeper than a Mosquito with everything hanging out.
This was more like parachuting than flying. Nothing but dirt out the
front of the canopy. The horizon was visible more towards the top of the
canopy. I aimed at a target and just kept the nose pointed there. I
pulled back on the stick when I ran out of nerve. The bird settled on
with a slight bump of the tailwheel and a little bounce as the main
dropped on (I flared just a bit too much). I have no doubt that I could
easily put this bird in a tiny field much easier than I could my Libelle
(and that is not difficult at all).
So, I'd have to say that all the bad things I've been told about landing
flaps on gliders and V-tails are definitely untrue with respect to the
HP-16. It is a comfortable and easy to fly glider and compares very well
to my Libelle and also to other glass birds, including my favorites for
handling, the Mosquito and LS-4.
Old November 17th 03, 11:32 PM
Eric Greenwell
HP-16.
If you believe that, perhaps you haven't been told "all the bad things".
For example, I've had HP pilots tell me getting sucked up into a cloud
can be "awkward" to deal with when all you've got is flaps.
My first and only flight in an HP went like Mr. Berry's; even so, I hope
anyone beginning to fly a flaps only glider gets thorough checkout,
because there are ways to go wrong.
Replace "SPAM" with "charter" to email me directly
Eric Greenwell
Washington State
USA
Old November 18th 03, 12:40 AM
Bob Whelan
HP-16.
No offense, Eric, but speaking from the vantage point of one with all his
1-26 glide-ratio time in flaps-only ships (C-70, HP-14, Zuni), the more
powerful the flaps, the _less_ 'exciting' it need be if you allow yourself
to get sucked into a cloud. (For those unfamiliar with lift in the western
U.S., streets miles long and wide containing lift exceeding 10 knots are not
uncommon, and 'getting sucked into a cloud' _can_ happen, even if relatively
savvy and switched on...scale effects, new experience learning curves, etc.)
Can we take as a given that what's 'thrilling' about IFR flight with a VFR
panel is the very real possibility of pulling wings off in the ensuing
spiral dive? If that's true, then the more drag you have available...and
flapped HP's tend to have a LOT of disposable drag [a great thing as Wallace
B. better understands now, :-)]...the less thrilling blind flight. My HP-14
wouldn't exceed 55 knots (as I recall) with full flaps when left to its own
(hands-off) devices for minutes on-end. Sure, it took on some interesting
attitudes as it alternately nosed up, stalled, fell off on a wing, regained
speed, nosed up...etc., but there was no way it was ever going to come close
to maneuvering speed. To avoid the repeated stalling, all one needed to do
was hold 40 knots with full flaps (required forward stick). You'd
eventually end up in a steep spiral, but, so what?
My Zuni is less forgiving (considerably weaker flaps...i.e. less drag than
the HP-14) in this regard, and will pretty soon exceed 75 knots
hands-off-the-stick in the zoom, stall, fall off sequence, but like the HP
is utterly innocuous if trimmed aft w. full flaps and held at 40 (or 45 or
whatever one is comfortable with). Again, you're likely to eventually end
up in a tight spiral if using this technique, but you're not going to pull
the wings off.
IMHO, playing imaginary mind games (and backed up by considerable
experimentation over the years), my personal adrenaline level will be a lot
lower in a flaps-only ship having 'adequate drag' (and I know of no 15-meter
flap-only ships that do not) than in a spoilers-only ship if I envision
being in a big, turbulent cloud with a VFR panel. For the record, I'm aware
of the 'benign spiral mode.'
Actually, I suspect 'flapped cloud safety' comes not so much the flaps
as-such, but from their high level of drag. Imagine a tail-chute-only of
'ridiculously large diameter' to see what I mean...likewise, 'ridiculously
large spoilers'. For non-U.S. pilots, the most powerful spoiler-only
gliders I know of are the Schweizer 1-34 and 2-32, both of which have
terminal-velocity-limiting dive brakes. Personally, I'd much rather come
out the bottom of a cloud doing 40 knots in a spiral than at Vne more or
less vertically. Adrenaline may have its place in the human condition, but
I prefer to keep mine out of the cockpit!
Regards,
Bob - you can't have too much disposable drag - Whelan
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.538 / Virus Database: 333 - Release Date: 11/10/2003
Old November 18th 03, 12:59 AM
Eric Greenwell
HP-16.
The situations described to me were the difficulty of avoiding the cloud
entry in the first place. A pilot can open his spoilers at 90 knots and
begin descending immediately, but deploying the flaps at 90 knots first
increases your altitude, making it much harder to stay out of the cloud.
If you do lose control in a cloud, lots of drag is an advantage.
The main point I hoped to make is landings aren't the only way spoilers
and glide path flap operation differs, and one good landing isn't enough
to know the pitfalls, even for landings. I think everyone agrees the HP
series is a great ship to make off-field landings in the hands of a good
pilot.
Eric Greenwell
Washington State
USA
Old November 18th 03, 03:16 AM
Scott Correa
pilot.
Eric Greenwell
Washington State
USA
Eric.
Good points.... But flap deployment at speed needn't cause an altitude
change.
Roll 40 or so your favorite direction, g up and put them out. Minimal
altitude gain if any.
Scott.
Old November 18th 03, 04:38 AM
Al
Scott remember Eric speaks for the little old lady division of the SSA.
Winter is here let the fun begin.
Al
"Scott Correa" wrote in message
pilot.
Eric Greenwell
Washington State
USA
Eric.
change.
Scott.
Old November 19th 03, 11:47 AM
Silent Flyer
When Slingbys tried to produce the HP14 for the British market they ran into
trouble with the use of flaps only for cloud flying. At that time to get an
airworthiness certification the glider had to have speed limiting devices
for cloud flying. It had been proved in test flying that the flaps
certainly limited the airspeed to "rough air max." but the test pilot ( John
Williamson) reported if the airspeed was already high and rising, the effort
required to lower the flaps down to 90 degrees was just too much.
If the sailplane was genuinely going out of control in cloud the flaps would
be useless. Various methods were tried to overcome this including a high
pressure air bottle to actuate pneumatic jacks- unfortunately at high speeds
forcing the flaps down in this manner caused problems with the supporting
secondary spar structure requiring yet further modifications.
DB
Old November 18th 03, 02:12 AM
Doug Hoffman
"all the bad things"? Do go on, Eric.
I fly an RS-15 and I don't worry about spoiler(s) not being connected or
accidentally opening. There are some very positive things about the HPs.
Also, when landing flaps are deployed the ship becomes incredibly stable and
the stall speed decreases. That's a nice feeling when down low.
As with any ship that is "new in type" to the pilot. But good advice.
Regards,
-Doug
Old November 18th 03, 04:01 PM
Wallace Berry
HP-16.
No doubt there are ways to go wrong, but every design has it's quirks. I
would sooner turn a low time pilot loose in that HP-16 than my 301
Libelle.
For sure my one experience in a landing flapped equipped bird is far too
little experience to generalize. That's why I limited my comments to the
HP-16. However, I have been told horror stories about V-tails and
landing flaps. You know the stories. I was told the V-tail HP's were
hard to fly and dangerous for any but the most experienced fliers. I'm
no ace but I thought the thing was very easy to fly. Maybe the other
HP's are different. The main myth is that you can't modulate the flaps
to control glide path. In the HP-16, I rolled the flaps on and off
within a fairly wide range and the glider behaved very much like a
glider with very effective divebrakes. I would be very comfortable
landing Jim's HP-16 in any reasonably landable field.
Deploying flaps at high speeds can be problematic in a number of ships.
I have heard that at least one 301 Libelle structural failure was due to
flap deployment at a speed significantly above Vne. However, a number of
ships which have flaps that deploy with the divebrakes have maximum
deployment speed limitations too. And, not to forget, deployment of just
divebrakes at high speeds can be dangerous. I think a couple of open
class ships have lost their wings when the divebrakes were deployed well
over Vne.
As for getting sucked into a cloud, I would have an easier time keeping
that HP-16 out of the cloud than my Libelle with it's relatively
ineffective divebrakes. I have been in the gear down, full divebrakes
and full slip configuration diving for the edge of the cloud at high
speed to keep from getting sucked in.
Fly safe,
Wallace
Old November 18th 03, 04:37 PM
Eric Greenwell
The 301 definitely has weak spoilers (good wheel brake, though!), which
is one reason I moved to an ASW 20C.
Eric Greenwell
Washington State
USA
f-84G Flaps question Frederico Afonso Military Aviation 0 September 8th 04 06:58 PM
757 flaps miss-aligned in cruise AnyBody43 General Aviation 1 April 2nd 04 02:01 AM
Cessna 182S flaps EDR Piloting 7 January 16th 04 03:37 AM
Slats and Fowler Flaps On Light Plane Brock Home Built 28 July 31st 03 11:12 PM
automatic flaps problem in Beechcraft KAF90 deeknow Simulators 0 July 24th 03 03:45 AM
