Are any solvents damaging to gelocat?
Xylene, lacquer thinner, gasoline, paint thinner? GA |
Yes
"Nolaminar" wrote in message ... Are any solvents damaging to gelocat? Xylene, lacquer thinner, gasoline, paint thinner? GA |
Phil Jeffery wrote:
Yes "Nolaminar" wrote in message ... Are any solvents damaging to gelocat? Xylene, lacquer thinner, gasoline, paint thinner? GA We routinely remove traces of glue from adhesive tape with gasoline (100 LL), and those from mylar seals with aceton without any damage to the gelcoat. |
WD40 works well on tape residue too.
Robert Ehrlich wrote: Phil Jeffery wrote: Yes "Nolaminar" wrote in message ... Are any solvents damaging to gelocat? Xylene, lacquer thinner, gasoline, paint thinner? GA We routinely remove traces of glue from adhesive tape with gasoline (100 LL), and those from mylar seals with aceton without any damage to the gelcoat. |
Robert Ehrlich wrote: Phil Jeffery wrote: For years I was a shade tree mechanic....fixing my cars, friends and families ...... And during engine rebuilds, I'd often use just gasoline and alot of elbow grease to clean stuff up.... But you know what REALLY cleaned up stuff MUCH nicer, quicker, and easier than gasoline? Not to mention being much safer and easier to work with? Diesel fuel (and I suspect kerosene would be similiar). Off hand you might think gas would be a much better solvent for getting grung off...but the diesel was MUCH better and faster....at least on the stuff on and in car engines... So, maybe try diesel, and then use something like alchohol to remove the last traces of diesel residue? take care Blll |
Well,
Jet-A works like diesel and doesn't smell as bad. Cheers! "BllFs6" wrote in message ... WD40 works well on tape residue too. Robert Ehrlich wrote: Phil Jeffery wrote: For years I was a shade tree mechanic....fixing my cars, friends and families ..... And during engine rebuilds, I'd often use just gasoline and alot of elbow grease to clean stuff up.... But you know what REALLY cleaned up stuff MUCH nicer, quicker, and easier than gasoline? Not to mention being much safer and easier to work with? Diesel fuel (and I suspect kerosene would be similiar). Off hand you might think gas would be a much better solvent for getting grung off...but the diesel was MUCH better and faster....at least on the stuff on and in car engines... So, maybe try diesel, and then use something like alchohol to remove the last traces of diesel residue? take care Blll |
In article , Mark
Zivley writes WD40 works well on tape residue too. Robert Ehrlich wrote: Phil Jeffery wrote: Yes "Nolaminar" wrote in message ... Are any solvents damaging to gelocat? Xylene, lacquer thinner, gasoline, paint thinner? GA We routinely remove traces of glue from adhesive tape with gasoline (100 LL), and those from mylar seals with aceton without any damage to the gelcoat. The handbook for our DG202 specifically warns against using petrol/gasoline for cleaning. -- Mike Lindsay |
Nolaminar wrote:
Are any solvents damaging to gelocat? Xylene, lacquer thinner, gasoline, paint thinner? If I had this question, I'd ask someone like Bob Gaines...smiley face I'm sure all of them "damage" the gel coat, but perceptible damage depends on how often and how much, and the condition of the gel coat to begin with. My experience is occasionally cleaning of tape residue or transfer adhesive (mylar seals) isn't a problem, even after 10 years, on gel coat that is in good condition to begin with. Some polishes for gel coat, like Lesonal, are petroleum based anyway (I think so, but someone that has a can of this with the label still on it, please check!). Under what circumstances did you want to use the solvents? -- Change "netto" to "net" to email me directly Eric Greenwell Washington State USA |
| Thread Tools | |
| Display Modes | |
