NACA Numbers???
Old October 8th 04, 07:37 PM
c hinds
Default NACA Numbers???
How are they decoded? The aircraft I am constructing has the NACA
Airfoil number of 65(3)518-A7. Any comments or suggestions are
welcome.
Thanks,
Clark
Old October 8th 04, 11:54 PM
Cy Galley
The NACA 5-digit airfoils are set up in a similar manner
to the 4-digit airfoils. The primary difference is the use
of a different camber line. In a 5-digit airfoil, 1.5 times
the first digit is the design lift coefficient in tenths, the
second and third digits are one-half the distance from the
leading edge to the location of maximum camber in percent of
the chord, and the fourth and fifth digits are the thickness
in percent of the chord. For example, a NACA 23015 airfoil
has a design lift coefficient of 0.3, has the maximum camber
at 0.15c, and is 15% thick. Additionally, the first three
digits indicate the mean line used. In this case, the mean
line designation is 230. The 5-digit airfoils use the same
thickness distribution as the 4-digit airfoils. This example
is displayed below.
NACA 23015
NACA 230 mean line (230)
15 thickness, % (15%)
NACA 2 (design lift coefficient * 10) / 1.5, (0.3)
30 2 * (position, maximum camber), (0.30 / 2 = 0.15c)
15
NACA 23
0 type of camber line used
15
"c hinds" wrote in message
om...
welcome.
Thanks,
Clark
Old October 9th 04, 05:27 AM
Dave Hyde
6 is the series number (near-laminar, low drag), the first 5 is the
location of minimum pressure (50% chord), the second 5 is the
design lift coefficient x 10 (0.5) 18 is the thickness (% chord).
The subscript 3 means it's near-laminar (or low-drag) within
+/- 0.3 CL of the design CL, or at lift coefficients from
0.2 to 0.8. The a-number (should be less than 1) is the
chordwise percentage of the airfoil that has a uniform pressure
distribution, in this case (probably) 70%.
Clear as mud.
Dave 'keep it clean' Hyde
Old October 11th 04, 10:40 PM
c hinds
Thank you! Clear and concise.
Press fit numbers? Boelkowj Home Built 1 April 29th 04 07:51 PM
Any Canadians Who Can Provide Numbers on a Champ, Taylorcraft, or Luscombe with Warp Drive Propeller? Larry Smith Home Built 7 December 21st 03 10:39 PM
Reverse NACA duct Chris W Home Built 22 October 28th 03 11:59 PM
NACA duct ventrui Chris W Home Built 7 October 27th 03 05:11 PM
Darpa contract numbers - = krusty = - Home Built 9 July 23rd 03 04:22 AM
