After every flight, Qantas pilots fill out a form, called a "gripe =
sheet," which tells mechanics about problems with the aircraft. The = mechanics correct the problems; document their repairs on the form, and = then pilots review the gripe sheets before the next flight. Never let it = be said that ground crews lack a sense of humour. =20 Here are some actual maintenance complaints submitted by Qantas' pilots = (marked with a P) and the solutions recorded (marked with an S) by = maintenance engineers. By the way, Qantas is the only major airline = that has never had an accident. ... Enjoy! =20 P: Left inside main tire almost needs replacement. =20 S: Almost replaced left inside main tire. =20 P: Test flight OK, except auto-land very rough. =20 S: Auto-land not installed on this aircraft. =20 P: Something loose in cockpit. =20 S: Something tightened in cockpit. =20 P: Dead bugs on windshield. =20 S: Live bugs on back-order. =20 P: Autopilot in altitude-hold mode produces a 200 feet per minute = descent. =20 S: Cannot reproduce problem on ground. =20 P: Evidence of leak on right main landing gear. =20 S: Evidence removed. =20 P: DME volume unbelievably loud. =20 S: DME volume set to more believable level. =20 P: Friction locks cause throttle levers to stick. =20 S: That's what they're for. =20 P: IFF inoperative. =20 S: IFF always inoperative in OFF mode. =20 P: Suspected crack in windshield. =20 S: Suspect you're right. =20 P: Number 3 engine missing. =20 S: Engine found on right wing after brief search. =20 P: Aircraft handles funny. (I love this one!) =20 S: Aircraft warned to straighten up, fly right, and be serious. =20 P: Target radar hums. =20 S: Reprogrammed target radar with lyrics. =20 P: Mouse in cockpit.=20 S: Cat installed. =20 And the best one for last... =20 P. Noise coming from under instrument panel. Sounds like a midget = pounding on something with a hammer. =20 S: Took hammer away from midget=20 --=20 ---------------------------------------------------------------- "Common sense is not so common."=20 -- Voltaire |
OT - humour.. | Ghost | Home Built | 0 | August 23rd 04 07:07 PM |
An oldie question | DeltaDeltaDelta | Simulators | 0 | July 19th 04 01:52 PM |
And they say the Germans are without humour! | Lars Peder Hansen | Soaring | 2 | December 15th 03 10:46 PM |
military humour | Ed Majden | Military Aviation | 3 | October 25th 03 12:30 PM |
Humour: CO DATA PAGE TERMINOLOGY CAT:BTN SUB:DES PGE:TRM | Dave Kearton | Military Aviation | 0 | September 24th 03 10:38 AM |
