All:
I have a 1966 C150 with a Continental 200 engine. Before I bought the plane,the owner had the generator removed and replaced with an alternator.Part of that installation included a circular cluster gage that has a voltmeter,ammeter,cht meter and egt meter. During my recent run-up I switched the alternator field off and realized the voltmeter was reading app.3 volts and the ammeter sat at zero. Further tests show the voltmeter reads app. 3 volts when the master is on and zero when the master is off. I connected a voltmeter to a cigerette lighter plug and it read 11.9 volts.With the engine running the voltage increases to 14.2.This shows the alternator is doing it's thing but the gages are not.Connecting a milliamp meter across the shunt terminals definately shows a differnt reading when radios or any lights are turned on or off. It would appear the meters in the plane have gone west, but it seems too much of a coincedence that both would crap out at the same time.Especially since the volt meter reads something (not correct) while the ammeter doesn't respond at all. Anyone had any experience with this sort of thing?My next step is to cut apart the nice neat wiring harness and try to trace all wires looking for bad connections or removing the cluster gage and bench testing.Both of these are a major pain in the a**.I am looking for a simple solution but I am aware such a thing may exist only in my sometimes vivid imagination. Any and all suggestions greatly appreciated. Bob Barker N8749S |
On Sun, 3 Apr 2005 09:58:55 -0400, "Robert A. Barker"
wrote: All: I have a 1966 C150 with a Continental 200 engine. Before I bought the plane,the owner had the generator removed and replaced with an alternator.Part of that installation included a circular cluster gage that has a voltmeter,ammeter,cht meter and egt meter. During my recent run-up I switched the alternator field off and realized the voltmeter was reading app.3 volts and the ammeter sat at zero. Further tests show the voltmeter reads app. 3 volts when the master is on and zero when the master is off. I connected a voltmeter to a cigerette lighter plug and it read 11.9 volts.With the engine running the voltage increases to 14.2.This shows the alternator is doing it's thing but the gages are not.Connecting a milliamp meter across the shunt terminals definately shows a differnt reading when radios or any lights are turned on or off. It would appear the meters in the plane have gone west, but it seems too much of a coincedence that both would crap out at the same time.Especially since the volt meter reads something (not correct) while the ammeter doesn't respond at all. Anyone had any experience with this sort of thing?My next step is to cut apart the nice neat wiring harness and try to trace all wires looking for bad connections or removing the cluster gage and bench testing.Both of these are a major pain in the a**.I am looking for a simple solution but I am aware such a thing may exist only in my sometimes vivid imagination. Any and all suggestions greatly appreciated. Bob Barker N8749S the simplest solution would be to mark them unserviceable and keep flying. Stealth ( but I bet you wont do that :-) ) Pilot |
You most likely have a high resistance in the wiring to one of the
shunt taps. This should be findable with a ohm meter. I will bet it is a butt splice made with a cheap crimper. Get a T&B IU style crimping tool. John On Sun, 3 Apr 2005 09:58:55 -0400, "Robert A. Barker" wrote: All: I have a 1966 C150 with a Continental 200 engine. Before I bought the plane,the owner had the generator removed and replaced with an alternator.Part of that installation included a circular cluster gage that has a voltmeter,ammeter,cht meter and egt meter. During my recent run-up I switched the alternator field off and realized the voltmeter was reading app.3 volts and the ammeter sat at zero. Further tests show the voltmeter reads app. 3 volts when the master is on and zero when the master is off. I connected a voltmeter to a cigerette lighter plug and it read 11.9 volts.With the engine running the voltage increases to 14.2.This shows the alternator is doing it's thing but the gages are not.Connecting a milliamp meter across the shunt terminals definately shows a differnt reading when radios or any lights are turned on or off. It would appear the meters in the plane have gone west, but it seems too much of a coincedence that both would crap out at the same time.Especially since the volt meter reads something (not correct) while the ammeter doesn't respond at all. Anyone had any experience with this sort of thing?My next step is to cut apart the nice neat wiring harness and try to trace all wires looking for bad connections or removing the cluster gage and bench testing.Both of these are a major pain in the a**.I am looking for a simple solution but I am aware such a thing may exist only in my sometimes vivid imagination. Any and all suggestions greatly appreciated. Bob Barker N8749S |
| Thread Tools | |
| Display Modes | |
| Mooney Engine Problems in Flight | Paul Smedshammer | Piloting | 45 | December 18th 04 10:40 AM |
| Uvalde Open and 18 Meter 2ond practice day.#711 reporting | TomnKeyLargo | Soaring | 0 | August 9th 04 05:58 PM |
| Radio Shack SWR meter | Paul Lee | Home Built | 6 | June 2nd 04 05:42 AM |
| F22 Problems | Paul F Austin | Military Aviation | 9 | February 5th 04 03:27 AM |
| Kestral 1000 Wind Speed Meter NEW IN BOX | Cecil E. Chapman | Products | 0 | November 7th 03 07:56 PM |
