A-65 mechanic question
Old May 25th 05, 12:23 AM
Michael Horowitz
Default A-65 mechanic question
My A-65 had the lower half redone.
At operating temp. and at idle, the oil pressure is certainly below
15PSI and may be below 10.
I asked the company that did the work and they replied "we don't worry
about low pressure at idle".
Continental says a minimum of 10PSI.
I'll get my A&P to put a real pressure gauge on to see what the
pressure is.
In your experience, does idle typically produce less than 15PSI or am
I looking at a problem?
Old May 25th 05, 06:58 PM
Bertie the Bunyip
Michael Horowitz
pressure is.
If it's just had a bottom overhaul and broken in, you should see a bit
under thirty at an idle of around 500 rpm if you have healthy oil pressure
at higher power settings. Down to twenty might be reasonable, but I'd say
something is wrong if you have less than ten at idle. Might very well be
your gauge though, as you say.. ..
Old May 25th 05, 09:41 PM
Philippe
pressure is.
spring oil pressure relief valve P/N 21352
Just install a new spring and you get higher oil press.
I do that and my pressure jump to the high side of the normal range.
It cost me 2 euros (2.6$) for this paperless new spring.
The new spring was 1" longer than the 40 year old one.
If it don't work, you may suspect your engine bearings are in poor
condition.
By
Pub: http://www.slowfood.fr/france
Philippe Vessaire Ò¿Ó¬
Old May 26th 05, 02:27 AM
Michael Horowitz
pressure is.
condition.
By
Philippe - doesnt that relief valve control the upper limit i.e. opens
at pressures greater than 35psi? - Mike
Old May 26th 05, 07:22 AM
Philippe
I agree but with a very weak spring, it work for me... Why not try this
first? ....
By
Old May 27th 05, 07:56 AM
Philippe
first? ....
If you have a weak spring, your higher power settign OP will also be low.
Yes, it was...
Old May 26th 05, 05:21 AM
There are other potential reasons for low A-65 oil pressure. See the third
paragraph:
http://www.bowersflybaby.com/tech/fenton.htm#studs
182RG question Paul Anton Owning 11 May 16th 05 10:45 PM
Good morning or good evening depending upon your location. I want to ask you the most important question of your life. Your joy or sorrow for all eternity depends upon your answer. The question is: Are you saved? It is not a question of how good Excelsior Home Built 0 April 22nd 05 02:11 AM
molding plexiglas websites? [email protected] Owning 44 February 17th 05 10:33 PM
