cambridge 302
Old March 4th 20, 08:42 PM posted to rec.aviation.soaring
john firth
Default cambridge 302
Just bought a used CAI 302 from W and Wh; unfortunately many accessories
are missing incl. the CD.
I have installed and run the 300 support program, and configured the
302 for my PIK 20E.
Turn on does the usual start routine, but settles with +2kts indicated.
Any ideas?
John Firth ( old but no longer bold pilot)
Old March 4th 20, 09:10 PM posted to rec.aviation.soaring
Nick Gilbert[_2_]
Is it in cruise mode? What happens when you switch it?
Old March 4th 20, 11:03 PM posted to rec.aviation.soaring
Nick Kennedy[_3_]
John
When you power it up make sure the sun is not on the 302 face.
Having sun on the instrument face can cause your problem.
Nick
Old March 5th 20, 03:37 PM posted to rec.aviation.soaring
john firth
302 for my PIK 20E.
Any ideas?
It seems "netto" mode causes the offset but 2kts?
Anyway, TE mode restores the zero.
John F
Old March 5th 20, 05:44 PM posted to rec.aviation.soaring
Martin Gregorie[_6_]
accessories are missing incl. the CD.
302 for my PIK 20E.
Any ideas?
Netto mode generally needs to know the glider's polar since its trying to
tell you what the air is doing rather than whether the glider is climbing
or sinking, so it might be a good idea to see what glider polar is set in
the 302 and whether it matches your glider.
IOW it looks as if this is what the 302 thinks is going on: since it sees
neither climb or sink on the bench, but is showing +2 kts, it must have
assumed a sink rate for the glider in still air of 200 fpm, so therefore
the airmass must be rising at +2 kts for the bench to be neither climbing
nor sinking. Or something like that.
Martin | martin at
Gregorie | gregorie dot org
FS Cambridge 303 Jim[_18_] Soaring 0 June 24th 14 05:41 PM
FS Cambridge 302 and 303 KG[_2_] Soaring 6 June 18th 14 02:43 PM
WTB: 57mm Cambridge Vario/FS: 80mm Cambridge Vario ufmechanic Soaring 0 March 24th 09 05:31 PM
Cambridge 302 & PDA -- Value of adding Cambridge 303? V1 Soaring 5 July 31st 07 03:51 AM
Cambridge 302/Cambridge 3UTIQ255 utility/ WinPilot/iPAQ 4155 Nathan Whelchel Soaring 4 July 5th 04 11:22 PM
