Over some time the bolt holes in the link between the horizontal stabilizer
and the trim mechanism have been elongated. To get rid of the play, I consider installing an oversized bolt. The original bolt is an AN5-7. I am confused about the designation on oversized bolts. Can anyone help ? Thank you in advance. Kjell Sivertsen |
The spec's are about to be consolidated (so I've been told).. so dont
spend too much time memorizing things.. But the AN5 refers to "Army Navy spec", the number 5 in this case is the bolt diameter in 1/16" of an inch.. so this is 5/16".... an AN6 would be 6/16" (more commonly known as 3/8" The 7 in this part refers to the lengh.. and I do NOT know the specifics on the length.. There are bolt gauges that can be bought, and Bolt charts probably on the net that have the specs on them The next up AN bolt would be an AN6, so an AN6-7. Now.. I do not know the circumstances of your situation, and I'm not an A&P either, but you might want to inquire if that is an "approved repair" or even recommended in the spot that you are considering. I would check with a pro before doing this. The hole elongation MIGHT be a sign that the parts need replacing (MIght.. I dont know..dont claim to know). Dave Kjell Sivertsen wrote: Over some time the bolt holes in the link between the horizontal stabilizer and the trim mechanism have been elongated. To get rid of the play, I consider installing an oversized bolt. The original bolt is an AN5-7. I am confused about the designation on oversized bolts. Can anyone help ? Thank you in advance. Kjell Sivertsen |
Dave S wrote:
The 7 in this part refers to the lengh.. and I do NOT know the specifics on the length.. There are bolt gauges that can be bought, and Bolt charts probably on the net that have the specs on them An AN5-7 has a grip of 7/16" and a length of 31/32". Don't assume that the -7 has these dimensions for every diameter - an AN6-7 has a grip of 5/16" and length of 61/64". See http://tinyurl.com/5zd4n George Patterson There's plenty of room for all of God's creatures. Right next to the mashed potatoes. |
"Kjell Sivertsen" wrote in message ... Over some time the bolt holes in the link between the horizontal stabilizer and the trim mechanism have been elongated. To get rid of the play, I consider installing an oversized bolt. The original bolt is an AN5-7. I am confused about the designation on oversized bolts. Can anyone help ? Thank you in advance. Kjell Sivertsen Are you considering going up to a AN6 bolt? I am familiar with oversize rivets but not bolts. I think you might be required to replace the worn parts if it is a certified airplane. Mike MU-2 |
"Kjell Sivertsen" wrote in message ... Over some time the bolt holes in the link between the horizontal stabilizer and the trim mechanism have been elongated. To get rid of the play, I consider installing an oversized bolt. The original bolt is an AN5-7. I am confused about the designation on oversized bolts. Can anyone help ? Thank you in advance. Kjell Sivertsen I don't think they make AN bolts in oversize sizes like some NAS hardware. The issue though is not the bolt, but the hole it fits into. By the time you ream it out to fit a larger bolt, you may have lost the design strength required. You need to replace the part and the bolt. Don A&P / IA Posted Via Usenet.com Premium Usenet Newsgroup Services ---------------------------------------------------------- ** SPEED ** RETENTION ** COMPLETION ** ANONYMITY ** ---------------------------------------------------------- http://www.usenet.com |
Kjell Sivertsen wrote: Over some time the bolt holes in the link between the horizontal stabilizer and the trim mechanism have been elongated. To get rid of the play, I consider installing an oversized bolt. The original bolt is an AN5-7. I am confused about the designation on oversized bolts. Can anyone help ? Thank you in advance. Kjell Sivertsen Kjell, Several NAS and MS bolts are available in diameters 1/64 inch oversize (also 1/32 over). The advice from others that making the hole larger may weaken the part too much is correct, and you have no real way of knowing that. Getting a suitable bolt is not much of a problem. To assure that the link is strong enough, you may have to replace it. Regards, Bruce Cunningham N30464 C177A |
Kjell, Several NAS and MS bolts are available in diameters 1/64 inch oversize (also 1/32 over). Where are these available? I know of industrial applications where quality oversize bolts would be very useful. |
nrp,
Try gen-aircraft-hardware.com or give them a call. There are lots of places in S. Cal. that sell aircraft quality hardware. You need to find out exactly which NAS and MS bolts you need and then do a google search. I have done this in the past and found several suppliers of say, NAS 8703 stainless countersunk bolts for Lance fuel tank screws. You realize that there are hundreds of different NAS and MS bolts available, all the way up to 260,000 psi tensile strength, corrosion resistant, 1200 degree F, etc. Some designations are merely 1/64 or 1/32 oversize of a certain other NAS or MS number. regards, Bruce Cunningham N30464 C177A |
| Oil Leak on top of the engine -- follow up | Jay Honeck | Owning | 6 | February 13th 05 02:50 PM |
| Oil leak on top of the engine | Jay Honeck | Owning | 31 | February 12th 05 03:27 AM |
| Epoxy Bonding to Aluminum and Magnesium | Ryan Young | Home Built | 25 | September 16th 04 03:45 AM |
| Source for Bolts | Dave | Home Built | 2 | May 20th 04 09:09 PM |
| Can F-15s making 9G turns with payload? | Paul J. Adam | Military Aviation | 114 | September 27th 03 06:47 AM |
